Home » Eclipse Projects » GEF » A few questions on Zest
| A few questions on Zest [message #246567] |
Sun, 14 December 2008 07:32  |
Originally posted by: zzhangh.cn.ibm.com
Hi all,
I got a few questions while using Zest as below,
1. How to use custom figure for GraphNodes (not tooltips, but the nodes themselves)
2. After a graph has been created, how to show/hide texts on the nodes (I tried GraphNode#setNodeStyle(), but the graph
was not updated)
Thanks in advance!
Hao
| Re: A few questions on Zest [message #246572 is a reply to message #246567] |
Sun, 14 December 2008 22:26   |
Originally posted by: lifesting.gmail.com
Hao Zhang wrote:
> Hi all,
> was not updated)
> Thanks in advance!
> Hao
1. Every GraphNode has a GraphLabel as its figure, so if you use Zest
Viewer(JFace style), specify a image in the viewer's labelprovider or
directly set the image for GrahpNode through invoking its method
*setImage* (SWT style)
viewer = new GraphViewer(shell, SWT.NONE);
viewer.setContentProvider(new MyContentProvider());
viewer.setLabelProvider(new MyLabelProvider(){
public Image getImage(Object element) {
return custom_image;
Graph g = new Graph(shell, SWT.NONE);
GraphNode n = new GraphNode(g, SWT.NONE, "David");
n.setImage(image);
2 Because figure is GraphLabel, you can simply do it like below:
Hide:
node.setText("");
//update node style
node.setNodeStyle(n.getNodeStyle() | ZestStyles.NODES_HIDE_TEXT);
Show:
node.setText("New Text");
node.setNodeStyle(n.getNodeStyle() & ~ZestStyles.NODES_HIDE_TEXT);
Hope this help you!
BTW: are you the famous IBM CSDL fellow Zhang Hao?
| Re: A few questions on Zest [message #246577 is a reply to message #246572] |
Mon, 15 December 2008 05:05   |
Hi David,
For the show/hide question your suggestion worked, thanks!
However, for the other one, what I wanted is to use a custom IFigure other than an Image, is there any solution? Do I
have to write my own GraphNode?
P.S. I'm not the fellow...
Hao
David BY Chan wrote:
> Hao Zhang wrote:
>> Hi all,
>> was not updated)
>> Thanks in advance!
>> Regards,
>> Hao
> n.setImage(image);
> Hide:
> node.setText("");
> //update node style
> Show:
> Hope this help you!
| Re: A few questions on Zest [message #246582 is a reply to message #246577] |
Mon, 15 December 2008 22:21  |
yes, write an extended GraphNode and override its method
createFigureForModel, where substitute your figure for GraphLabel.
More details you'd better read the source code of Zest.
Hao Zhang wrote:
> Hi David,
> Hao
>> Hao Zhang wrote:
>>> Hi all,
>>> was not updated)
>>> Thanks in advance!
>>> Regards,
>>> Hao
>> n.setImage(image);
>> Hide:
>> node.setText("");
>> //update node style
>> Show:
>> Hope this help you!
Current Time: Wed Oct 29 10:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.53907 seconds
