| IncompatibleClassChangeError with 2.2.0 [message #247542] |
Thu, 12 July 2007 02:55   |
Eclipse User  |
I migrated my system to 2.2.0. To generate the reports I'm using the BIRT
Runtime.
My first test ends with an exception:
Caused by: org.eclipse.birt.report.engine.api.EngineException: Error
happened while running the report
 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:178)
 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
 de.guidecom.birt.reporting.impl.BIRTRunAndRenderTaskImpl.run AndRenderTask(BIRTRunAndRenderTaskImpl.java:133)
 de.guidecom.kgiplus3.web.handler.impl.AbstractHandlerImpl.cr eateReport(AbstractHandlerImpl.java:463)
	... 28 more
Caused by: java.lang.IncompatibleClassChangeError
 org.eclipse.birt.report.engine.css.engine.CSSEngine.parsePro pertyValue(CSSEngine.java:114)
 org.eclipse.birt.report.engine.css.dom.AbstractStyle.setCssT ext(AbstractStyle.java:193)
 org.eclipse.birt.report.engine.parser.EngineIRVisitor.addRep ortDefaultPropertyValue(EngineIRVisitor.java:2310)
 org.eclipse.birt.report.engine.parser.EngineIRVisitor.addRep ortDefaultPropertyValue(EngineIRVisitor.java:2276)
 org.eclipse.birt.report.engine.parser.EngineIRVisitor.create ReportDefaultStyles(EngineIRVisitor.java:2329)
 org.eclipse.birt.report.engine.parser.EngineIRVisitor.visitR eportDesign(EngineIRVisitor.java:266)
 org.eclipse.birt.report.model.api.DesignVisitor$Forwarder.vi sitReportDesign(DesignVisitor.java:1175)
 org.eclipse.birt.report.model.elements.ReportDesign.apply(Re portDesign.java:89)
 org.eclipse.birt.report.model.api.DesignVisitor.apply(Design Visitor.java:123)
 org.eclipse.birt.report.engine.parser.EngineIRVisitor.transl ate(EngineIRVisitor.java:237)
 org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:177)
 org.eclipse.birt.report.engine.api.impl.ReportRunnable.getRe portIR(ReportRunnable.java:199)
 org.eclipse.birt.report.engine.executor.ExecutionContext.get Report(ExecutionContext.java:694)
 org.eclipse.birt.report.engine.executor.ReportExecutor.(Repo rtExecutor.java:78)
 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:96)
In CSSEngine.java classes from sac are used. But I don't why such an
exception occures.
Can anyone help me?
Daniel
FUDForum. Page generated in 0.06976 seconds
