Home » Eclipse Projects » Eclipse Platform » URGENT! Debug Framework
URGENT! Debug Framework [message #246244] Thu, 27 May 2004 09:38 Go to next message
Originally posted by: soranom.ar.ibm.com
Following the subject in
http://dev.eclipse.org/newslists/news.eclipse.platform/msg03 767.html
I would like to deepen my Debug framework awareness.
Please, could anybody send me examples about
1) Implemention of an IThread
2) Implemention of an IStrackFrame
3) Implemention of an IVariable holding IValues
4) Implemention of an IDebugModelPresentation and its extension points
Thanks a lot!!
Angeles
Re: URGENT! Debug Framework [message #246357 is a reply to message #246244] Thu, 27 May 2004 13:27 Go to previous messageGo to next message
There are implementations of all of these within Eclipse itself for the Java
debugger.
I would start:
http://www.eclipse.org/articles/Article-Launch-Framework/lau nch.html
and
http://www.eclipse.org/articles/Article-Java-launch/launchin g-java.html
and then start browsing/debugging the Java debugger implementation.
HTH
Darins
"Angeles Sorano" <soranom@ar.ibm.com> wrote in message
news:c94r13$k00$1@eclipse.org...
> Hello,
> Thanks a lot!!
> Angeles
Re: URGENT! Debug Framework [message #246412 is a reply to message #246357] Thu, 27 May 2004 13:30 Go to previous messageGo to next message
Thanks Darin for your answer but,
I have forgot to tell you that my Debug implementation is oriented to
non-Java language. So, I don't know if this a problem or not.
I mean, i would like to know if I have to create a new Debug model or
extend all the existing debug fuctionality.
Up to know, I have reached to create a Run/Debug Configuration (a
LaunchConfigurationDelegate, a LaunchConfigurationTabGroup
and a MainTab).
I have no problem for "Run mode" but I don't know how to do in "Debug
mode".
i.e. inside my LaunchConfigurationDelegate.launch(....){
if (mode == "debug")
/*WHAT SHOULD DO HERE???*/
Thanks for advice!
Angeles
> debugger.
> I would start:
> and
> HTH
> Darins
> > Hello,
> > Thanks a lot!!
> > Angeles
Re: URGENT! Debug Framework [message #246647 is a reply to message #246412] Thu, 27 May 2004 20:34 Go to previous messageGo to next message
DarinS advice still applies. The Eclipse SDK comes with a java debugger,
if you want to see another example you can also look at the c debugger
in the CDT.
Kevin
> and a MainTab).
> mode".
> Thanks for advice!
> Angeles
>>debugger.
>>I would start:
>>and
>>HTH
>>Darins
>>>Hello,
>>>Thanks a lot!!
>>>Angeles
Re: URGENT! Debug Framework [message #246822 is a reply to message #246647] Fri, 28 May 2004 09:26 Go to previous message
Ok, Kevin/Darin....we are understand us. :)
See, that I have to do is a plugin Debbuger that it'll use an external
debugger.
I think the same, that CDT is closer to my debug model.
But the only problem is there are so many classes and interfaces that I
can't understand its design model. :(
So, I think I should re-direct my mail to CDT newsgroup.
Thanks both for tyour help!!!!
Anyway I'd like to know your opinions.
Angeles
> in the CDT.
> Kevin
> > and a MainTab).
> > mode".
> > Thanks for advice!
> > Angeles
Java
> >>debugger.
> >>I would start:
> >>and
> >>HTH
> >>Darins
> >>>Hello,
> >>>Thanks a lot!!
> >>>Angeles
Previous Topic:Context menu - TargetID
Next Topic:show/hide coolbar in RCP
Current Time: Mon May 12 06:53:18 EDT 2025
Powered by FUDForum. Page generated in 0.06435 seconds
