Home » Archived » BIRT » Setting relative url for images
Setting relative url for images [message #247644] Thu, 12 July 2007 12:10 Go to next message
Originally posted by: weisswieschwarz.gmx.net
I set up the Servlet Example to use the RE API.
It works quite well, but the Charts only get displayed with IE.
I think Firefox has a problem with displaying the absolute URLs of the
Chart-Images. (It gets displayed correctly when I change the urls manually)
I tried to set a relative url by using:
renderContext.setBaseImageURL("/images");
but this didn't work.
(In the HTML-Source there's still an absolute URL)
How can I get an HTML output with a relative url for my images?
Thanks a lot
Karin
Re: Setting relative url for images [message #247659 is a reply to message #247644] Thu, 12 July 2007 12:56 Go to previous message
Karin,
If you are using BIRT 2.2 try the following:
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat("html");
options.setImageHandler(new HTMLServerImageHandler());
options.setImageDirectory(sc.getRealPath("/images"));
options.setBaseImageURL(req.getContextPath()+"/images");
options.setOutputStream(resp.getOutputStream());
task.setRenderOption(options);
The key is to use the HTMLServerImageHandler class;
Jason
Karin wrote:
> Hello,
> Thanks a lot
> Karin
Previous Topic:Example on Crosstab
Next Topic:Unable to set y-axis scale dynamically - Please help
Current Time: Fri Oct 31 09:24:49 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
