Home » Eclipse Projects » GEF » How to find the bound of the parent Figure
| How to find the bound of the parent Figure [message #24318] |
Sun, 06 October 2002 15:54  |
I have a Figure class which extends the Shape class, it needs to draw a
straight hort. line across its container (parent). First it needs to figure
out how wide is it parent, and then it the paint() method, it just draw a
hort line.
My question is how can a Figure find out its container's class? I call
getParentingFigure() method but it returns null.
And I try to call the getParent() method in its EditPart, it returns null
also.
Any help is appreciated.
| Re: How to find the bound of the parent Figure [message #25202 is a reply to message #24869] |
Mon, 07 October 2002 19:23   |
Thanks. In my SeparatorFigure class, I get the width of it parents by
calling the getBounds() method, but
it always gives me r.width= 64 and r.height=36 and these values are wrong. I
set the parent's size to be width = 100, and height = 100.
It stays the same evern if I manually resize the parent.
Could you please tell me how to draw the separator to the parent figure?
Thanks for you help.
protected void fillShape(Graphics graphics) {
Rectangle r = new Rectangle(getBounds());
System.out.println ("r.width" + r.width + "r.height" + r.height);
"Hal" <otaconss2@hotmail.com> wrote in message
news:ans470$ljq$1@rogue.oti.com...
> Yes. Is there something like that in GEF already? Or I need to do it
myself
> like I said? But if a child figure can only paint within its own bounds, I
> need to find out how LONG it should draw, (in other words, the width of it
> parent) right?
> Thanks for your help.
> "Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
> news:anql3r$u2h$1@rogue.oti.com...
> > A child figure can only paint within its own bounds. This is unsured by
> > clipping the Graphics to that region. What are you trying to do?
Create
> a
> > "separator"?
> > news:anq32r$nu6$1@rogue.oti.com...
a
> > figure
draw
> a
> > > hort line.
> null
> > > also.
| Re: How to find the bound of the parent Figure [message #26570 is a reply to message #25284] |
Wed, 09 October 2002 10:57   |
Randy,
Thanks for the example. But how I apply that to Logic Editor Example?
Each figure is create by the EditPart (e.g. CircuitEditPart creates
CircuitFigure, AndGateEditPart creates AndGateFigure).
And the parentFigure does not explicitly add its childFigure
(CircuitEditPart never adds AndFigure, it is just Circuit adds AndGate, and
in your example, you need add the childFigure (SeparateFigure) to the
parentFigure (umlType). So how can I apply your example to application using
MVC patterns (e.g. Logic Editor Example)
Thanks for your help again.
news:anta0f$d5r$1@rogue.oti.com...
> myself
I
it
> > parent) right?
> You can just use a regular Figure. Here is an example:
> import org.eclipse.draw2d.*;
> import org.eclipse.swt.layout.FillLayout;
> import org.eclipse.swt.widgets.Display;
> import org.eclipse.swt.widgets.Shell;
> public class SeparatorExample {
> public static void main(String[] args) {
> Display d = new Display();
> Shell shell = new Shell(d);
> shell.setText("Separator example");
> shell.setLayout(new FillLayout());
> FigureCanvas canvas = new FigureCanvas(shell);
> Figure umlType = new Figure();
> ToolbarLayout layout = new ToolbarLayout();
> layout.setSpacing(3);
> //method below was recently renamed from setMatchWidth()
> layout.setStretchMinorAxis(true);
> umlType.setLayoutManager(layout);
> Label typeName = new Label("Image");
> umlType.add(typeName);
> Figure separator = new Figure();
> separator.setPreferredSize(1,1);
> separator.setBackgroundColor(ColorConstants.black);
> separator.setOpaque(true);
> umlType.add(separator);
> Label attrName = new Label(" + handle : int");
> attrName.setLabelAlignment(Label.LEFT);
> umlType.add(attrName);
> Label attrPal = new Label(" + palette : PaletteData");
> attrPal.setLabelAlignment(Label.LEFT);
> umlType.add(attrPal);
> canvas.setContents(umlType);
> shell.setSize(300,260);
> shell.open();
> while (!shell.isDisposed())
> while (!d.readAndDispatch())
> d.sleep();
| Re: How to find the bound of the parent Figure [message #26734 is a reply to message #26570] |
Wed, 09 October 2002 15:32   |
Originally posted by: hudsonr.us.eye-bee-em.com
> Randy,
and
using
What are you trying to do? Draw a separator between every child in a
container?
One way to do that is to make the entire container black, and the children
are all white or whatever color you want for the normal background. Then,
use some layout with a gap set to 1 or more pixels, so the black part is
exposed between children.
> > myself
bounds,
> I
of
> it
> > > parent) right?
> > shell.open();
> > d.sleep();
| Re: How to find the bound of the parent Figure [message #26813 is a reply to message #26734] |
Wed, 09 October 2002 16:00   |
Randy,
I am trying to draw a Hortizontal line across each Circuit Figure in the
Logic Editor Example. When you resize Circuit Figure, the hortizontal line
will get either (longer/shorter) depending on the size of teh Circuit
Figure.
news:ao1us1$7gu$1@rogue.oti.com...
> > Randy,
> and
> using
> container?
> > > myself
> bounds,
> > I
> of
> > it
> > > > parent) right?
> > > shell.open();
> > > d.sleep();
| Re: How to find the bound of the parent Figure [message #27014 is a reply to message #26813] |
Wed, 09 October 2002 18:24  |
To be more specify, I wan to draw a Hortizontal line 5 pixels from the top
of the Circuit Figure and it always touches the left & right side of the
Circuit Figure.
news:ao20g9$8hr$1@rogue.oti.com...
> Randy,
> Figure.
> > > Randy,
AndGate,
> > and
> > using
> > container?
children
Then,
it
> > > > myself
> > bounds,
> > > I
width
> > of
> > > it
> > > > > parent) right?
> > > > shell.open();
> > > > d.sleep();
Current Time: Fri Nov 07 11:00:18 EST 2025
Powered by FUDForum. Page generated in 0.05469 seconds
