Home » Newcomers » Newcomers » help
help [message #247281] Wed, 30 January 2008 22:53 Go to next message
Originally posted by: estuardodelcid.hotmail.com
what can i do with this?
30/01/2008 09:20:47 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
Files\Java\jre1.5.0_05\bin;.;C:\WINDOWS\system32;C:\WINDOWS; C:/Program
Files/Java/jre1.5.0_05/bin/client;C:/Program
Files/Java/jre1.5.0_05/bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\Program
Files\QuickTime\QTSystem\;C:\Sun\SDK\bin;C:\CLIPPER5\BIN;;C: \PROGRA~1\COMMON~1\MUVEET~1\030625
30/01/2008 09:20:48 PM org.apache.coyote.http11.Http11Protocol init
INFO: Inicializando Coyote HTTP/1.1 en puerto http-8080
30/01/2008 09:20:48 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1219 ms
30/01/2008 09:20:48 PM org.apache.catalina.core.StandardService start
INFO: Arrancando servicio Catalina
30/01/2008 09:20:48 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.14
30/01/2008 09:20:48 PM com.sun.faces.config.ConfigureListener
contextInitialized
INFO: Initializing Sun's JavaServer Faces implementation (1.2_07-b03-FCS)
for context '/JSFTutorial'
30/01/2008 09:20:50 PM org.apache.coyote.http11.Http11Protocol start
INFO: Arrancando Coyote HTTP/1.1 en puerto http-8080
30/01/2008 09:20:50 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
30/01/2008 09:20:50 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/187 config=null
30/01/2008 09:20:50 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 2446 ms
30/01/2008 09:20:52 PM org.apache.catalina.core.StandardWrapperValve invoke
GRAVE: Servlet.service() para servlet jsp lanzó excepción
java.lang.RuntimeException: Cannot find FacesContext
javax.faces.webapp.UIComponentClassicTagBase.getFacesContext (UIComponentClassicTagBase.java:1835)
javax.faces.webapp.UIComponentClassicTagBase.setJspId(UIComp onentClassicTagBase.java:1652)
org.apache.jsp.Prueba1_jsp._jspx_meth_f_005fview_005f0(Prueb a1_jsp.java:107)
at org.apache.jsp.Prueba1_jsp._jspService(Prueba1_jsp.java:81)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:70)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:393)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:320)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :266)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:128)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:263)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:584)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:447)
at java.lang.Thread.run(Unknown Source)
Re: help [message #247334 is a reply to message #247281] Thu, 31 January 2008 09:48 Go to previous message
This appears to be an issue with Catalina (tomcat) and JSF
configuration, so I would start by asking on the Web Tools newsgroups,
eclipse.webtools and eclipse.webtools.jsf
Hope this helps,
Eric
> in production environments was not found on the java.library.path:
> C:\Program
> contextInitialized
> (1.2_07-b03-FCS) for context '/JSFTutorial'
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
Previous Topic:Open external file in defined editor
Next Topic:Exclude folder in Package Explorer view
Current Time: Tue Jul 22 14:45:44 EDT 2025
Powered by FUDForum. Page generated in 0.08656 seconds
