| *.svn-base not hidden [message #247072] |
Wed, 29 August 2007 04:48  |
Hi!
I'm using subversive 1.1.7 on Eclipse 3.2 on two different machines. On my
main machine at work, everything is fine and the *.svn-base files are
ignored in the various dialogs of eclipse (most notably Search results,
and Open Resource).
But on my home machine, I must have done something wrong, and now these
files appear everywhere, thus 'polluting' my display.
Any idea what the problem could be?
Thanks for your help.
BoD
| Re: *.svn-base not hidden [message #247094 is a reply to message #247072] |
Wed, 29 August 2007 10:05  |
Originally posted by: jacek.pospychala.pl.ibm.com
BoD,
I've seen you already asked this question on
eclipse.technology.subversive. It's better to send one post to many
groups at once, instead of separate to each other because then everybody
will see all the answers.
If you don't get any reasonable answer there, you might try at
eclipse.platform as there is the biggest crowd.
Please check if the svn files are filtered in PackageExplorer - you'll
have to press a small triangle in the view upper right corner and choose
"Filters..." from there. Another option is to go to Window ->
Preferences and look for any svn and filters options. I don't have
subversive installed so it's hard to quess for me.
BoD wrote:
> Hi!
> On my main machine at work, everything is fine and the *.svn-base
> files are ignored in the various dialogs of eclipse (most notably
> Search results, and Open Resource).
> these files appear everywhere, thus 'polluting' my display.
> BoD
FUDForum. Page generated in 0.03407 seconds
