Home » Eclipse Projects » Eclipse Platform » Disable back button in wizard
Disable back button in wizard [message #247451] Mon, 31 May 2004 04:42 Go to next message
Originally posted by: titi-r5.bluewin.ch
Hi all !
Is it possible to disable the back button on a wizar page ? There is a
canFlipToNextPage method but no canFlipToPreviosPage in WizardPage
class. Is there a mean to work around this ?
Thank you in advance...
Thierry
Re: Disable back button in wizard [message #247465 is a reply to message #247451] Mon, 31 May 2004 05:13 Go to previous messageGo to next message
Please don't do this. It should always be possible to go a step back in
dialog based workflows. Otherwise the user would have to use "cancel" to
correct some of his input on former pages. From the ergonomic point of
view that would be a really bad design for the user interface.
Ciao, Michael.
Re: Disable back button in wizard [message #247830 is a reply to message #247465] Tue, 01 June 2004 05:18 Go to previous message
I see your point. Anyway if someone is interested to do it nevertheless,
you just have to override getPreviousPage and make it return null...
> Ciao, Michael.
Thank you for your answer !
Thierry
Previous Topic:Open view in a desired folder
Next Topic:Problem with Fixed Views (see Bug 49811)
Current Time: Fri Jul 25 10:23:25 EDT 2025
Powered by FUDForum. Page generated in 0.08651 seconds
