Home » Archived » BIRT » Example on Crosstab
Example on Crosstab [message #247483] Wed, 11 July 2007 19:13 Go to next message
I am looking for an example that shows how to create table columns
dynamically. Can someone please point me to a good example.
Thanks.
Re: Example on Crosstab [message #247488 is a reply to message #247483] Wed, 11 July 2007 20:21 Go to previous messageGo to next message
Hi Nisha
You can find the example of crosstab:
http://wiki.eclipse.org/Cross_Table_Revenue_By_Product_%28BI RT%29
The example of crosstab report design:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190895
1, you should create a dataset.
2, create a cube with the dataset. In cube builder, you should create at
least one dimension and one measure.
3, drag a crosstab into layout
4, drag a dimension from cube(in data explorer) into crosstab's row area
or column area
5, drag the measure from cube into crosstab's detail area
6, preview
I hope this simple steps can help you create a simple crosstab, after that
you can be more familiar with the useage crosstab and create more complex
crosstab as you want.
Welcome to ask if any troubles.
Good luck!
Re: Example on Crosstab [message #247629 is a reply to message #247488] Thu, 12 July 2007 11:43 Go to previous message
Thanks a lot for your response and help.
Nisha
Previous Topic:Question on group header
Next Topic:Setting relative url for images
Current Time: Sat Jul 26 09:55:19 EDT 2025
Powered by FUDForum. Page generated in 0.07016 seconds
