Home » Eclipse Projects » Eclipse Platform » java.util.Properties in to a IFile??
java.util.Properties in to a IFile?? [message #247498] Mon, 31 May 2004 06:49 Go to next message
Originally posted by: purjo76.luukku.com
Hi!
How do i save a content of a Properties class in to a EclipseŽs IFile
instance?? In Properties there are store() and load() methods, but how do
set the file where to store to be an IFile??
Re: java.util.Properties in to a IFile?? [message #247512 is a reply to message #247498] Mon, 31 May 2004 07:14 Go to previous message
I think it is not the best way.....but it is a way.
Create a class StringBufferOutputStream like the class which i append in the footer.
Implement the doSave(...) method in your Editor.
* Saves editor's document.
public void doSave(IProgressMonitor monitor)
try
// your properties to save!!!!
Properties props =new Properties();
// stream the properties into a buffer
StringBufferOutputStream out=new StringBufferOutputStream();
props.save(out);
// use the created buffer as inputStream for the IFile.setContents method.
StringBufferInputStream inputStream=new StringBufferInputStream(out.toString());
((IFileEditorInput)getEditorInput()).getFile().setContents(i nputStream,true,false,monitor);
// mark the file as saved
getCommandStack().markSaveLocation();
catch (Exception e)
// TODO: do the error handling...
e.printStackTrace();
Greetings
Andreas
P.S. A better solutions are welcome ;-)
public class StringBufferOutputStream extends OutputStream implements Serializable
protected StringBuffer buf;
public StringBufferOutputStream(StringBuffer sb)
buf = sb;
public StringBufferOutputStream(int defaultBufferSize)
buf = new StringBuffer(defaultBufferSize);
public void close()
buf = null;
public void write(byte abyte0[])
buf.append(toCharArray(abyte0));
public void write(byte abyte0[], int i, int j)
if (i < 0 || j < 0 || i + j > abyte0.length)
throw new IndexOutOfBoundsException("Parameters out of bounds.");
byte abyte1[] = new byte[j];
for (int k = 0; k < j; k++)
abyte1[k] = abyte0[i];
i++;
buf.append(toCharArray(abyte1));
public void write(int i)
buf.append((char) i);
private static char[] toCharArray(byte abyte0[])
if (abyte0 == null)
return null;
char ac[] = new char[abyte0.length];
for (int i = 0; i < abyte0.length; i++)
ac[i] = (char) abyte0[i];
return ac;
public String toString()
return buf.toString();
Previous Topic:Illegal Thread Access
Next Topic:Form&Source Editor
Current Time: Sat Nov 08 09:57:56 EST 2025
Powered by FUDForum. Page generated in 0.03440 seconds
