Home » Archived » Riena » Getting sendig host when using client monitoring
Getting sendig host when using client monitoring [message #24316] Tue, 07 April 2009 03:57 Go to next message
is it possible to get the hostname of the sending client in my
IReceiver-implementation?
I am using
org.eclipse.riena.monitor.client.SimpleSender as sender,
org.eclipse.riena.monitor.client.SimpleStore as store and
org.eclipse.riena.monitor.client.LogServiceCollector as collector?
Or do I have to create my own implementation of one of these to get this
information?
Greetz and Thanks!
Carsten
Re: Getting sendig host when using client monitoring [message #24358 is a reply to message #24316] Tue, 07 April 2009 10:25 Go to previous messageGo to next message
Hi Carsten,
Carsten Spieker wrote:
Well, not out of the box! At least not yet ;-)
> I am using
> information?
You could probably sub-class LogServiceCollector and implement there the
collect( T payload) method, such that you create another Serializable
containing the hostname and the original payload and pass this to
super.collect()
However, this seems to me reasonable use case. I would suggest that you
create a bugzilla for that and we can continue discussing there.
Tschüß,
Stefan
> Greetz and Thanks!
> Carsten
Re: Getting sendig host when using client monitoring [message #24399 is a reply to message #24358] Wed, 08 April 2009 01:48 Go to previous messageGo to next message
Hi Stefan,
thanks for your reply.
I added Bug 271556.
Tsch
Re: Getting sendig host when using client monitoring [message #24440 is a reply to message #24358] Wed, 08 April 2009 03:40 Go to previous messageGo to next message
Hi Stefan,
unfortunately your suggestion does not seem to work, or I
Re: Getting sendig host when using client monitoring [message #24481 is a reply to message #24440] Wed, 08 April 2009 04:54 Go to previous messageGo to next message
Hi Carsten,
I guess this happens when the store tries to deserialize the
collectibles from disk, right?
Does ´patching´ the manifest.mf with "Eclipse-BuddyPolicy" solve the issue?
Tschüß,
Stefan
> Hi Stefan,
> unfortunately your suggestion does not seem to work, or I´m still doing
> something wrong.
> What I did:
> - Extending LogServiceCollector and overwriting the collect(*)-method.
> - Implementing an Serializable-Object which contains hostname and the
> original LogEventTransferObject
> - calling super.collect(myOwnSerializable)
> What goes wrong:
> - When SimpleSender asks the SimpleStore for the Collectibles which are to
> transfer, the SimpleStore cannot found the class of my Serializable-object.
> - I tried to set a "Eclipse-RegisterBuddy: org.eclipse.riena.monitor.client"
> entry in my Manifest.MF but unfortunately org.eclipse.riena.monitor.client
> does not set an accordant "Eclipse-BuddyPolicy".
> Effect:
> - The Receiver does not receive my Serializable-object but only the original
> LogEntryTranferObject and I´m as far as before.
> Have I done something wrong here?
> Greetz,
> Carsten
> "Stefan Liebig" <Stefan.Liebig@compeople.de> schrieb im Newsbeitrag
> news:grfno1$bho$1@build.eclipse.org...
>> Hi Carsten,
>>> Hi,
>>> I am using
>>> information?
>> super.collect()
>> Tschüß,
>> Stefan
>>> Greetz and Thanks!
>>> Carsten
Re: Getting sendig host when using client monitoring [message #24522 is a reply to message #24481] Wed, 08 April 2009 05:59 Go to previous messageGo to next message
Hi Stefan,
yes patching the manifest.mf solves it. Can this be treated as a bug, so
that I can enter a bug report? Or does it make no sense for you to add the
BuddyPolicy to this bundle in general?
Tsch
Re: Getting sendig host when using client monitoring [message #24563 is a reply to message #24522] Wed, 08 April 2009 07:08 Go to previous messageGo to next message
Hi Carsten,
Yes, I think it is a bug. So a bug report would be fine.
Thanks and Tschüß,
Stefan
> Hi Stefan,
> Tschüss,
> Carsten
> news:grhoom$8k9$1@build.eclipse.org...
>> Hi Carsten,
>> I guess this happens when the store tries to deserialize the collectibles
>> from disk, right?
>> issue?
>> Tschüß,
>> Stefan
>>> Hi Stefan,
>>> something wrong.
>>> What I did:
>>> What goes wrong:
>>> to transfer, the SimpleStore cannot found the class of my
>>> org.eclipse.riena.monitor.client" entry in my Manifest.MF but
>>> unfortunately org.eclipse.riena.monitor.client does not set an accordant
>>> Effect:
>>> original LogEntryTranferObject and I´m as far as before.
>>> Greetz,
>>> Carsten
>>>> Hi Carsten,
>>>>> Hi,
>>>>> I am using
>>>>> this information?
>>>> super.collect()
>>>> Tschüß,
>>>> Stefan
>>>>> Greetz and Thanks!
>>>>> Carsten
Re: Getting sendig host when using client monitoring [message #24605 is a reply to message #24563] Wed, 08 April 2009 07:53 Go to previous messageGo to next message
bug 271607 added.
Greetz,
Carsten
news:gri0j7$b42$1@build.eclipse.org...
> Hi Carsten,
> Thanks and Tsch
Re: Getting sendig host when using client monitoring [message #24645 is a reply to message #24605] Tue, 14 April 2009 04:18 Go to previous message
The bug has been resolved and you can read about the solution here:
http://wiki.eclipse.org/Riena_Getting_Started_with_Client_Mo nitoring#Client_information_provider
Tschüß,
Stefan
> bug 271607 added.
> Greetz,
> Carsten
>> Hi Carsten,
>> Thanks and Tschüß,
>> Stefan
>>> Hi Stefan,
>>> the BuddyPolicy to this bundle in general?
>>> Tschüss,
>>> Carsten
>>>> Hi Carsten,
>>>> issue?
>>>> Tschüß,
>>>> Stefan
>>>>> Hi Stefan,
>>>>> something wrong.
>>>>> What I did:
>>>>> What goes wrong:
>>>>> Effect:
>>>>> Greetz,
>>>>> Carsten
>>>>>> Hi Carsten,
>>>>>>> Hi,
>>>>>>> I am using
>>>>>>> this information?
>>>>>> the collect( T payload) method, such that you create another
>>>>>> Serializable containing the hostname and the original payload and pass
>>>>>> this to super.collect()
>>>>>> you create a bugzilla for that and we can continue discussing there.
>>>>>> Tschüß,
>>>>>> Stefan
>>>>>>> Greetz and Thanks!
>>>>>>> Carsten
Re: Getting sendig host when using client monitoring [message #581750 is a reply to message #24316] Tue, 07 April 2009 10:25 Go to previous message
Hi Carsten,
> I am using
> information?
super.collect()
Tschüß,
Stefan
> Greetz and Thanks!
> Carsten
Re: Getting sendig host when using client monitoring [message #581760 is a reply to message #24358] Wed, 08 April 2009 01:48 Go to previous message
Hi Stefan,
I added Bug 271556.
Tsch
Re: Getting sendig host when using client monitoring [message #581771 is a reply to message #24358] Wed, 08 April 2009 03:40 Go to previous message
Hi Stefan,
Re: Getting sendig host when using client monitoring [message #581796 is a reply to message #24440] Wed, 08 April 2009 04:54 Go to previous message
Hi Carsten,
Tschüß,
Stefan
> Hi Stefan,
> something wrong.
> What I did:
> What goes wrong:
> Effect:
> Greetz,
> Carsten
>> Hi Carsten,
>>> Hi,
>>> I am using
>>> information?
>> super.collect()
>> Tschüß,
>> Stefan
>>> Greetz and Thanks!
>>> Carsten
Re: Getting sendig host when using client monitoring [message #581807 is a reply to message #24481] Wed, 08 April 2009 05:59 Go to previous message
Hi Stefan,
Tsch
Re: Getting sendig host when using client monitoring [message #581822 is a reply to message #24522] Wed, 08 April 2009 07:08 Go to previous message
Hi Carsten,
Thanks and Tschüß,
Stefan
> Hi Stefan,
> Tschüss,
> Carsten
>> Hi Carsten,
>> from disk, right?
>> issue?
>> Tschüß,
>> Stefan
>>> Hi Stefan,
>>> something wrong.
>>> What I did:
>>> What goes wrong:
>>> Effect:
>>> Greetz,
>>> Carsten
>>>> Hi Carsten,
>>>>> Hi,
>>>>> I am using
>>>>> this information?
>>>> super.collect()
>>>> Tschüß,
>>>> Stefan
>>>>> Greetz and Thanks!
>>>>> Carsten
Re: Getting sendig host when using client monitoring [message #581840 is a reply to message #24563] Wed, 08 April 2009 07:53 Go to previous message
bug 271607 added.
Greetz,
Carsten
> Hi Carsten,
> Thanks and Tsch
Re: Getting sendig host when using client monitoring [message #581856 is a reply to message #24605] Tue, 14 April 2009 04:18 Go to previous message
Tschüß,
Stefan
> bug 271607 added.
> Greetz,
> Carsten
>> Hi Carsten,
>> Thanks and Tschüß,
>> Stefan
>>> Hi Stefan,
>>> Tschüss,
>>> Carsten
>>>> Hi Carsten,
>>>> issue?
>>>> Tschüß,
>>>> Stefan
>>>>> Hi Stefan,
>>>>> something wrong.
>>>>> What I did:
>>>>> What goes wrong:
>>>>> Effect:
>>>>> Greetz,
>>>>> Carsten
>>>>>> Hi Carsten,
>>>>>>> Hi,
>>>>>>> I am using
>>>>>>> this information?
>>>>>> Tschüß,
>>>>>> Stefan
>>>>>>> Greetz and Thanks!
>>>>>>> Carsten
Previous Topic:Getting sendig host when using client monitoring
Next Topic:Deploying Riena applications
Current Time: Mon Jul 21 21:36:23 EDT 2025
Powered by FUDForum. Page generated in 0.06412 seconds
