Home » Archived » XML Schema Definition (XSD) » Loading Schema from JAR
Loading Schema from JAR [message #24240] Thu, 03 July 2003 11:57 Go to next message
Originally posted by: tim.harris.snellwilcox.com
Hey,
I would like to load my schema files from a jar file (which holds the
entire app). How do I go about doing this?
I've tried passing the URL of the resource (works when not in jar file).
Tim
Re: Loading Schema from JAR [message #24282 is a reply to message #24240] Thu, 03 July 2003 12:59 Go to previous messageGo to next message
--------------19457ED2DCF6C667FF7AA8C2
Content-Type: text/plain; charset=us-ascii
Tim,
When I run XSD standalone with xsd.resources.jar on the CLASSPATH, the
schema for schema is loaded using a URL that looks like this for me:
jar:file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse .xsd/runtime/xsd.resources.jar!/org/eclipse/xsd/cache/www.w3 .org/2001/XMLSchema.xsd
Have you tried something like this?
Tim Harris wrote:
> Hey,
> Tim
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Tim,
<p>When I run XSD standalone with xsd.resources.jar on the CLASSPATH, the
<blockquote>jar:<A HREF=" file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd /runtime/xsd.resources.jar!/org/eclipse/xsd/cache/www.w3.org /2001/XMLSchema.xsd "> file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd /runtime/xsd.resources.jar!/org/eclipse/xsd/cache/www.w3.org /2001/XMLSchema.xsd </A></blockquote>
<br>&nbsp;
<p>Tim Harris wrote:
<blockquote TYPE=CITE>Hey,
<br>I would like to load my schema files from a jar file (which holds the
<br>entire app). How do I go about doing this?
<br>I've tried passing the URL of the resource (works when not in jar file).
<br>Thanks,
<br>Tim</blockquote>
</html>
--------------19457ED2DCF6C667FF7AA8C2--
Re: Loading Schema from JAR [message #24368 is a reply to message #24282] Fri, 04 July 2003 06:36 Go to previous messageGo to next message
Ed,
Yes I have (i'm running on unix so the path doesn't have the d:/ but other
than that it looks identical). How is the URL loaded?
I do this:
XSDResourceImpl xsdSchemaResource =
(XSDResourceImpl)resourceSet.getResource(
org.eclipse.emf.common.util.URI.createURI(schemaFile.toStrin g()),
true);
Where schemaFile is a Java URL object generated by:
URL schemaFile = this.getClass().getResource("filename.xsd");
Tim
> Tim,
Re: Loading Schema from JAR [message #24464 is a reply to message #24368] Fri, 04 July 2003 07:56 Go to previous messageGo to next message
--------------F9F59164A7034BE38FBF769A
Tim,
I'm not sure what to suggest without more details of what you have tried and how exactly it is failing. I tried adding an Example1.xsd to the
xsd.test.jar and running
xsd-test -validate
jar:file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse .xsd.test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example 1.xsd
That works fine. If I change URI to a .xsd file that doesn't exist, I get this stack trace:
<!-- << jar:file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse .xsd.test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example 1x.xsd >>
java.io.FileNotFoundException: JAR entry org/eclipse/xsd/test/Example1x.xsd not found in
D:\sandbox\unpackage13\eclipse\plugins\org.eclipse.xsd.test\ runtime\xsd.test.jar
at sun.net.www.protocol.jar.JarURLConnection.connect(JarURLConn ection.java:109)
at sun.net.www.protocol.jar.JarURLConnection.getInputStream(Jar URLConnection.java:119)
at org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createU RLInputStream(URIConverterImpl.java:466)
at org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:404)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:752)
at org.eclipse.xsd.test.XSDMainTest.loadAndPrint(XSDMainTest.ja va:354)
at org.eclipse.xsd.test.XSDMainTest.run(XSDMainTest.java:233)
at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
You can see from this stack trace that the URIConverterImpl is called to create the input stream from the URI. In this case, it's handled as a
normal URL:
protected InputStream createURLInputStream(URI uri) throws IOException
URL url = new URL(uri.toString());
URLConnection urlConnection = url.openConnection();
return urlConnection.getInputStream();
Can you provide more details of what you've tried and how it's failing?
Tim Harris wrote:
> Ed,
> I do this:
> true);
> Tim
> > Tim,
<html>
Tim,
<p>I'm not sure what to suggest without more details of what you have tried
and how exactly it is failing.&nbsp; I tried adding an Example1.xsd to
the xsd.test.jar and running
<blockquote>xsd-test -validate jar:<A HREF=" file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd .test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example1.xs d "> file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd .test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example1.xs d </A></blockquote>
That works fine.&nbsp; If I change URI to a .xsd file that doesn't exist,
<blockquote>&lt;!-- &lt;&lt; jar:<A HREF=" file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd .test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example1 "> file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd .test/runtime/xsd.test.jar!/org/eclipse/xsd/test/Example1 </A><font color="#FF0000">x</font>.xsd
<br>java.io.FileNotFoundException: JAR entry org/eclipse/xsd/test/Example1<font color="#FF0000">x</font>.xsd
not found in D:\sandbox\unpackage13\eclipse\plugins\org.eclipse.xsd.test\ runtime\xsd.test.jar
<br>&nbsp;at sun.net.www.protocol.jar.JarURLConnection.connect(JarURLConn ection.java:109)
<br>&nbsp;at sun.net.www.protocol.jar.JarURLConnection.getInputStream(Jar URLConnection.java:119)
<br>&nbsp;at org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createU RLInputStream(URIConverterImpl.java:466)
<br>&nbsp;at org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:404)
<br>&nbsp;at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:752)
<br>&nbsp;at org.eclipse.xsd.test.XSDMainTest.loadAndPrint(XSDMainTest.ja va:354)
<br>&nbsp;at org.eclipse.xsd.test.XSDMainTest.run(XSDMainTest.java:233)
<br>&nbsp;at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
<br>&nbsp;at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
<br>&nbsp;at java.lang.reflect.Method.invoke(Native Method)
<br>&nbsp;at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
<br>&nbsp;at org.eclipse.core.launcher.Main.run(Main.java:747)
<br>&nbsp;at org.eclipse.core.launcher.Main.main(Main.java:583)</blockquote >
create the input stream from the URI.&nbsp; In this case, it's handled
as a normal URL:
<blockquote>&nbsp; protected InputStream createURLInputStream(URI uri)
throws IOException
<br>&nbsp; {
<br>&nbsp;&nbsp;&nbsp; URL url = new URL(uri.toString());
<br>&nbsp;&nbsp;&nbsp; URLConnection urlConnection = url.openConnection();
<br>&nbsp;&nbsp;&nbsp; return urlConnection.getInputStream();
<br>&nbsp; }</blockquote>
<br>&nbsp;
<blockquote TYPE=CITE>Ed,
<br>Yes I have (i'm running on unix so the path doesn't have the d:/ but
other
<br>than that it looks identical). How is the URL loaded?
<br>I do this:
<p>XSDResourceImpl xsdSchemaResource =
<br>&nbsp;&nbsp;&nbsp; (XSDResourceImpl)resourceSet.getResource(
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; org.eclipse.emf.common.util.URI.createURI(schemaFile.toStrin g()),
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; true);
<p>Where schemaFile is a Java URL object generated by:
<p>URL schemaFile = this.getClass().getResource("filename.xsd");
<p>Thanks,
<br>Tim
<p>Ed Merks wrote:
<p>> --------------19457ED2DCF6C667FF7AA8C2
<br>> Content-Type: text/plain; charset=us-ascii
<br>> Content-Transfer-Encoding: 7bit
<p>> Tim,
<p>> When I run XSD standalone with xsd.resources.jar on the CLASSPATH,
the
<br>> schema for schema is loaded using a URL that looks like this for
me:
<p>>
<br>jar:<a href=" file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd /runtime/xsd.resources.jar!/org/eclipse/xsd/cache/www.w3.org /2001/XMLSchema.xsd "> file:/D:/sandbox/unpackage13/eclipse/plugins/org.eclipse.xsd /runtime/xsd.resources.jar!/org/eclipse/xsd/cache/www.w3.org /2001/XMLSchema.xsd </a>
<p>> Have you tried something like this?</blockquote>
</html>
--------------F9F59164A7034BE38FBF769A--
Re: Loading Schema from JAR [message #24506 is a reply to message #24464] Fri, 04 July 2003 10:19 Go to previous messageGo to next message
Ed,
Me == Muppet!
In the class path I mistyped xsd.resources.jar as xsdresources.jar!
It now loads the main Schema file out of a jar(yay!). Unfortunately none
of the files that are included in the schema file are being loaded. I get
the following error:
java.lang.IllegalArgumentException: merge against relative path
at org.eclipse.emf.common.util.URI.mergePath(URI.java:1260)
at org.eclipse.emf.common.util.URI.resolve(URI.java:1239)
at org.eclipse.emf.common.util.URI.resolve(URI.java:1172)
org.eclipse.xsd.util.XSDConstants.resolveSchemaLocation(XSDC onstants.java:1493)
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:368)
at org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.jav a:324)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:513)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1494)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2240)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1205)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:842)
org.eclipse.xsd.util.XSDResourceImpl.attached(XSDResourceImp l.java:352)
org.eclipse.emf.ecore.resource.impl.ResourceImpl$ContentsELi st.inverseAdd(ResourceImpl.java:326)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:238)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 58)
org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:316)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:881)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:755)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:220)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:286)
<stack to call getResource(schema file URI)>
Warning: URI jar:file:<path_to_jar>.jar!<path_to_schema>.xsd Line 17
Column 2
XSD: The location '<includedfile>.xsd' has not been resolved
<lots of XSD errors about unresolved element references>
Tim
Re: Loading Schema from JAR [message #24547 is a reply to message #24464] Fri, 04 July 2003 10:21 Go to previous messageGo to next message
FYI the error I was getting before I corrected the classpath typo was a
null return from EMFPlugin.INSTANCE.getBaseURL().
Tim
Re: Loading Schema from JAR [message #24588 is a reply to message #24506] Fri, 04 July 2003 12:12 Go to previous messageGo to next message
Tim,
Yes, I can reproduce this too when the schema contains relative schema locations. I need to talk to
the URI guy on Monday...
In the meantime, your best bet it to avoid zipping them into a jar. :-(
Tim Harris wrote:
> Ed,
> Me == Muppet!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Column 2
> Tim
Re: Loading Schema from JAR [message #24909 is a reply to message #24588] Tue, 15 July 2003 06:56 Go to previous message
Tim,
The next drop of EMF/XSD 1.1.1 will contain a fix to org.eclipse.emf.common.util.URI that will allow a
relative URI to be properly resolved against a jar-scheme URI.
Ed Merks wrote:
> Tim,
> Tim Harris wrote:
> > Ed,
> > Me == Muppet!
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Column 2
> > Thanks,
> > Tim
Re: Loading Schema from JAR [message #573611 is a reply to message #24240] Thu, 03 July 2003 12:59 Go to previous message
Tim,
Tim Harris wrote:
> Hey,
> Tim
<html>
Tim,
<br>&nbsp;
<br>Thanks,
</html>
Re: Loading Schema from JAR [message #573696 is a reply to message #24282] Fri, 04 July 2003 06:36 Go to previous message
Ed,
I do this:
true);
Tim
> Tim,
Re: Loading Schema from JAR [message #573831 is a reply to message #24368] Fri, 04 July 2003 07:56 Go to previous message
Tim,
xsd-test -validate
normal URL:
Tim Harris wrote:
> Ed,
> I do this:
> true);
> Tim
> > Tim,
<html>
Tim,
as a normal URL:
throws IOException
<br>&nbsp; {
<br>&nbsp;
other
<br>I do this:
<p>Thanks,
<br>Tim
<p>> Tim,
the
me:
<p>>
</html>
Re: Loading Schema from JAR [message #573868 is a reply to message #24464] Fri, 04 July 2003 10:19 Go to previous message
Ed,
Me == Muppet!
Column 2
Tim
Re: Loading Schema from JAR [message #573898 is a reply to message #24464] Fri, 04 July 2003 10:21 Go to previous message
Tim
Re: Loading Schema from JAR [message #573926 is a reply to message #24506] Fri, 04 July 2003 12:12 Go to previous message
Tim,
Tim Harris wrote:
> Ed,
> Me == Muppet!
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Column 2
> Tim
Re: Loading Schema from JAR [message #574285 is a reply to message #24588] Tue, 15 July 2003 06:56 Go to previous message
Tim,
Ed Merks wrote:
> Tim,
> Tim Harris wrote:
> > Ed,
> > Me == Muppet!
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > Column 2
> > Thanks,
> > Tim
Previous Topic:ResourceSetImpl.getResource exception
Next Topic:Analysing Schemas
Current Time: Wed Aug 13 15:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.06918 seconds
