Home » Newcomers » Newcomers » The jar file cannot be exported into itself
The jar file cannot be exported into itself [message #247432] Fri, 01 February 2008 12:53 Go to next message
Originally posted by: dgresh.mail.rochester.edu
When I go to overwrite a JAR file with the JAR export wizard I get the
error "The jar file cannot be exported into itself" unless I first delete
the old jar. Is there some way to avoid this, just as a matter of
convenience?
Dan
Re: The jar file cannot be exported into itself [message #247444 is a reply to message #247432] Fri, 01 February 2008 14:11 Go to previous messageGo to next message
Dan wrote:
> delete the old jar. Is there some way to avoid this, just as a matter of
> convenience?
What I think this means is that the JAR that you are exporting to is
included in the files you have selected to export. This can happen if
you choose as the destination for your JAR the project that you are
exporting.
Hope this helps,
Eric
Re: The jar file cannot be exported into itself [message #247454 is a reply to message #247444] Fri, 01 February 2008 14:44 Go to previous messageGo to next message
> exporting.
> Hope this helps,
> Eric
This is exactly the problem. I moved the jar destination outside of the
project, and it works fine.
Thank you very much,
Dan
Re: The jar file cannot be exported into itself [message #247617 is a reply to message #247454] Mon, 04 February 2008 06:55 Go to previous messageGo to next message
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig4817417286A0797C482CB82B
Content-Type: text/plain; charset=UTF-8; format=flowed
Dan schreef:
> Eric Rizzo wrote:
>=20
>> Dan wrote:
>=20
>> What I think this means is that the JAR that you are exporting to is=20
>> included in the files you have selected to export. This can happen if =
>> you choose as the destination for your JAR the project that you are=20
>> exporting.
>=20
>> Hope this helps,
>> Eric
>=20
> This is exactly the problem. I moved the jar destination outside of the=
=20
No need for that if you unselect the jar file itself in the jar packager.=
H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.4-svn0 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iD8DBQFHpv0Ze+7xMGD3itQRAgRrAJ9QyTwBmsjTZ4DnoN1bZKwuO8nvTACc CUmT
OMnRlhpq3U1DNzuOw30PTn8=
=6o3H
-----END PGP SIGNATURE-----
--------------enig4817417286A0797C482CB82B--
icon5.gif  Re: The jar file cannot be exported into itself [message #755008 is a reply to message #247617] Sun, 06 November 2011 12:37 Go to previous messageGo to next message
Hendrik
What do you mean by the "jar packager"?
Picking through Eclipse menus I have not run into anything like that.
Re: The jar file cannot be exported into itself [message #755028 is a reply to message #755008] Sun, 06 November 2011 22:04 Go to previous message
On 2011.11.06 10:37, pete dudley wrote:
> Hendrik
Creating a JAR is done via File -> Export -> Java -> JAR file.
Previous Topic:ClassCastException:java.util.ArrayList cannot be cast to
Next Topic:Derby "startnetworkserver.bat"
Current Time: Sat Nov 08 19:00:18 EST 2025
Powered by FUDForum. Page generated in 0.06838 seconds
