Home » Archived » M2M (model-to-model transformation) » [ATL] Re-usable modules with metamodels as formal parameters?
[ATL] Re-usable modules with metamodels as formal parameters? [message #24269] |
Sun, 18 March 2007 19:00  |
Hi all,
my metamodels have common subsets of metaclasses. For these
metaclasses, I have fixed transformation rules. Is it possible to put
these rules into a separate "rule library" module and use them from
several other transformations?
Example:
Metamodels MA, MB and MC all share the same metaclass MClass with the
same set of attributes. There are transformations that transform MA
into MB or MB into MC.
So, I'd like to be able to write something like this:
module MClassLibrary (param1, param2);
create OUT: param2 from IN: param1;
-- Copy all MClasses from one model to the next
rule MClassToMClass {
from mclassIn : param1!MClass
to mclassOut : param2!MClass (
name <- mclassIn.name
,someOtherAttribute = mclassIn.someOtherAttribute
And then:
module TransformAtoB;
create OUT: MB from IN: MA;
uses MClassLibrary (MA, MB);
-- more rules that operate especially on MA go here.
As well as:
module TransformBtoC;
create OUT: MC from IN: MB;
uses MClassLibrary (MB, MC);
-- more rules that operate especially on MB go here.
Is this possible? How?
Matthias at andromda.org
Re: [ATL] Re-usable modules with metamodels as formal parameters? [message #24353 is a reply to message #24269] |
Mon, 19 March 2007 06:39   |
Matthias Bohlen schreef:
> Hi all,
Hi Matthias,
> my metamodels have common subsets of metaclasses. For these metaclasses,
> I have fixed transformation rules. Is it possible to put these rules
> into a separate "rule library" module and use them from several other
> transformations?
The (lightweigth) solution for this is to use module superimposition. My
use case is to start from a general "copy" transformation and then
override a few rules to do something specific (i.e. "refinement").
> Example:
> same set of attributes. There are transformations that transform MA into
> MB or MB into MC.
> And then:
> As well as:
Superimposition cannot do *exactly* what you want. It can work for you,
if it's possible to use the same meta-model and model names (IN, OUT,
MB, MA, etc.). In this case, you can define a general transformation
module with the common transformation rules already in there. Then, you
define another transformation module with some specific rules (and
perhaps additional models/meta-models), which you can "superimpose" on
top of the general transformation module.
Dennis
> Cheers,
Re: [ATL] Re-usable modules with metamodels as formal parameters? [message #24517 is a reply to message #24353] |
Mon, 19 March 2007 12:30   |
On 2007-03-19 11:39:51 +0100, Dennis Wagelaar <dennis.wagelaar@vub.ac.be> said:
Hi Dennis,
thanks for the update.
Superimposition is not exactly what I need because my metamodels are
really different. They contain different metaclasses, only some of
which are common across several metamodels. This is why I really need
formal parameter substitution at ATL compile time, not superimposition
at load time.
To give you an example:
AndroMDA generates code for enterprise applications in Java or C#.
AndroMDA has one metamodel (EnterpriseApp) for enterprise applications,
it contains a Service and an Entity metaclass. Services and Entities
can have methods with parameters and their types, so this metamodel
also contains the metaclasses Method, Parameter and Type.
AndroMDA contains a second metamodel (Spring) for Spring-enabled beans.
This metamodel contains the metaclass SpringBean. Because SpringBeans
can have methods with parameters and their types, the Spring metamodel
also contains the same metaclasses Method, Parameter and Type.
Now, AndroMDA even contains a third metamodel called OOP (for object
oriented programming). This metamodel contains Class, Interface,
Property, Method, Parameter, Type and Comment. So, you see, Method,
Parameter and Type again.
(By the way: I create these metamodels in UML 2 and let them include
the same sub-model for the OOP metaclasses so that I do not have to
repeat myself).
Now, I have three got ATL transformations:
* UML2EnterpriseApp
* EnterpriseApp2Spring
* Spring2OOP
Each one of these transformations has to copy methods with parameters
and types from the source to the target model - always the same code
except that the metamodels are different although they contain some
common metaclasses.
What can we do so that I can write this "copy" code only once? It's
really essential for proper operation in AndroMDA.
Some months ago, Frédéric proposed this kind of "formal metamodel
parameter substitution". Would it be difficult to implement? Who has
got the necessary knowledge about the compiler?
Matthias
Re: [ATL] Re-usable modules with metamodels as formal parameters? [message #24680 is a reply to message #24517] |
Mon, 19 March 2007 15:54   |
>> you, if it's possible to use the same meta-model and model names (IN,
>> OUT, MB, MA, etc.). In this case, you can define a general
>> transformation module with the common transformation rules already in
>> there. Then, you define another transformation module with some
>> specific rules (and perhaps additional models/meta-models), which you
>> can "superimpose" on top of the general transformation module.
> Hi Dennis,
> really different. They contain different metaclasses, only some of which
> are common across several metamodels. This is why I really need formal
> parameter substitution at ATL compile time, not superimposition at load
> time.
Your meta-models can be different, as long as you use the same symbolic
name for your models/meta-models in the ATL transformations. For
example: 'UML' can refer to different meta-models, as long as they are
compatible for your purposes. More on this below...
You mention compile-time: the ATL compiler does not include a linker.
That means that helper calls and meta-model types are not checked at
compile time. The compiler just includes their symbolic references (e.g.
"UML" or "toString()"), such that the virtual machine can look up the
helpers and meta-classes. These helpers and meta-classes are looked up
in the libraries and (meta-)models you provide in your launch
configuration. If you provide your own meta-model and call it "UML" for
the purpose of the launch configuration, that's where the ATL VM will
look up any meta-classes starting with "UML!".
So ATL does its linking at run-time, except for rule inheritance. Rule
inheritance is implemented by inlining, not linking. This means all
inherited code is inserted in the child rule.
> it contains a Service and an Entity metaclass. Services and Entities can
> have methods with parameters and their types, so this metamodel also
> (By the way: I create these metamodels in UML 2 and let them include the
> same sub-model for the OOP metaclasses so that I do not have to repeat
> myself).
Hey, there we are! You even have a portion of the meta-model that is
guaranteed identical for all your meta-models. That means you can,
more-or-less, safely define a model transformation for that portion of
the meta-model. I say "more-or-less", since ATL is in effect a
dynamically typed language and does not provide type safety at compile-time.
(According to model-driven tradition: if you do want compile-time type
safety, you can add this by defining a type checking transformation ;-).)
> * UML2EnterpriseApp
> * Spring2OOP
> common metaclasses.
You can refer to your meta-models with a common symbolic name, e.g.
'MM'. Ever since ATL had support for MOF packages, it's easy to
distinguish between the different parts of your metamodel, e.g.:
rule Method {
from s : MM!common::Method
to t : MM!common::Method (
As soon as you use something specific from your "other" meta-models
(it's really just one big meta-network), you use a different MOF package:
rule SpringBean {
from s : MM!spring::SpringBean
to t : MM!spring::SpringBean (
> parameter substitution". Would it be difficult to implement? Who has got
> Cheers,
> Matthias
It would be more difficult than the above solution of just using 'MM'
whenever you refer to one of your meta-models.
The ATL compiler is in effect an ATL model transformation, for which the
source is unfortunately not available in the Eclipse CVS
(/org/atl/eclipse/engine/resources/ATLToASMCompiler.asm). The ATL engine
does provide an extension point such that you can include your own
compiler. I believe Frédéric has access to and knows everything about
the standard compiler setup.
Dennis
Re: [ATL] Re-usable modules with metamodels as formal parameters? [message #24863 is a reply to message #24680] |
Thu, 22 March 2007 06:21   |
If anyone is interested, academically speaking, in the idea of
transformations with metamodels as substitutable formal parameters,
there is a paper in SoSyM on this at
http://dx.doi.org/10.1007/s10270-006-0036-6
Jim.
(if you don't have a Springer subscription, email me).
>> Hi Dennis,
>> at load time.
>> applications, it contains a Service and an Entity metaclass. Services
>> and Entities can have methods with parameters and their types, so this
>> metamodel also contains the metaclasses Method, Parameter and Type.
>> beans. This metamodel contains the metaclass SpringBean. Because
>> SpringBeans can have methods with parameters and their types, the
>> Spring metamodel also contains the same metaclasses Method, Parameter
>> and Type.
>> repeat myself).
> compile-time.
>> * UML2EnterpriseApp
>> * Spring2OOP
>> common metaclasses.
> rule Method {
> rule SpringBean {
>> Cheers,
>> Matthias
> Dennis
Current Time: Sat Aug 30 19:35:28 EDT 2025
Powered by FUDForum. Page generated in 0.23856 seconds
