| [Zest] Zest Layouts [message #247218] |
Wed, 11 February 2009 06:47  |
Hi Ian,
i have to display some dependencies with the help of
zest and the jgrapht library, i use the DirectedGraph
class from this library as an input to the GraphViewer
from zest.
At the moment i have a problem with layouts.
Just like in the org.eclipse.pde.visualization.dependency
example i use the CompositeLayoutAlgorithm which is
composed of the DirectedGraphLayoutAlgorithm and HorizontalShift.
Only HorizontalShift seems to be applied.
Could you please review the snippet on this location, its a
little example of my situation(you can import it as a project
and open the view with an action in the main tool bar) :
http://depositfiles.com/files/uax112e5c
What could be the reason for such a behaviour ?
What am i doing wrong ?
thank you for help
| Re: [Zest] Zest Layouts [message #247284 is a reply to message #247218] |
Fri, 13 February 2009 11:46  |
Originally posted by: irbull.cs.uvic.ca
Yes, the one in Zest removes the horizontal placement. this is a bug
(We actually do this on purpose because the horizontal placement is
slow, I then manually place it myself).
Can you open a bug
cheers,
ian
Aleksey wrote:
> Hi Ian,
> class from this library as an input to the GraphViewer from zest.
> Could you please review the snippet on this location, its a little
> thank you for help
FUDForum. Page generated in 0.12380 seconds
