Home » Newcomers » Newcomers » How to find out what editor is opened?
How to find out what editor is opened? [message #247389] Thu, 31 January 2008 20:14 Go to next message
Hi Everyone,
How can I find out what the currently opened editor is? For example when I
have opened an HTML page in an editor, given that I have multiple editors
which could open an HTML file, then how can I find out what that
particular editor that I have opened is?
Thanks in Advance For your reply
Re: How to find out what editor is opened? [message #247405 is a reply to message #247389] Thu, 31 January 2008 20:51 Go to previous messageGo to next message
Orod wrote:
> Hi Everyone,
> I have opened an HTML page in an editor, given that I have multiple
> editors which could open an HTML file, then how can I find out what that
Hi Orod. I think you want Window / Preferences / General / Editors /
File Associations. HTH. Mark
Re: How to find out what editor is opened? [message #247480 is a reply to message #247389] Sat, 02 February 2008 12:01 Go to previous messageGo to next message
Originally posted by: dcarver.starstandard.org
Orod wrote:
> Hi Everyone,
You might want to try right mouse clicking on the file, and select Open
With. That will give you a list of possible editors, the one that is
selected is the one that it will open with. If you need the file to
open with a different editor, you can select the editor from that list.
The next time you open that particular file, it'll open with your
last selection.
Mark's suggestion on the File Association is also good, as you can
select to make a particular editor the default editor based on the
extension.
Re: How to find out what editor is opened? [message #247509 is a reply to message #247389] Sat, 02 February 2008 19:42 Go to previous messageGo to next message
Mark, and David,
Thanks for your replies. I do know about the default editor and how to
open a file using different editors. What I actually was looking for was
some easy way of knowing what the active editor is without having a prior
knowledge of what editor was used to open the file. For example, when you
look at a file that is opened with Ms Word, then you can see "Microsoft
Word" at the top and know what editor is being used without having prior
knowledge. I go from computer to computer and help people with their
problems, and I thought there might be an easy way of identifying the
editor that the person has open. I don't think the feature exists, but I
didn't want to miss the feature if it does exist.
Orod
Re: How to find out what editor is opened? [message #247514 is a reply to message #247509] Sat, 02 February 2008 20:42 Go to previous message
> was some easy way of knowing what the active editor is without having a
> prior knowledge of what editor was used to open the file. For example,
> when you look at a file that is opened with Ms Word, then you can see
> "Microsoft Word" at the top and know what editor is being used without
> having prior knowledge. I go from computer to computer and help people
> with their problems, and I thought there might be an easy way of
Well, if the editor has it's own Icon, then that should give you a
visual clue, but not a verbal clue.
Dave
Previous Topic:No Virtual Machine found
Next Topic:Exporting a plugin fails
Current Time: Sat Jul 26 12:40:17 EDT 2025
Powered by FUDForum. Page generated in 0.13159 seconds
