Home » Modeling » TMF (Xtext) » Serialize (pretty-print) - Xtext or TCS?
Serialize (pretty-print) - Xtext or TCS? [message #24283] Sun, 14 December 2008 18:09 Go to next message
is there a way to do model-to-text transformation with Xtext
programatically? If not, TCS surely can do it - but is it available at
least as source yet?
Thanks for the reply in advance!
thSoft
Re: Serialize (pretty-print) - Xtext or TCS? [message #24324 is a reply to message #24283] Mon, 15 December 2008 03:48 Go to previous messageGo to next message
Hi Dennis,
yes, TMF Xtext allows that. We are currently working on the API to
specify how whitespaces should be handled. It's pretty much finished and
will be included in M4 (dec. 29th).
Sven
Dennis Harmath schrieb:
> thSoft
Re: Serialize (pretty-print) - Xtext or TCS? [message #24407 is a reply to message #24324] Mon, 15 December 2008 06:24 Go to previous messageGo to next message
Hi Dennis,
Xtext provides an EMF Resource implementation, you can use that to save
models disk (serialize them to their textual format based on the grammar
you specified).
This is an example of the API Sven mentioned:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tmf/org .eclipse.xtext/plugins/org.eclipse.xtext/src/org/eclipse/xte xt/xtext/XtextFormattingTokenSerializer.java?revision=1.1&am p;root=Modeling_Project&view=markup
It defines whitespaces, linewraps and indentation for Xtext grammars itself.
regards,
Moritz
Re: Serialize (pretty-print) - Xtext or TCS? [message #26152 is a reply to message #24407] Thu, 15 January 2009 18:49 Go to previous messageGo to next message
Great news!
So that M4 is out, what is the exact way of serializing a model?
Something like this:
XtextResource resource;
resource.setTokenSerializer(new XtextFormattingTokenSerializer());
resource.doSave(new FileOutputStream(myFile), Collections.EMPTY_MAP);
...as I figured out so far...
Re: Serialize (pretty-print) - Xtext or TCS? [message #26192 is a reply to message #26152] Fri, 16 January 2009 11:44 Go to previous message
Hey,
you can use the RuntimeConfig of your DSL to configure a formatter for
it. This is Xtext's own RuntimeConfig, for example:
public class XtextRuntimeConfig extends AbstractXtextRuntimeConfig {
public Set<IServiceRegistration> registrations() {
Set<IServiceRegistration> inherited = scope(IXtext.SCOPE)
.with(IScopeProvider.class, XtextScopeProvider.class)
.with(ILinker.class, XtextLinker.class)
.with(ILinkingService.class, XtextLinkingService.class)
.with(ITransientValueService.class, XtextTransientValueService.class)
.with(ITokenSerializer.class, XtextFormattingTokenSerializer.class)
.registrations();
inherited.addAll(super.registrations());
return inherited;
Then XtextResources will use this formatter... there is no further
special treatment required for the resource.
Please note, that currently all information that is not stored in the
AST (your model) is not serialized when using the formatter. These are
whitespaes/linebrakes and comments.
This snipped might also be interesting, but don't rely on the API to
stay that way...
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.tmf/org .eclipse.xtext/plugins/org.eclipse.xtext/src/org/eclipse/xte xt/parsetree/reconstr/SerializerUtil.java?revision=1.3&r oot=Modeling_Project&view=markup
hth,
Moritz
Dennis Harmath wrote:
> Great news!
Previous Topic:[TCS] dc#title going in "dc#title" going out
Next Topic:[Announce] TMF XTEXT 0.7.0 I200901151317 is available
Current Time: Mon Sep 01 02:41:04 EDT 2025
Powered by FUDForum. Page generated in 0.07893 seconds
