Home » Eclipse Projects » GEF » [Zest] Removing Node and Connections
[Zest] Removing Node and Connections [message #247005] Thu, 22 January 2009 11:29 Go to next message
Originally posted by: simone.simonesaraceni.it
I try to remove items from the Graph on Zest, i use this tip:
Object[] objects = g.getConnections().toArray() ;
for ( int x = 0 ; x < objects.length ; x++ ) {
((GraphConnection) objects[x]).dispose() ;
// remove all the nodes
objects = g.getNodes().toArray() ;
((GraphNode) objects[x]).dispose();
g.applyLayout();
But when I click on the graph, I receive the Exception:
org.eclipse.swt.SWTException: Widget is disposed.
Where I wrong?
Re: [Zest] Removing Node and Connections [message #247274 is a reply to message #247005] Fri, 13 February 2009 11:44 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
What version did you try this with? With had a problem with improper
disposing of connections, but I fixed this recently. Can you try with M5?
cheers,
ian
> g.applyLayout();
> Where I wrong?
Re: [Zest] Removing Node and Connections [message #247302 is a reply to message #247274] Fri, 13 February 2009 12:42 Go to previous messageGo to next message
Thanks for reply, I'm using v. 3.4.1. But I've solved the problem with
the code:
* This method removes all items (GraphNodes and GraphConnections) from
the graph
public void clearGraph(){
List nodes= this.getNodes();
int s=nodes.size();
for (int i = s-1; i >= 0; i--) {
((GraphNode ) nodes.get(i)).dispose();
So, for the moment I think i continue tu use current version.
Simone.
> cheers,
> ian
>> Object[] objects = g.getConnections().toArray() ; for (
>> // remove all the nodes objects = g.getNodes().toArray() ;
>> g.applyLayout();
>> Where I wrong?
Re: [Zest] Removing Node and Connections [message #247656 is a reply to message #247274] Sat, 07 March 2009 19:08 Go to previous message
The exception is thrown when removing selected nodes. Scenario is
following:
1. select node
2. remove all nodes
3. add new nodes
4. when selecting node exception is thrown.
Workaround is to unselect nodes before disposing.
I use M5 (org.eclipse.zest.core_1.0.100.v20090205-1237.jar).
Piotr
> cheers,
> ian
>> g.applyLayout();
>> Where I wrong?
Previous Topic:Print diagram without editor
Next Topic:PrintGraphicalViewerOperation question
Current Time: Mon Nov 17 04:27:25 EST 2025
Powered by FUDForum. Page generated in 0.07352 seconds
