| BIRT Runtime -Report Engine 2.2 Error [message #247551] |
Thu, 12 July 2007 03:37  |
Originally posted by: hijaysh.gmail.com
I have been using BIRT Runtime 2.1.2 for my web appln and currently
migrating to 2.2.
In my web app, I have included all the jars from
birt-runtime-2_2_0\ReportEngine\lib to my proj library and also used the
latest plugins and configuration folders in my webapp's WEB-INF/platform.
But while running the report from my web app, i get the standard
exception: "Unhandled exception when executing script".
The same report runs in the latest Eclipse (3.3) with BIRT 2_2_0 though!!
Is there any thing else that needs to be configured for 2_2_0 runtime
engine?!
Also, I notice that HTMLRenderContext and PDFRenderContext are deprecated
in the latest(2.2.0) release! Does that imply that there is some other api
by which we can generate HTML and PDF reports using runtime BIRT engine.
Please do let me know.
Thanks in Advance.
| Re: BIRT Runtime -Report Engine 2.2 Error [message #247743 is a reply to message #247606] |
Thu, 12 July 2007 21:34   |
Hi Jason
PF below the full error.
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "reportClass = new
Packages.sconce.pdmrep.dal.generics.ScriptCall();
vect = reportClass.getUsers();
totalrows= vect.size() ;
currentrow=0 ;":{1}.
Error.ScriptEvaluationError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
Packages.sconce.pdmrep.dal.generics.ScriptCall();vect =
reportClass.getUsers();totalrows= vect.size() ;currentrow=0 ;":{1}. at
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:77)
org.eclipse.birt.report.engine.script.internal.DataSetScript Executor.handleJS(DataSetScriptExecutor.java:159)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:6 6)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:79)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:244)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :220)
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:761)
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:216)
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:152)
org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:83)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:155)
org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:115)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:178)
org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1678)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:82)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:61)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 5)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:42)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:33)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:126)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:148)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
pdmreport.reportGeneration.ReportGeneration.generateReportBu tton_action(ReportGeneration.java:1421)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
at java.lang.reflect.Method.invoke(Method.java:585) at
com.sun.faces.el.MethodBindingImpl.invoke(MethodBindingImpl. java:146) at
com.sun.faces.application.ActionListenerImpl.processAction(A ctionListenerImpl.java:92)
com.sun.rave.web.ui.appbase.faces.ActionListenerImpl.process Action(ActionListenerImpl.java:57)
at javax.faces.component.UICommand.broadcast(UICommand.java:332 ) at
javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot. java:287) at
javax.faces.component.UIViewRoot.processApplication(UIViewRo ot.java:401)
com.sun.faces.lifecycle.InvokeApplicationPhase.execute(Invok eApplicationPhase.java:95)
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:245) at
com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl. java:110) at
javax.faces.webapp.FacesServlet.service(FacesServlet.java:21 3) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:173)
at com.sun.rave.web.ui.util.UploadFilter.doFilter(UploadFilter. java:198)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:202)
at pdmreport.SessionCheckFilter.doFilter(SessionCheckFilter.jav a:45) at
org.netbeans.modules.web.monitor.server.MonitorFilter.doFilt er(MonitorFilter.java:368)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:178)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:869)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:664)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:527)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:80)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:684)
at java.lang.Thread.run(Thread.java:595)Caused by:
org.eclipse.birt.data.engine.core.DataException: A BIRT exception
occurred: Error evaluating Javascript expression. Script engine error:
TypeError: [JavaPackage sconce.pdmrep.dal.generics.ScriptCall] is not a
function. (DataSet[Data Set].__bm_OPEN#2) Script source: DataSet[Data
Set].__bm_OPEN, line: 1, text:__bm_OPEN(). See next exception for more
information.Error evaluating Javascript expression. Script engine error:
Set].__bm_OPEN, line: 1, text:__bm_OPEN() at
org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:582)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:79)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)
... 62 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
evaluating Javascript expression. Script engine error: TypeError:
[JavaPackage sconce.pdmrep.dal.generics.ScriptCall] is not a function.
org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoExc eption(JavascriptEvalUtil.java:281)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:105)
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScri pt(JavascriptEvalUtil.java:137)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:578)
... 64 moreCaused by: org.mozilla.javascript.EcmaError: TypeError:
(DataSet[Data Set].__bm_OPEN#2) at
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
org.mozilla.javascript.ScriptRuntime.typeError1(ScriptRuntim e.java:3258)
org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3317)
org.mozilla.javascript.ScriptRuntime.notFunctionError(Script Runtime.java:3308)
at org.mozilla.javascript.ScriptRuntime.newObject(ScriptRuntime .java:2057)
at org.mozilla.javascript.gen.c6._c1(DataSet[Data Set].__bm_OPEN:2) at
org.mozilla.javascript.gen.c6.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.optimizer.OptRuntime.callName0(OptRun time.java:105)
at org.mozilla.javascript.gen.c7._c0(DataSet[Data Set].__bm_OPEN:1) at
org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
at org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.gen.c7.exec(DataSet[Data Set].__bm_OPEN) at
org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawS cript(JavascriptEvalUtil.java:98)
... 66 more
+ There are errors evaluating script "if (totalrows>currentrow)
var obj = vect.get(currentrow);
var name = obj[0];
var email = obj[1];
var telephone = obj[2];
var org = obj[3];
var fax = obj[4];
var web = obj[5];
var add = obj[6];
row["Name"]=name;
row["Email"]=email;
row["Phone"]=telephone;
row["Organization"]=org;
row["Fax"]=fax;
row["Address"]=add;
row["Website"]=web;
currentrow=currentrow+1;
return ( true );
return ( false );":{1}.
errors evaluating script "if (totalrows>currentrow){ var obj =
vect.get(currentrow); var name = obj[0]; var email = obj[1]; var
telephone = obj[2]; var org = obj[3]; var fax = obj[4]; var web = obj[5];
var add = obj[6]; row["Name"]=name; row["Email"]=email;
row["Phone"]=telephone; row["Organization"]=org; row["Fax"]=fax;
row["Address"]=add; row["Website"]=web; currentrow=currentrow+1; return
( true );} return ( false );":{1}. at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 100)
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:102)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:257)
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:150)
org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:91)
org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:62)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:268)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:241)
org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:204)
org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:68)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:113)
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:66)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePass(PassManager.java:185)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:90)
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:72)
org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:208)
org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:132)
org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:106)
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223)
ReferenceError: "totalrows" is not defined. (DataSet[Data
Set].__bm_FETCH#2) Script source: DataSet[Data Set].__bm_FETCH, line: 1,
text:__bm_FETCH(). See next exception for more information.Error
evaluating Javascript expression. Script engine error: ReferenceError:
"totalrows" is not defined. (DataSet[Data Set].__bm_FETCH#2) Script
source: DataSet[Data Set].__bm_FETCH, line: 1, text:__bm_FETCH() at
... 77 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 79 moreCaused by: org.mozilla.javascript.EcmaError: ReferenceError:
"totalrows" is not defined. (DataSet[Data Set].__bm_FETCH#2) at
org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3303)
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1632)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1571) at
org.mozilla.javascript.gen.c8._c1(DataSet[Data Set].__bm_FETCH:2) at
org.mozilla.javascript.gen.c8.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c9._c0(DataSet[Data Set].__bm_FETCH:1) at
org.mozilla.javascript.gen.c9.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c9.call(DataSet[Data Set].__bm_FETCH) at
org.mozilla.javascript.gen.c9.exec(DataSet[Data Set].__bm_FETCH) at
... 81 more
- Unhandled exception when executing script
Error.UnhandledScriptError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Unhandled
exception when executing script at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:141)
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:131)
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 119)
data.engine.BadFetchScriptReturnType at
org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 109)
... 75 more
| Re: BIRT Runtime -Report Engine 2.2 Error [message #247771 is a reply to message #247606] |
Fri, 13 July 2007 03:53   |
Hi Jason,
The exception shows a reference error for 'totalrows' a variable that i
have used in the script.
Actual Exception:
vect = reportClass.getSample();
totalrows= vect.size();
reportClass.getSample();totalrows= vect.size();currentrow=0 ;":{1}. at
at test.Page1.button1_action(Page1.java:272) at
... 59 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 61 moreCaused by: org.mozilla.javascript.EcmaError: TypeError:
at org.mozilla.javascript.gen.c4._c1(DataSet[Data Set].__bm_OPEN:2) at
org.mozilla.javascript.gen.c4.call(DataSet[Data Set].__bm_OPEN) at
at org.mozilla.javascript.gen.c5._c0(DataSet[Data Set].__bm_OPEN:1) at
org.mozilla.javascript.gen.c5.call(DataSet[Data Set].__bm_OPEN) at
at org.mozilla.javascript.gen.c5.call(DataSet[Data Set].__bm_OPEN) at
org.mozilla.javascript.gen.c5.exec(DataSet[Data Set].__bm_OPEN) at
... 63 more
- There are errors evaluating script "if (totalrows>currentrow)
var one = obj[0];
var two = obj[1];
row["one"]=one;
row["two"]=two;
return ( true );
vect.get(currentrow); var one = obj[0]; var two = obj[1];
row["one"]=one; row["two"]=two; currentrow=currentrow+1; return ( true
... 74 moreCaused by: org.eclipse.birt.core.exception.CoreException: Error
... 76 moreCaused by: org.mozilla.javascript.EcmaError: ReferenceError:
org.mozilla.javascript.gen.c6._c1(DataSet[Data Set].__bm_FETCH:2) at
org.mozilla.javascript.gen.c6.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c7._c0(DataSet[Data Set].__bm_FETCH:1) at
org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_FETCH) at
at org.mozilla.javascript.gen.c7.call(DataSet[Data Set].__bm_FETCH) at
org.mozilla.javascript.gen.c7.exec(DataSet[Data Set].__bm_FETCH) at
... 78 more
... 72 more
| Re: BIRT Runtime -Report Engine 2.2 Error [message #247792 is a reply to message #247771] |
Fri, 13 July 2007 10:45   |
Jayashree,
Where is this class located sconce.pdmrep.dal.generics.ScriptCall?
Also can you post your scripts for the open and fetch methods?
Jason
Jayashree wrote:
> Hi Jason,
> Actual Exception:
> ReportDesign (id = 1): + There are errors evaluating script "reportClass
> = new Packages.sconce.pdmrep.dal.generics.ScriptCall();
> currentrow=0 ;":{1}. Error.ScriptEvaluationError ( 1 time(s) )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl. java:110)
> at javax.faces.webapp.FacesServlet.service(FacesServlet.java:21 3) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Error evaluating Javascript expression. Script engine error: TypeError:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 63 more
> var one = obj[0];
> var two = obj[1];
> row["one"]=one;
> row["two"]=two;
> return ( true );
> return ( false );":{1}. Error.ScriptEvaluationError ( 1 time(s) )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 78 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> .. 72 more
| Re: BIRT Runtime -Report Engine 2.2 Error [message #247982 is a reply to message #247792] |
Mon, 16 July 2007 03:18  |
Hi Jason,
I was able to resolve the error by using the code below which i noticed
from an earlier post about similar exception.
runAndRenderTask.getAppContext().put(EngineConstants.APPCONT EXT_CLASSLOADER_KEY,
ReportEngineService.class.getClassLoader());
Aneways,thanks for your help :)!
Jayashree
FUDForum. Page generated in 0.06111 seconds
