Home » Language IDEs » Java Development Tools (JDT) » def-use-chain
def-use-chain [message #247300] |
Tue, 04 September 2007 10:05  |
Originally posted by: svylbowe.hotmail.com
is there any support for uncovering def-use-chains in the
org.eclipse.jdt.core APIs? Specifically, I wish to find all uses of a
parameter within a method body. Any help is greatly appriciated!
-- AH
Re: def-use-chain [message #247354 is a reply to message #247300] |
Tue, 04 September 2007 18:22   |
Originally posted by: eclipse5.rizzoweb.com
Anders H wrote:
Toggle on the Highlight Occurrences feature for the editor, then put the
cursor on any part of the parameter name that you're interested in. It
also works for other elements of code like methods, fields, exceptions,
return values, classes, etc.
The Highlight Occurrences feature is available via a toggle button on
the toolbar above the Java editor - icon looks like a yellow highlighter
pen.
Hope this helps,
Eric
Re: def-use-chain [message #247366 is a reply to message #247354] |
Wed, 05 September 2007 02:55   |
Thanks!
Do you also know where the relevant sources for this functionality is
located. I need it for a custom plugin.
-- Anders
"Eric Rizzo" <eclipse5@rizzoweb.com> wrote in message
news:fbklqa$qop$4@build.eclipse.org...
> Anders H wrote:
> The Highlight Occurrences feature is available via a toggle button on the
> toolbar above the Java editor - icon looks like a yellow highlighter pen.
> Hope this helps,
> Eric
Re: def-use-chain [message #247493 is a reply to message #247366] |
Wed, 05 September 2007 17:11   |
Originally posted by: jacek.pospychala.pl.ibm.com
Anders,
Maybe this dirty little secrets tutorial will put more light on topic
you are looking for:
www.cs.purdue.edu/homes/baker29/pldi05-tutorials/Static%20An alysis%20for%20*Java*%20in%20*Eclipse*.pdf
Anders H wrote:
> Thanks!
> -- Anders
>> Anders H wrote:
>>> Hi,
>> Hope this helps,
>> Eric
Re: def-use-chain [message #247511 is a reply to message #247366] |
Thu, 06 September 2007 04:13   |
Anders H wrote:
>Thanks!
It's in the org.eclipse.jdt.ui plug-in. Take a look at OccurrencesFinder.
HTH
Dani
>-- Anders
>>Anders H wrote:
>>>Hi,
>>Hope this helps,
>>Eric
Re: def-use-chain [message #247521 is a reply to message #247493] |
Thu, 06 September 2007 08:20   |
Thanks!
Is the source code for this tutorial available anywhere?
-- Anders
"Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
news:fbn64n$umo$1@build.eclipse.org...
> Anders,
> Maybe this dirty little secrets tutorial will put more light on topic you
> are looking for:
> Anders H wrote:
>> Thanks!
>> -- Anders
>>> Anders H wrote:
>>>> Hi,
>>> pen.
>>> Hope this helps,
>>> Eric
Re: def-use-chain [message #247526 is a reply to message #247511] |
Great, thanks!
-- Anders
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:fbocsi$a01$1@build.eclipse.org...
> Anders H wrote:
>>Thanks!
> HTH
> Dani
>>-- Anders
>>>Anders H wrote:
>>>>Hi,
>>>Hope this helps,
>>>Eric
Current Time: Sat Jul 26 12:40:17 EDT 2025
Powered by FUDForum. Page generated in 0.28991 seconds
