Home » Language IDEs » Java Development Tools (JDT) » Package Explorer is empty after "Go Into" and delete of this project
Package Explorer is empty after "Go Into" and delete of this project [message #246883] Fri, 17 August 2007 04:59 Go to next message
currently my package explorer is empty if I open a certain workspace and I'm
not able find a way to get it populated again.
What I did:
1.) I selected a project A and selected "Go Into"
2.) Somehow (I'm not able to reproduce / undo this) I made this perspective
the default one. So everytime I started Eclipse this view of "Go Intro" for
this specific project A was the default one. I always had to select "Up" to
get the "right" level.
3.) At some point I deleted project A.
Now the "Up" button is inactive and the package explorer is empty.
Any advice how to solve this? I did run eclipse with -clean but no result.
And in addition does anyone know how to set the "Go Into" to the default in
the package explorer? If I could reproduce this, I would like to open a bug
report.
Best regards, Lars
Re: Package Explorer is empty after "Go Into" and delete of this project [message #246893 is a reply to message #246883] Fri, 17 August 2007 08:03 Go to previous messageGo to next message
Lars,
I couldn't reproduce this behavior. The package explorer doesn't seem
to remember the "go into" value (with 3.3). The navigator does seem to
remember and gets slightly upset if I close Eclipse in the state where
it was focused on a deleted project and then start up again. But if I
create a new project, it shows that project. It seems odd either view
would stay in the state of being focused on a deleted project, so
perhaps that's worth opening a bug about...
Lars Vogel wrote:
> Hello,
> What I did:
> report.
> Best regards, Lars
Re: Package Explorer is empty after "Go Into" and delete of this project [message #246907 is a reply to message #246893] Fri, 17 August 2007 11:05 Go to previous messageGo to next message
Hi Ed,
thank you for your reply. I'm also using Eclipse 3.3
I opened Bug 200375 as suggested even though I assume it will be hard to
reproduce. I added also a screenshot in the bug report.
Best regards, Lars
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fa42qk$8ml$1@build.eclipse.org...
> Lars,
> I couldn't reproduce this behavior. The package explorer doesn't seem to
> remember and gets slightly upset if I close Eclipse in the state where it
> was focused on a deleted project and then start up again. But if I create
> a new project, it shows that project. It seems odd either view would stay
> in the state of being focused on a deleted project, so perhaps that's
> Lars Vogel wrote:
>> Hello,
>> I'm not able find a way to get it populated again.
>> What I did:
>> perspective the default one. So everytime I started Eclipse this view of
>> "Go Intro" for this specific project A was the default one. I always had
>> to select "Up" to get the "right" level.
>> result.
>> in the package explorer? If I could reproduce this, I would like to open
>> a bug report.
>> Best regards, Lars
Re: Package Explorer is empty after "Go Into" and delete of this project [message #246912 is a reply to message #246907] Fri, 17 August 2007 14:09 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
Have you tried to reset the perspective from the Window menu?
"Lars Vogel" <Lars.Vogel@gmail.com> wrote in message
news:fa4dgc$1s1$1@build.eclipse.org...
> Hi Ed,
> Best regards, Lars
> > Lars,
to
it
create
stay
> > Lars Vogel wrote:
> >> Hello,
and
> >> What I did:
of
had
> >> result.
default
open
> >> a bug report.
> >> Best regards, Lars
Re: Package Explorer is empty after "Go Into" and delete of this project [message #246917 is a reply to message #246912] Sat, 18 August 2007 02:30 Go to previous message
Hi Dave,
thank you for the tip. Resetting did not help but based on your tip I closed
the perspective.
After closing all perspectives and re-opening the java one the package
explorer is displaying the elements again.
Thank you, Lars
P.S. I will update Bug 200375 accordingly.
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:fa4o9f$quj$1@build.eclipse.org...
>> Hi Ed,
>> Best regards, Lars
>> > Lars,
> to
> it
> create
> stay
>> > Lars Vogel wrote:
>> >> Hello,
> and
>> >> What I did:
> of
> had
>> >> result.
> default
> open
>> >> a bug report.
>> >> Best regards, Lars
Previous Topic:setClasspathContainer doesn't affect classpath
Next Topic:Programmatically search for method references
Current Time: Tue Jun 03 07:39:23 EDT 2025
Powered by FUDForum. Page generated in 0.05960 seconds
