Word Emitter Error [message #247358] |
Wed, 11 July 2007 09:48  |
Getting the following error in 2.2.0 runtime, using the frameset servlet,
export to Word.
- org.eclipse.birt.report.service.api.ReportServiceException: Error happened
while running the report; nested exception is:
java.lang.NoClassDefFoundError
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userExcept ion
faultSubcode:
faultString: org.eclipse.birt.report.service.api.ReportServiceException:
Error happened while running the report; nested exception is:
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:org.eclipse.birt.rep ort.service.api.ReportServiceException:
org.eclipse.birt.report.service.BirtViewerReportService.rend erReport(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.BirtRenderRepo rtActionHandler.__execute(Unknown
Source)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.doService(Unknown
Source)
org.eclipse.birt.report.presentation.aggregation.layout.Fram esetFragment.service(Unknown
Source)
at org.eclipse.birt.report.servlet.ViewerServlet.__doGet(Unknow n Source)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(Unknown
Source)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:230)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:179)
org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:84)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:104)
org.jboss.web.tomcat.service.jca.CachedConnectionValve.invok e(CachedConnectionValve.java:156)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:241)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:580)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NoClassDefFoundError
org.eclipse.birt.report.engine.emitter.wpml.WordEmitter.acco untPageProp(WordEmitter.java:350)
org.eclipse.birt.report.engine.emitter.wpml.WordEmitter.star tPage(WordEmitter.java:195)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.start( HTMLPageLM.java:188)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:138)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RenderTask$PageRange Render.render(RenderTask.java:532)
org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:254)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(Unknown
Source)
... 29 more
{http://xml.apache.org/axis/}hostname:webdev1
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Source)
Caused by: org.eclipse.birt.report.service.api.ReportServiceException: Error
... 29 more
Source)
... 29 more
Re: Word Emitter Error [message #247445 is a reply to message #247413] |
Wed, 11 July 2007 14:59  |
Dave,
Can you log a bugzilla entry for this.
The word emitter is using a call that throws an exception in headless.
java.awt.Toolkit.getDefaultToolkit().getScreenResolution().
Add your log to the bug.
If you want to change the emitter plugin for your installation you can
modify that line of code to set a default value.
Jason
Dave Greco wrote:
> Jboss 4.2.0GA. The provided error was from running the sample test report.
> Other reports I've written give the same error.
> Actually upon further inspection, the first time (after JBoss startup) I run
> the Word emitter, I get a different error. On subsequent attempts I get the
> NoClassDefFoundError. The error about no X11 display found is certainly
> true- not running X on the server.
> First attempt error:
> java.lang.ExceptionInInitializerError
> AxisFault
> faultSubcode:
> faultActor:
> faultNode:
> faultDetail:
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by: java.lang.ExceptionInInitializerError
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> ... 29 more
> Caused by: java.awt.HeadlessException:
> No X11 DISPLAY variable was set, but this program performed an operation
> which requires it.
> at sun.awt.HeadlessToolkit.getScreenResolution(HeadlessToolkit. java:189)
> at
> org.eclipse.birt.report.engine.emitter.wpml.WordUtil.<clinit >(WordUtil.java:19)
> ... 38 more
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 29 more
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> ... 29 more
> which requires it.
> at org.eclipse.birt.report.engine.emitter.wpml.WordUtil.(WordUt il.java:19)
> ... 38 more
> "Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
> news:f72pra$bgo$1@build.eclipse.org...
>> Dave,
>> What app server are you using and does the word emitter work with the
>> sample test report?
>> Jason
>>> export to Word.
>>> AxisFault
>>> faultCode:
>>> faultSubcode:
>>> faultActor:
>>> faultNode:
>>> faultDetail:
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> ... 29 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 29 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> ... 29 more
FUDForum. Page generated in 0.13775 seconds
