Home » Newcomers » Newcomers » JDK compliance
JDK compliance [message #24338] Wed, 02 February 2005 22:51 Go to next message
Originally posted by: javabeanist.hotmail.com
I just got started with Eclipse (v3.0). I want to use the JDK 1.5.0.
(which is installed on my machine). When I set up the JDK compliance level
(Window > Preferences > Compiler), the only compliance levels offered in
the pull down menu are 1.3 and 1.4. No 1.5! Because I can't select 1.5, my
apps using 1.5 features (such as Scanner) won't compile.
How can I select the compiler compliance level 1.5?
Re: JDK compliance [message #24455 is a reply to message #24338] Thu, 03 February 2005 04:51 Go to previous messageGo to next message
Originally posted by: ot_mail.hotmail.com
Hi.
Install Eclipse 3.1 M4 and you will find level 1.5 inside
Window/Preferences/Compiler ;)
Re: JDK compliance [message #26351 is a reply to message #24455] Mon, 07 February 2005 10:58 Go to previous message
Massimiliano wrote:
> Hi.
Thanks for the advice, I works well now with 3.1M4 installed!
Previous Topic:Code Assist
Next Topic:Java newbie requesting advice
Current Time: Sat Jul 26 09:54:48 EDT 2025
Powered by FUDForum. Page generated in 0.08269 seconds
