[RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener [message #247377] |
Sun, 30 May 2004 17:43  |
Originally posted by: fre_gilbert.yahoo.fr
Hi all,
I'm under Gentoo Linux and I tried the RCP Tutorial Part 1. In eclipse
my plugin works fine but when I running it outside Eclipse, it doesn't
work and I have a NoClassDefFoundError :
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Listener
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:151)
org.eclipse.ui.tutorials.rcp.part1.RcpApplication.run(RcpApp lication.java:26)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:277)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:239)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:117)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
The plugins directory contains both org.eclipse.swt_3.0.0 and
org.eclipse.swt.gtk_3.0.0
Any idea ?
Thanks in advance,
Frédéric
Re: [RCP M8] NoClassDefFoundError org/eclipse/swt/widgets/Listener [message #247935 is a reply to message #247910] |
Tue, 01 June 2004 10:41  |
rob dingwell wrote:
> exquisitus wrote:
>> Hi all,
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Any idea ?
>> Thanks in advance,
>> Frédéric
> I got a similar error as well. Difference was that
> org/eclipse/swt/widgets/Control was the class not found.
> The exception occured at the same location in tutorial 1
> though and both the swt and swt gtk plugins where under the plugins
> directory. I tried this a couple of ways as well, one by using the
> RCP runtime download and the other by following the directions in
> the tutorial to create the directory structure and copy all of the
> plugins over. Neither worked and both gave the same error.
> Running under Fedora Core 1, jdk 1.4.2_03.
> Rob..
Also I forgot to mention that this was on M9 not M8.
Rob
FUDForum. Page generated in 0.04093 seconds
