Home » Newcomers » Newcomers » Vogella's Tutorial on RCP 3.3. Key Bindings?
Vogella's Tutorial on RCP 3.3. Key Bindings? [message #247002] Mon, 28 January 2008 13:31 Go to next message
Originally posted by: maxwellmac99.gmail.com
Hi Folks,
anyone tried this tutorial on Eclipse 3.3? All good up to key bindings,
which I can't get to work.
http://www.vogella.de/articles/RichClientPlatform/article.ht ml#N101E1
I'm running on Mac OS X Tiger with Europa 3.3.
Any advice would be much appreciated. I ask the man himself & he said it
should work OK. I've tried three times though with no luck!
Curiously, the XML source editor says some of the relevant tags have
deprecated.
Pretty weird given the XML is generated by the wizard & I only downloaded
it yesterday!...
Severity and Description Path Resource Location Creation Time Id
Attribute 'commandId' is deprecated TestKeybinding plugin.xml line
58 1201537865579 255
Attribute 'keyConfigurationId' is
deprecated TestKeybinding plugin.xml line 59 1201537865579 256
Attribute 'keySequence' is deprecated TestKeybinding plugin.xml line
60 1201537865580 257
Element 'keyBinding' is deprecated TestKeybinding plugin.xml line
57 1201537865580 258
Max
Re: Vogella's Tutorial on RCP 3.3. Key Bindings? [message #247240 is a reply to message #247002] Wed, 30 January 2008 10:02 Go to previous message
Hi Folks just to say for anyone else who tries this, it works!
I went through the tutorial again and it works fine. That's using Europa
on Mac OS X. The deprecated warnings don't seem to matter.
Probably the problem is before I cheated by copying one of the other
projects then modifying it to save time. I didn't realise that of course
the project XML files are project specific and you can't just copy the
project like that and expect it to work.
Anyway pretty cool to see it working with the key bindings...
Max
Previous Topic:how eclipse frees memory on exit?
Next Topic:Eclipse project settings shared between platforms
Current Time: Wed Nov 05 17:48:59 EST 2025
Powered by FUDForum. Page generated in 0.06582 seconds
