Home » Eclipse Projects » GEF » Confused with Policies
Confused with Policies [message #247609] Wed, 04 March 2009 11:17 Go to next message
Originally posted by: bruno.pereira.alert.pt
I'm developing my first application using GEF, as expected I'm still green
about the subject.
I'm starting to implement a LayoutPolicy for re-ordering the childs of a
AbstractGraphicalEditPart. I extend the XYLayoutEditPolicy and override the
method getMoveChildrenCommand... the problems started here:
1 - I can easily know the "parent" EditPart thanks to the getHost, but
what about the currently selected EditPart?
I "solve" this getting the childs of the parent and check witch
one was getSelected() == AbstractGraphicalEditPart.SELECTED_PRIMARY. Is this
the best way? Shouldn't the request retrieve the EditPart i'm currently
moving?
2 - When I drop the Figure I'm dragging on top of other Figure (with the
same parent) I want to move the first Figure to the place of the second and
shift the position of the others. Theres any way of knowing the
Figure/EditPart located where i drop the Figure i was dragging, without
checking for every Figure if the area occupied contains the point where I
drop the Figure (currently I'm doing this :\)?
3 - My EditPart, that has installed the MyXYLayoutEditPolicy, can have
as child other EditParts that also has installed a XYLayoutEditPolicy. When
I drag a Figure and position it over its brother, if that brother had a
XYLayoutEditPolicy installed the frameworks think I want to add the dragged
Figure to the EditPart of his brother. Start firing the
getAddCommand(Request generic), the thing is that I might want to just
re-order the "brothers" or I might really want to add the first one inside
the last one. It's possible to detect, when the getAddCommand is firing, if
the user as the CTRL pressed? And have different behavior if it is pressed
or not? If it's possible the next question is how?
Any tips are welcome.
Bruno Pereira
Re: Confused with Policies [message #247630 is a reply to message #247609] Thu, 05 March 2009 05:37 Go to previous message
Forget the fist doubt, found the answer after digging the API a little more:
ChangeBoundsRequest request = (ChangeBoundsRequest)generic;
List editParts = request.getEditParts();
Bruno Pereira
"Bruno Pereira" <bruno.pereira@alert.pt> wrote in message
news:gom9im$sui$1@build.eclipse.org...
> Hello,
> about the subject.
> the method getMoveChildrenCommand... the problems started here:
> this the best way? Shouldn't the request retrieve the EditPart i'm
> currently moving?
> the same parent) I want to move the first Figure to the place of the
> second and shift the position of the others. Theres any way of knowing the
> When I drag a Figure and position it over its brother, if that brother had
> a XYLayoutEditPolicy installed the frameworks think I want to add the
> dragged Figure to the EditPart of his brother. Start firing the
> if the user as the CTRL pressed? And have different behavior if it is
> pressed or not? If it's possible the next question is how?
> Bruno Pereira
Previous Topic:Questions about ConnectionAnchors
Next Topic:Changing edit policies
Current Time: Sat Jul 26 13:16:16 EDT 2025
Powered by FUDForum. Page generated in 0.06689 seconds
