Home » Archived » BIRT » Custom hyperlink
Custom hyperlink [message #246231] Wed, 04 July 2007 01:17 Go to next message
My application stores BIRT objects in database and files.
BIRT provides dialog to select location of BIRT object. I need ability
to extend UI (My dialog will provide UI to select BIRT Object in
database) and runtime part for opening BIRT Objects from database.
How to implement it?
Thanks.
Boris Stepanov
Re: Custom hyperlink [message #246360 is a reply to message #246231] Wed, 04 July 2007 20:36 Go to previous messageGo to next message
Boris Stepanov wrote:
> Hello,
> Thanks.
what's the dialog that you mentioned? Do you mean the source location
dialog?
Could you provide a screen shot of the dialog?
Qs
Re: Custom hyperlink [message #246419 is a reply to message #246360] Thu, 05 July 2007 03:28 Go to previous messageGo to next message
--------------060402070705090504060601
Content-Type: text/plain; charset=UTF-8; format=flowed
I mean Hiperlink Options dialog (picture is attached). User can input
any string (e.g. path to database report) to this dialog and extention
of this dialog has a low priority. The problem is that I do not know how
to handle this custom string in runtime. Where I can put my code to
parse that string, get report from database and provide it to the BIRT
Report Engine?
> dialog?
> Regards
> Qs
Boris Stepanov
Content-Type: image/jpeg;
name="hyperlinkOptions.JPG"
Content-Disposition: inline;
filename="hyperlinkOptions.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAK4AgwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDY8f8Aj/WPC3iG10zTLOwl SW0il/fW5dy7
EjAwR6Cs248c/EK0RXuNB0iMMNwDQqGx9PMyKl8YmEfGXQTPt2Cwjxu6bsSb f1xUfiLWtPuZ
T9svEV0+UjzpBj/yCa9GlSg4x92+hm76u5iyfGXxPDIY5NP0hXBwQbU//FUg +NHiP/nx0f8A
8BT/APFVlaXJp8vxB8NvYzCUnUoA5EjPj96mPvRp7+v4d+xubnSY9P8AiXIN NuZFi1S2a8jm
uwVuALtshdqKYwcMOrEZHPHOsqdKLtyf1exjzS7mIPjN4j/58tH/APAU/wDx VOHxl8Rf8+Wk
f+Ap/wDiq3oPBvg6PxboOkRxf2gmsyTaij7povKszC5hixu+b5gTuyG+TBHN V9P8HaDOdLl1
LS3sdSm0u9uZNHRpdzyRPiLETv5pLKXbaHG7y+CAGqbYf+X+tf8AIP3ncyx8 Y/EX/PlpH/gK
f/iqsXHxW8V2nlfatJ06DzoxNF5tky70PRly3KnsRxU76F4YttN17Vbjwzqk S2EFhILS8Z7R
i7yskhQFnIjbaPvFiPmAI4I6UaVaapounR3YmeM6ToETRrO6I6vcMrBlUgNx 0znHUYNKSor7
H9af5jTn3OVtPir4qv7lLaz0rTri4fO2KGyZ2bAycAHJ4BNRD4v+IP8Any0n /wABT/8AFV1v
hXQtJt/FVvqFjYJZy2XiC80tRFJIyyRLbSMC29m+bI6jA5PHTHnHi7SrLSf7 NTS4fNsJbYPH
qm9j9uY43nbnEew/LsxuGPmJyKcIUZS5eUTc0r3NsfF7xB/z56T/AOAp/wDi qcPi5r//AD56
T/4DH/4qup1j7T/bHi7zfO/4Rb+wv9A35+xb/Lh8vyv4M7vu7ec9KbeeGND0 PxBdXJ01NKt9
N1LTTY3byyKtwHcGUEyMVYKMn5cEbeTjNSvY9Yf1p/mP3+5zQ+Lev/8APnpX /gMf/iqUfFnX
v+fPSv8AwGP/AMVW7caTBd3vjIapay6XA2oWgMizSxLLE926tMwdirZGSCRt GMgDmp7TwVoU
2uWsF7o/2PdrF1aRW/myr9qtkhZll+ZixwwX5lIHPTkUfuFvH+rXD953OdHx X14/8uelf+Ax
/wDiqcPitrv/AD6aV/4DH/4qruleHdB1C30DUZ9LuEF/a3hkgs4554kkjkCo 7KGMu35ucN12
9BmuQ8T6fHpXia/sYja7IJNg+ysxj6D+8zEH1BJw2R2rSNOjJ8qiS5TSvc6M fFXXf+fTS/8A
wG/+vTh8U9c/59NL/wDAb/69cKKcKv6tS/lI9rPud0Pilrn/AD6aX/4Df/Xp R8UNb/59NM/8
Bv8A69cOKeKPq9L+UftZ9ztx8T9b/wCfTTP/AAG/+vTh8Tda/wCfXTP/AAG/ +vXECnij6vS/
lD2s+52o+Jmtf8+um/8AgN/9enD4laz/AM+um/8AgN/9euLFOFL6vS/lF7Wf c7QfEnWT/wAu
um/+A3/16cPiPrH/AD66b/4D/wD164wU8UfV6X8oe1n3OxHxG1j/AJ9tO/8A Af8A+vTh8RNX
/wCfbTv/AAH/APr1x4pwo+r0v5Q9rPudePiHq/8Az7ad/wCA/wD9enD4hat/ z7af/wCA/wD9
euRFOFL6vS/lD2s+51w+IGrf8+2n/wDgP/8AXpR4+1X/AJ99P/8AAf8A+vXJ inij6vS/lD2s
+51Y8e6r/wA++n/+A/8A9enDx3qn/PvYf+A4/wAa5QU8UfV6XYPaz7nUjx1q n/PvYf8AgOP8
acPHOp/8+9h/4Dj/ABrlxThS+r0uwe1n3OoHjfU/+fex/wDAcUo8bal/zwsf /AcVzIp4o+r0
+we1n3OlHjTUv+eFj/4DinDxnqP/ADwsv+/ArmhTxR7Cn2D2s+50Y8Y6j/zw sv8AvwKcPF+o
f88LL/vwK50U8UvYU+we1n3OhHi7UP8AnjZf9+BSjxZf/wDPGz/78CufFPFH sKfYPaz7m+PF
d/8A88bP/vwKUeKr/wD542f/AH4FYIp4o9hT7B7Wfc3R4ovv+eNp/wB+BTh4 nvv+eNp/34FY
Qp4pewp9g9rPubg8S3v/ADytP+/ApR4kvf8Anlaf9+BWKKeKPYU+wvaz7myP EV5/zytf+/Ap
w8Q3f/PK1/78LWMKeKPYU+we1n3Nca/d/wDPK1/78LThr13/AM87b/vytZIp wpewp9g9rPua
w1y6/wCedt/35WlGt3X/ADztv+/K1linCj2FPsHtZ9zUGs3P/PO3/wC/K0o1 i5P/ACzt/wDv
yv8AhWaKeKXsafYPaz7miNWuP7lv/wB+V/wpw1W4/uW//flf8KzxThR7Gn2D 2s+5oDU5/wC5
B/35X/ClGpTf3IP+/K/4VRFPFHsafYPaz7mhDeTzTJEqwBnYKMwrjn8Ksb5P +e9l/wB+D/8A
EVRsf+P+2/66r/MVyHjGx1G81ex/4RyCa319Y2xqZGy3ig7xykqwkycbUAJB +bgdeXEKMGlF
HRRbmndnY6jqg02COWWW1fzJkhRUg5LOwUdVA75+g/CvIPiRK83i12c9IIwA BgAYzwO3U10l
rBBbeFNLij068sbhdWh+1peZaWSfeN8jSYxLuPIccEYxjGBy/wAQ/wDka3/6 4x/yrG943sa7
SsdV8Q/AureJfEdtqGn3NpEkVnFF+9d1bcMtkYU/3hXO33w28XakqC81PS5S gwGLMGP1Ijyf
xr2S5/1q/wDXNP8A0EVDVxxdSCUV0H7NPU8THwe8QDpeaZ/39k/+Ipw+EHiD /n80z/v7J/8A
EV7VRV/XqxPsIHmP/CH+O/8AhKP+Ek/tnTP7X/5+Mf7Hl/d8rb93jp+tYw+E ev8A/P3pv/fy
T/4ivZ6KSxtVbW+4PYRZ40PhLr3/AD96b/38f/4inD4Ta8P+XvTf+/j/APxF ex0U/r1YPYQP
HR8KNd/5+9O/7+P/APEU4fCnXf8An707/v4//wARXsFFH16sHsIHkA+FWuf8 /enf9/H/APiK
vap4B8U61qUuo6jqOnTXc23fJuZc4AUcBAOgFeo0UvrtW99A9hA8kHwu1v8A 5+tP/wC/j/8A
xFOHwv1v/n60/wD7+P8A/EV6zRR9erB7CB5OPhjrQ/5etP8A+/j/APxFOHwy 1r/n6sP+/j//
ABFerUUfXqoewgeVj4aaz/z82H/fx/8A4ilHw11n/n5sP+/j/wDxNep0UfXa ovYQPLh8N9Y/
5+bH/v4//wATTh8ONY/5+bH/AL7f/wCJr0+ij67VH7CB5iPhzq//AD82P/fb /wDxNOHw71f/
AJ+LH/vt/wD4mvTKKPrtUPYQPNR8PdW/5+LL/vt//iaUfD7Vv+fiy/77f/4m vSaKPrtUXsIH
nA8AaqP+Xiy/77b/AOJpw8A6r/z8Wf8A323/AMTXotFL67VD2EDzseA9U/5+ LP8A77b/AOJp
w8Cap/z3s/8Avtv/AImvQqKPrtUPq8Dz4eBdT/572n/fbf8AxNOHgfU/+e9p /wB9t/8AE139
FH12qH1eBwQ8Eal/z3tP++2/+Jpw8Fal/wA97T/vtv8A4mu7oo+uVQ+rwOFH gvUf+e1r/wB9
t/8AE04eDdR/57Wv/fTf/E13FFH1yqH1eBxI8Hah/wA9rX/vpv8A4mlHhDUP +e1t/wB9N/8A
E12tFH1yqH1eBxg8I3//AD2tv++m/wDiaUeE7/8A57W3/fTf4V2VFH1yqH1e Bx48KX3/AD1t
v++m/wAKcPC19/z1t/8Avpv8K66il9cqh9XgckPC97/z1t/++m/wpw8M3v8A z1t/++j/AIV1
dFH1yqH1eByw8NXn/PWD/vo/4U4eHLz/AJ6Qf99H/Cunoo+uVQ+rwOZHh27/ AOekH/fR/wAK
cPD13/z0h/76P+FdJRR9bqh9Xgc4NAuv+ekP/fR/wpw0G6/56Q/mf8K6Gij6 3UD6vAwBodz/
AH4fzP8AhSjRLn+/F+Z/wreoo+t1A+rwMMaNcf34vzP+FOGkXH9+L8z/AIVt UUfW6gfV4GMN
Jn/vx/mf8KcNKn/vx/mf8K16KX1uoH1eBlDTJv70f5n/AApRps396P8AM/4V qUUfWqgfV4Ga
NPl/vJ+Z/wAKcLCUfxJ+ZrQoo+tVA+rwKAspP7yfmacLOT1X86u0UfWqgfV4 FQWr+q04W7+q
1Zoo+tVA+rwK/kzKMxy+VIPuyLglT2IyCOPcEVkf8I5c/wDQwat/3+T/AOIr foqJV5S3KjSj
HY54+GHkkhafV9RuFilSVY5ZEKllORn5PavO/iIMeLJB6Qx/yr2WvG/iN/yN 0v8A1yT+VLnb
0HypantVz/rV/wCuaf8AoIqGprn/AFq/9c0/9BFQ1mWFFcld6teaLf3N7rM+ opax+e8UcCW7
W0yojyKi8ecH8tCx3FV3KwBwVBpXXjC5As7u8sLyzitLl5ZhGkypPGLS5faP NjiLMDGCRjA+
Q5z0LAd1RXK2viy9uQsB0V4r2adYYBMZooHJSRzl5IVbIWJ84RhynPJ23dFv 9VutY1eG8ith
bW86IpSYs0bmCFygGwbly7HeTnnG0DoAbtFcX/wkmrfYP+PG8/5DX2X7d+48 ryvt3lbdu/f9
z5M7M55/2qtSeMJTawm205JLrbEtzC9wUW3ne4W3EZbYdw3ib5lB/wBV0+ZT RYDqqK5K78ZX
NpN9h/srzNTSR0liiaaWJQqROSGjhZzxPH1jAzuGeBujuvEd5qVvJ5Nhc2MM F/p8bSyybJCZ
ZLZzGUHIO2VlcE46AbsttLAdjRXHaN4uvLuwt7qWwQ2Qazt5Z2uszmSeOFlO wRqpG6dQSCvQ
kL0WrvgjVpdW8M2LvvfyrS3SSaWQmSSXylZyynkD5lIJOWySBtKsxYDpKK5K 2vb/AEptevLz
U7zULbTblIjHMsKBITHDJJKSkYJZA8hwOoGMZwast4jv7jVBZaZpttOGa5CS 3F20SssDRI5w
I2OfMkdcEf8ALPOSCKLAdJRXJWnjgajf20dlpN5LaS+QHl8qUuhlRHB+VGj2 hZELFpFIw3Bw
u7p7WWeWFmuLfyHEkihN4bKhyFbI/vKA2O2cdqAJJJY4YzJK6og6sxwB+NEc sc0YkidXQ9GU
5B/GqOmadZa14xvItWiWaOzto2tbaXmOUOTvcoeH2kKM9BuGecEbc+haXpLX Elhax2xmCl0i
+VAVOBtXouQWJwBkjPrTtpcLlSiuYvNWvrPxsI3nzpK21tHJDsX5JZ5JVSTO Nx+aNI9o4/eb
jgKaq6H4svLnR9Oubi2SaELZ295cmXbIbidIiCsYXaVzMmTuXHzYU4GVYDsa KzILud/FN/Zs
+beKytpUTA4Z3nDHPXkIv5fWsHRvF15d2FvdS2CGyDWdvLO11mcyTxwsp2CN VI3TqCQV6Ehe
i0AdjRXN+CNWl1bwzYu+9/KtLdJJpZCZJJfKVnLKeQPmUgk5bJIG0qzdJQMK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigArxv4jf8jdL/wBck/lXsleN/Eb/AJG6X/rkn8qc dxM9quf9av8A
1zT/ANBFQ1Nc/wCtX/rmn/oIqGkBmHw/pr3Us88U1yZN+Y7q5kmiG4ENtjdi i5BZeAOGI6Ei
o08M6QoAktnuCGLFrueSdm+R02kyMSV2ySDafl+djjJzWvRQMyB4Z0sQPGY7 lmZlbz3vJmnU
gEDbKW3qAGcYDAfO3945tW2lWlndG5gEyymMRuTPIwfAADMC2GfCqN5y2ABn FXaKAKX9k2P2
T7L5H7j7T9q272/1vm+duznP+s+bHTt04rPufDS3em3drLdP5l3fpeTTICjE JKjKo2sCpEca
R7gQfl3dc1u0UAZB8M6WYEjEdyrKzN56XkyzsSADulDb2BCoMFiPkX+6MTpo emRwPBHaJHC8
8U5jQlVDxCMRkAHgARR8Dj5enJrQooAzLbw9pVpY/Y4LXZb+ZDLs8xj80IjE ZyTngRR/Xbzn
JzNZ6TY6f9n+yweV5FstqmHb/VL91Tz82OcE5Iy2PvHN2igClLp+231H7BL9 ku7zLm42+Ztl
8tUV9pODgIvHAOPc1nz+FbKafTAklzBa6daSWsUNvcSxNtYxY+dHDEARYwc5 zntW7RQBmDw9
pS3UU6Wvl+Xs2wxyMkJKABCYgQjMoVcEqSNq4+6MXbW0gsoWit02I0kkpGSf mdy7Hn1Zifxq
aigB8EnkSmREXcQATjBwM45HI6noadNcPMfmwB1wO/1J5P41l3eovFfRafZ2 U97fyxmVIYsK
NoIBLO2FUc9z1wOpFTWc13MZo7zTbmxmh2h1lwVO7JG1xw3A5x06HmjURHda TY3n237RBv8A
ttsLW4+dhviG/C8Hj/WPyMHn2FYUnhGeG8hfTbmxtrWBYlht5beeRf3aqqs4 FwqSMNq4Zl3D
avPyg104miad4BIhmRVdoww3KpJAJHYEq2PofSqUOvaPcXkdnBq1jLdSKHSB LlGdlK7gQoOS
CvzfTmgAn0WyuNUTUn+0pdKqJuiupY1ZUYsoZVYKwBZvvA9TTLbw9pVpY/Y4 LXZb+ZDLs8xj
80IjEZyTngRR/XbznJzZtdSsL2e4gtL22uJrZtk8cUqu0TZIwwB+U5B6+hq1 QMpWek2On/Z/
ssHleRbLaph2/wBUv3VPPzY5wTkjLY+8c3aKKACiiigAooooAKKKKACiiigA ooooAKKKKACi
iigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AK8b+I3/ACN0v/XJP5V7JXjfxG/5G6X/AK5J/KnHcTParn/Wr/1zT/0EVDU1 z/rV/wCuaf8A
oIqGkAUUUUDCiiigAooooAKKKKACiiigAooooAKKKKAMe68NS60niPTzeTWl vrFnFF9pt2/e
RMhb5dnV0YEhhkcEjuSNfSdLTw34V0/Qhe3F6bOAQie4OHfkMfl6qowFVT0X AycZK0U76Csc
/c3I0nxTd3lzBeNb3NlbxRPbWktxlo3mLAiNWK8SJ1xnPGcHHMaJoutWOl+T eQ7bG3ubGS6t
0gLXBMNtbHdG4Yq6iSMAqFJIV9pLYFdvf6Do+qTrPqGk2N3Mq7BJcWySMFyT jJB4yT+dWrSz
tbC1S1s7aG2t0zsihQIi5OTgDgckn8aVwMjQZC+seIwYbmMNfq6NLbvGrqII kypYAMN0bjjP
QHoQTu0UUDCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvG/iN/wAj dL/1yT+VeyV4
38Rv+Rul/wCuSfypx3Ez2q5/1q/9c0/9BFQ1Nc/61f8Armn/AKCKhpAFFFFA wooooAKKKKAC
iiigAooooAKKKKACiiigDOhtbrxBr9zpsN9JZWdnCj3Lwgec7PkoEY5AA2nJ x7d8jTTQZ9IE
yvqc17BhWh89R5iAHDbmGN2Sy44GAMc0lgkNlqct+odZpY1icqflYAkgsvG4 88EnI5x1INu8
vmucgE4OMk8cegHb35OcCndWF1OZ1PXX0vV4oJ4IRp/2Ke8mujM2+NYtu7EY Q7vvp/F/e44G
YbnxfYQNabIrx/OufIkjNpMs0YMcjq4iKb2UmMjIGPvc/KaNf8O3Wt3Tst/D Bbvp1zYMhti7
/vguXDbwOCicY7NzyCH6j4eluta/ta2vEhuo1hEIkhMiKyCdSWAZSwK3DcAj BUHJ6UgJp/E2
kWz3ImuXRbdZGeUwSeWfLBLqr7drsoVsqpLDa3HynDG8WaMsir9omZTGJjKl rK0SxlmUSNIF
2qh2MQxIBA3ZxzWRc+AreZ9S2PYxC8W52zjT1NyHnDht0pPzKDI2AApwFBYg Hdr6noH9o/21
/pPl/wBpacth/q8+Xjzvn68/67px93rzwaAM17xJDpVhqflBxe21pLNCJ7eR YpHWMuFDkBXO
ASVVs4DehwzxF4l/sO+srX/iXJ9qjlk83UL/AOyxjYYxtB2Nlj5mcccKay9V 8A/2ld3Ev2uz
TzftB89rHddHzYpI9rTbxuRfN+VdowqIueM1u6npl/capZ6hp97bW01vBNAV uLZplZZGjbtI
mCDGPXrRoAQeJNPle2jcXME0yxlkmt3AhdwCscrgFEk+ZRsLZyy4zuGa134q tDAh0+TzJWub
aNfNhkRJY5J442eNiAJFAcHcpI+ZT0IzBa+EPsMcVlbX3/EsWS2mkjkh3TM8 CxKmJAwUKfIj
yNhJ+bBGRthbwT9otLSyvL2Ge0sY4re2jNr1gWWGQrLliHZhAi5AUcsdpyAD QDTbxZoyyKn2
iZt0YlVo7WV0KszKhDBSDvKME5+fjbncMzy+INNhtYLp5Zvs82796ttIUi2n DeaQuItpyDv2
4w2cYOM4+FpWubiR9TeSN2svJEkZZ0S3nMwVnLfOSWK7jggAE7jknP1XwD/a NpcQfa7N/P8A
tA3Xlj5/kebLJJuh+dfLf97gtzu2IcDFGgGpceK7EXdqlrcwtAL2W2vZZFZV h2RTuw3HADAw
85zhSD0ZTW7DKs8EcyBwsihgHQowBGeVIBB9iMiuY1Pw+E0+yia2udSWDVJ7 0xW4RH/e+eRh
nkTaUMoIYHdlQQB1G7pLXb6ZCb5ZluPmDCdY1kwGIUt5bMm7GCSpwTzhfugA u0UUUDCiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigArxv4jf8AI3S/9ck/lXsleN/Eb/kbpf8Arkn8qcdxM9quf9av/XNP /QRUNTXP+tX/
AK5p/wCgioaQBRRRQMKKKKACiiigAooooAKKKKACiiigAooooArX2o2emwed e3McEfq5xnkD
gd+oosdRs9Sg86yuY54/VDnHJHI7dDRoFvFJ45vZ7yEPNFax/YJGXOxTuEuD 0BPHXnG7HG6t
3UrezjluJ4oYkuJQnnSIoDOw4TcR1wu/Ge34U7aCuZdFcxewR3PinUmutRvL SCz062mR4rx4
o4SXuNzsudjcIud4IwvIIyKz7XxBrd7p7T31tbW4hu9OgeJRKknmS/ZWcEbh tCmVxgk7sgMM
Kd6sB29FcD8Pbqa30ZY4rC5uVla0V5ImjCwj7DactucEjk/dDHg8dMs0T+3b r/hFJf7Ts2u5
dFmk86e0eTKH7IcN+9BZ88l8gH+7RYD0GiuLsPFup6jps+opb2cNuZLOCBDu dw9yluQW6Aqh
nPAwX4HyYy2hpmuX8viRtGuxbO0CziWeKNkEjKts6lVLNtGLgggk5Kg5GcUW A6SiuIsPFOsa
hpdrqafYYoRPYW9xCYHZpGnWBmZG3jYALjABDfdznnAm8FXl/Bpfh7T7uS2m hudHW4gaKFo2
iWNYV2tlm3kiUcjbjaeOeCwHY0UUUDCiiigAooooAKKKKACiiigAooooAKKK KACiiigAoooo
AKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACvG/iN /wAjdL/1yT+V
eyV438Rv+Rul/wCuSfypx3Ez2q5/1q/9c0/9BFQ1Nc/61f8Armn/AKCKhpAF FFFAwooooAKK
KKACiiigAooooAKKKKACiiigB8crx52tweoIyD9QeDRJK8mNzcDoAMAfQDgU yigDC1fwtbav
qkGovcPBcwKqxulrbSMpViwIaSJ2BBPYge2c1oW2mQw2pinb7Y7SCaSaeKMP I6kFWbYqqWXa
gBxkbF9Ku0UAQ21na2UZjtLaGBDjKxIFHChRwPRVUD2AHao4NNsLWd57eyto ZnZ3aSOJVZmc
guSQOSxVc+u0Z6VaooAqppthFaS2kdlbJbSrskhWJQjrtCYK4wRtUL9AB0FQ voOjy6fFp8mk
2L2UTb47ZrZDGjc8hcYB+Y/mfWtCigDCu/CWl3mqWF9JEiixWNYIUghCr5bb kw2zzFAOPlVg
vGMYJB14rO1g8nyraGPyIzDDsQDy04+VfRflXgcfKPSpqKACiiigAooooAKK KKACiiigAooo
oAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigArxv4jf8jdL/ANck/lXsleN/Eb/kbpf+uSfypx3Ez2q5/wBav/XNP/QR Vd4opMeYjNjp
iV0/9BYZ/GrFz/rV/wCuaf8AoIqGkBH9ltf+eMn/AIFT/wDxdH2W1/54yf8A gVP/APF1JRRc
CP7La/8APGT/AMCp/wD4uj7La/8APGT/AMCp/wD4upKKLgR/ZbX/AJ4yf+BU /wD8XR9ltf8A
njJ/4FT/APxdSUUXAj+y2v8Azxk/8Cp//i6Pstr/AM8ZP/Aqf/4upKKLgR/Z bX/njJ/4FT//
ABdH2W1/54yf+BU//wAXUlFFwI/str/zxk/8Cp//AIuj7La/88ZP/Aqf/wCL qSii4Ef2W1/5
4yf+BU//AMXR9ltf+eMn/gVP/wDF1JRRcCP7La/88ZP/AAKn/wDi6Pstr/zx k/8AAqf/AOLq
Sii4Ef2W1/54yf8AgVP/APF0fZbX/njJ/wCBU/8A8XUlFFwI/str/wA8ZP8A wKn/APi6Pstr
/wA8ZP8AwKn/APi6koouBH9ltf8AnjJ/4FT/APxdH2W1/wCeMn/gVP8A/F1J RRcCP7La/wDP
GT/wKn/+Lo+y2v8Azxk/8Cp//i6koouBH9ltf+eMn/gVP/8AF0fZbX/njJ/4 FT//ABdSUUXA
j+y2v/PGT/wKn/8Ai6Pstr/zxk/8Cp//AIupKKLgR/ZbX/njJ/4FT/8AxdH2 W1/54yf+BU//
AMXUlFFwI/str/zxk/8AAqf/AOLo+y2v/PGT/wACp/8A4upKKLgR/ZbX/njJ /wCBU/8A8XR9
ltf+eMn/AIFT/wDxdSUUXAj+y2v/ADxk/wDAqf8A+Lo+y2v/ADxk/wDAqf8A +LqSii4Ef2W1
/wCeMn/gVP8A/F0fZbX/AJ4yf+BU/wD8XUlFFwI/str/AM8ZP/Aqf/4uj7La /wDPGT/wKn/+
LqSii4Ef2W1/54yf+BU//wAXR9ltf+eMn/gVP/8AF1JRRcCP7La/88ZP/Aqf /wCLo+y2v/PG
T/wKn/8Ai6koouBH9ltf+eMn/gVP/wDF0fZbX/njJ/4FT/8AxdSUUXAj+y2v /PGT/wACp/8A
4uj7La/88ZP/AAKn/wDi6koouBH9ltf+eMn/AIFT/wDxdH2W1/54yf8AgVP/ APF1JRRcCP7L
a/8APGT/AMCp/wD4uj7La/8APGT/AMCp/wD4upKKLgR/ZbX/AJ4yf+BU/wD8 XR9ltf8AnjJ/
4FT/APxdSUqIzsFRSzHoAMmi4EX2W1/54yf+BU//AMXR9ltf+eMn/gVP/wDF 1a+yXP8Az7y/
98Gj7Jc/8+8v/fBo1Aq/ZbX/AJ4yf+BU/wD8XR9ltf8AnjJ/4FT/APxdWvsl z/z7y/8AfBqu
rq+drBtrFDg5wwJBH1BBB9xRqA37La/88ZP/AAKn/wDi6Pstr/zxk/8AAqf/ AOLqSii4Ef2W
1/54yf8AgVP/APF0fZbX/njJ/wCBU/8A8XUlFFwCvG/iN/yN0v8A1yT+VeyV 438Rv+Rul/65
J/KnHcGe1XP+tX/rmn/oIqGprn/Wr/1zT/0EVDSAYJomneASIZkVXaMMNyqS QCR2BKtj6H0p
9cL4m8JWtppviTWluJmd9OuCIjjYrbLgsQPujPndVAbhiWPmSbtDU/EVlcz2 f2bxHbWelus3
m6jbzQsomUx7It7hkBKu7bcbjsyOAcgHVUVxemeIbuVzcavdTWt9FbJLHokE cayXQ+zLI5WN
wZGYOZFG1gMx4PIbOEms3V/fW8V54htja2N3FcPqlrdwTi3EkF0mGk8lI1GV QAMhOZPvHcoB
YD1GivO3169todQC36WckDXclhbpFEo1GcXVyvk4K5c/JECI8OTKSSSwNa+n X+pC+sribUZp
4r3VryyNtJHGI4kjNwVKFVDbv3Kj5mIwW4zggsB1tc5ZJrV14ct9al15IYri 7W1WJdOWQqz3
HkKSd65GSCeOmeta2jz/AGnRLCf7X9s822jf7T5fl+dlQd+3+HPXHbOKp6d/ yS7Sv+w3bf8A
p0SqiJmr/wAIj4h/6GmD/wAFg/8AjlH/AAiPiH/oaYP/AAWD/wCOV2dFOyEc Z/wiPiH/AKGm
D/wWD/45R/wiPiH/AKGmD/wWD/45XZ0UWQHGf8Ij4h/6GmD/AMFg/wDjlH/C I+If+hpg/wDB
YP8A45XZ0UWQHGf8Ij4h/wChpg/8Fg/+OUf8Ij4h/wChpg/8Fg/+OV2dFFkB xn/CI+If+hpg
/wDBYP8A45R/wiPiH/oaYP8AwWD/AOOV2dFFkBxn/CI+If8AoaYP/BYP/jlH /CI+If8AoaYP
/BYP/jldnRRZAcZ/wiPiH/oaYP8AwWD/AOOUf8Ij4h/6GmD/AMFg/wDjldnR RZAcZ/wiPiH/
AKGmD/wWD/45R/wiPiH/AKGmD/wWD/45XZ0UWQHGf8Ij4h/6GmD/AMFg/wDj lH/CI+If+hpg
/wDBYP8A45XZ0UWQHGf8Ij4h/wChpg/8Fg/+OUf8Ij4h/wChpg/8Fg/+OV2d FFkBxn/CI+If
+hpg/wDBYP8A45R/wiPiH/oaYP8AwWD/AOOV2dFFkBxn/CI+If8AoaYP/BYP /jlH/CI+If8A
oaYP/BYP/jldnRRZAcZ/wiPiH/oaYP8AwWD/AOOUf8Ij4h/6GmD/AMFg/wDj ldnRRZAcZ/wi
PiH/AKGmD/wWD/45R/wiPiH/AKGmD/wWD/45XZ0UWQHGf8Ij4h/6GmD/AMFg /wDjlH/CI+If
+hpg/wDBYP8A45XZ0UWQHGf8Ij4h/wChpg/8Fg/+OUf8Ij4h/wChpg/8Fg/+ OV2dFFkBxn/C
I+If+hpg/wDBYP8A45R/wiPiH/oaYP8AwWD/AOOV2dFFkBxn/CI+If8AoaYP /BYP/jlH/CI+
If8AoaYP/BYP/jldnRRZAcZ/wiPiH/oaYP8AwWD/AOOUf8Ij4h/6GmD/AMFg /wDjldnRRZAc
Z/wiPiH/AKGmD/wWD/45R/wiPiH/AKGmD/wWD/45XZ0UWQHGf8Ij4h/6GmD/ AMFg/wDjlH/C
I+If+hpg/wDBYP8A45XZ0UWQHGf8Ij4h/wChpg/8Fg/+OUf8Ij4h/wChpg/8 Fg/+OV2dFFkB
xZ8La9CDLL4lieNPmZF04KWA6gHecH3wfpV8IqX06KMKolAHttat+7/485/+ ubfyrCb/AJCN
z/21/k1JjRSJA61VvtTtdNgWW5aTDtsRI42kd25OFRQWY4BPAPAJ6DNVdWT7 TqOiac8syW17
etFOIZWiZkW3mkA3qQy/MingjgEE4Jrj9a8QxQRX0Og6r4numRHFlKospLZm wdnzSL5rpkgb
jksOQW3gniq4qFOpySduvkWlod3ZalZ6im60uEk+UMUzh0BLL8ynlTlGGCAQ VYdQao+CEV9E
s0YZVriUEe3nPWZ4RudKv9S1m+sNMv7W6neM3c13Jv8ANb5toBEjgbQfujGF ZOMEVq+Bf+QP
Y/8AXzL/AOj3rqg1KN1qJ7nWWlh59uJJooIixJCqXb5exzuHJHaqNhe6Tqt7 c2lhKJ5LYlZJ
FtZxCGGMqJc7CeRwCT7cGo/E+oPpvgi+u4ryS0lhtd0c0e3cHwNo+ZWHJwOR 39ea43wXr1l4
MstL8HXMOsS6pcCKSKCSGMjEqs7sjDGY0IcMW+YEcZHAvQg29Jvrm9n1UXKR xtb3rQLHGcqg
CJwCeTyScn17DitOsbQeb3X/APsKSf8AoCVs1L3KQV438Rv+Rul/65J/KvZK 8b+I3/I3S/8A
XJP5U47gz2q5/wBav/XNP/QRUNTXP+tX/rmn/oIqGkAyaJZ4JIXLhZFKko5R gCMcMCCD7g5F
VdP0u303zPIkvH8zGftN5LPjGenmM2OvbGfwq7RQMKKKKACiiigApLCzsbLQ bfSHZ7iCCZbg
F48HzFm85T8rjgOAQPQYOecrWI3i/wAPoxVtUhDA4IOcg/lQriOz/tj/AGv/ ACD/APZ0f2x/
tf8AkH/7OuL/AOEx8Pf9BWD9f8KP+Ex8Pf8AQVg/X/Cndhodp/bH+1/5B/8A s6P7Y/2v/IP/
ANnXF/8ACY+Hv+grB+v+FH/CY+Hv+grB+v8AhRdhodp/bH+1/wCQf/s6P7Y/ 2v8AyD/9nXF/
8Jj4e/6CsH6/4Uf8Jj4e/wCgrB+v+FF2Gh2n9sf7X/kH/wCzo/tj/a/8g/8A 2dcX/wAJj4e/
6CsH6/4Uf8Jj4e/6CsH6/wCFF2Gh2n9sf7X/AJB/+zo/tj/a/wDIP/2dcX/w mPh7/oKwfr/h
R/wmPh7/AKCsH6/4UXYaHaf2x/tf+Qf/ALOj+2P9r/yD/wDZ1xf/AAmPh7/o Kwfr/hR/wmPh
7/oKwfr/AIUXYaHaf2x/tf8AkH/7Oj+2P9r/AMg//Z1xf/CY+Hv+grB+v+FH /CY+Hv8AoKwf
r/hRdhodp/bH+1/5B/8As6P7Y/2v/IP/ANnXF/8ACY+Hv+grB+v+FH/CY+Hv +grB+v8AhRdh
odp/bH+1/wCQf/s6P7Y/2v8AyD/9nXF/8Jj4e/6CsH6/4Uf8Jj4e/wCgrB+v +FF2Gh2n9sf7
X/kH/wCzo/tj/a/8g/8A2dcX/wAJj4e/6CsH6/4Uf8Jj4e/6CsH6/wCFF2Gh 2n9sf7X/AJB/
+zo/tj/a/wDIP/2dcX/wmPh7/oKwfr/hR/wmPh7/AKCsH6/4UXYaHaf2x/tf +Qf/ALOj+2P9
r/yD/wDZ1xf/AAmPh7/oKwfr/hR/wmPh7/oKwfr/AIUXYaHaf2x/tf8AkH/7 Oj+2P9r/AMg/
/Z1xf/CY+Hv+grB+v+FH/CY+Hv8AoKwfr/hRdhodp/bH+1/5B/8As6P7Y/2v /IP/ANnXF/8A
CY+Hv+grB+v+FH/CY+Hv+grB+v8AhRdhodp/bH+1/wCQf/s6P7Y/2v8AyD/9 nXF/8Jj4e/6C
sH6/4Uf8Jj4e/wCgrB+v+FF2Gh2n9sf7X/kH/wCzo/tj/a/8g/8A2dcX/wAJ j4e/6CsH6/4U
f8Jj4e/6CsH6/wCFF2Gh2n9sf7X/AJB/+zo/tj/a/wDIP/2dcX/wmPh7/oKw fr/hR/wmPh7/
AKCsH6/4UXYaHaf2x/tf+Qf/ALOj+2P9r/yD/wDZ1xf/AAmPh7/oKwfr/hR/ wmPh7/oKwfr/
AIUXYaHaf2x/tf8AkH/7Oj+2P9r/AMg//Z1xf/CY+Hv+grB+v+FH/CY+Hv8A oKwfr/hRdhod
p/bH+1/5B/8As6P7Y/2v/IP/ANnXF/8ACY+Hv+grB+v+FH/CY+Hv+grB+v8A hRdhodp/bH+1
/wCQf/s6P7Y/2v8AyD/9nXF/8Jj4e/6CsH6/4Uf8Jj4e/wCgrB+v+FF2Gh2n 9sf7X/kH/wCz
o/tj/a/8g/8A2dcX/wAJj4e/6CsH6/4Uf8Jj4e/6CsH6/wCFF2Gh2MmqiWJ4 2Y4YFTiH1/4H
VLzkN1PMTtQrK5LHGBtY81zsfi3QZpUii1KJ5HYKqKCSxPQAY5Na91aRTxyW 13BHLHnDxyKG
UkHuDweRRr1AwPEdhpPiSyhtrjWDbLDN5oa2njBb5GQqdwIKlXYEEcg4PGQc T/hDdI7+K70/
WW15/wDIX1/M+pz1f/CPaJ/0B9P/APAZP8KP+Ee0T/oD6f8A+Ayf4VlOjTm7 zin8h3YWMuka
dZx2lrc2scMYwqiYHqckkk5JJJJJ5JJJyTmq3g6b7P4dt5vLeTy5pn2Jjc2J nOBkgZ+pAqz/
AMI9on/QH0//AMBk/wAKvW9vBaQLBbQxwxLnbHGoVRk54A960VkrIRzlxNqt 9PFNf+Grucxc
JF/aIWEgEld0Qk2OR6kHoKzL/Sr/AFDxNH4hl0TUxqUUkbwyLfwARKgI8tR/ cbcxYdTnqK7q
incLGJ4at76GG/l1G3ME9zdtNtLKcgogz8pIHIPetuiikwCvG/iN/wAjdL/1 yT+VeyV438Rv
+Rul/wCuSfypx3BntVz/AK1f+uaf+gioamuf9av/AFzT/wBBFQ0gMiDXHn16 bSf7Jvo2hUSP
cO0PlhGLhG4kLYYxsANuRxkCp4te0ee0N3Dq1jJbBmQzJcoUDKpdhuBxkKCx 9ACelYs13u8R
ap9nkvree6tIbGCcaXcOsUyPN85Jj2FQZVIO7BwcnHNUrLwhenxBb6hew2yw RTwS+VJqE162
Y47kBg0qgghpoyB0G0nr1AOq/tjTP7T/ALM/tGz/ALQ/59fPXzfu7vuZz056 dOapT+LdCgt7
a6/tSzktJ7k232mO4QxRv5bSYds4HC49csvrXMajo9/qN2fDSQ4tBc3tw9/5 co2C4iuOzII2
2tcBcLIScZwPm26Fv4a1CC4j1NILZb2CdHWGXU7i5EqrHMmGmkBKj9+xACHl Tknd8oB1yTRS
vKkciO0TbJFVgSjYDYPocMD9CPWn1VtYZYri+eSO2RZZw8bQqQzr5aLmT1bK kf7oX0q1QMKz
vCWvHTPDWkWEGlX2o3V19tmVLQwjakdxhiTLIg6yr0z3rRrmtH8NzazoXh+9 XRtG1eC1TUYn
ttUkKqGkuVKuv7qQZAjYdB97rVRJZ2Fj430W5tLu/uL60stPjuIoYLq6nESz iS3inUjft2kr
L93r8pPsNT+3dH/tj+yP7Vsf7T/58vtCed93d9zO77vPTpzXHx+Ddfsrd4xq H9oq0qNIrajP
YvcMtrbwiZ5ogz7t0Mvycq3mgk5UVJovgrUtN8KjS5p7Rpxe6Xcbkdiu22Sz WQcrnJNs+OO6
5xk4oR1Gga3Drujafer5cU91ZQXj2wkDNEsq5XPQ4yGAOBnafStSuX8GeG7z wrpNppzyQTQi
0i89gxLrcLGiNtYjLxkLxuwU2hRlSqx9RQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAQ3f/AB5z
/wDXNv5VwfibxxonhXUBbatdLamQsYs2TOrAHBwyoRkcZGcjI9RXeXf/AB5z /wDXNv5Vwmup
4e1wyW+otYXlutwJlWSRWG5WyD1/D3BIOQSKljRQ1jWItX0XR7yzcm1udQtm RvIMRdfMGDgq
Dg4BGeDwR2rp7v8A4/J/+ujfzrl/EN5bXEempDcQyMNStiQjgnG8eldRd/8A H5P/ANdG/nS6
DIaKKKQwooooAKKKKACiiigArxv4jf8AI3S/9ck/lXsleN/Eb/kbpf8Arkn8 qcdxM9quf9av
/XNP/QRUNTXP+tX/AK5p/wCgioaQBRRRQMKKKKACiiigAqa0mSxtktrW3SGF M7UR3AGTk/xd
SSSfUmoaKALn9oy+n/kR/wD4qj+0ZfT/AMiP/wDFVToouIuf2jL6f+RH/wDi qP7Rl9P/ACI/
/wAVVOii4Fz+0ZfT/wAiP/8AFUf2jL6f+RH/APiqp0UXAuf2jL6f+RH/APiq P7Rl9P8AyI//
AMVVOii4Fz+0ZfT/AMiP/wDFUf2jL6f+RH/+KqnRRcC5/aMvp/5Ef/4qj+0Z fT/yI/8A8VVO
ii4Fz+0ZfT/yI/8A8VR/aMvp/wCRH/8Aiqp0UXAuf2jL6f8AkR//AIqj+0Zf T/yI/wD8VVOi
i4Fz+0ZfT/yI/wD8VR/aMvp/5Ef/AOKqnRRcC5/aMvp/5Ef/AOKo/tGX0/8A Ij//ABVU6KLg
XP7Rl9P/ACI//wAVR/aMvp/5Ef8A+KqnRRcC5/aMvp/5Ef8A+Ko/tGX0/wDI j/8AxVU6KLgX
P7Rl9P8AyI//AMVR/aMvp/5Ef/4qqdFFwLn9oy+n/kR//iqP7Rl9P/Ij/wDx VU6KLgXP7Rl9
P/Ij/wDxVH9oy+n/AJEf/wCKqnRRcC5/aMvp/wCRH/8AiqP7Rl9P/Ij/APxV U6KLgXP7Rl9P
/Ij/APxVH9oy+n/kR/8A4qqdFFwLn9oy+n/kR/8A4qj+0ZfT/wAiP/8AFVTo ouBc/tGX0/8A
Ij//ABVH9oy+n/kR/wD4qqdFFwLn9oy+n/kR/wD4qj+0ZfT/AMiP/wDFVToo uBc/tGX0/wDI
j/8AxVH9oy+n/kR//iqp0UXAszXhuIZIZokkikUo6O7lWU8EEFuQayv7E0D/ AKF3Sv8AwHFX
KKLgVY9I0SGVJYtB0xJEYMrrBgqR0IOeDVyRzLK8jYyxLHHvTaKACiiigYUU UUAFFFFABRRR
QAV438Rv+Rul/wCuSfyr2SvG/iN/yN0v/XJP5U47iZ7Vc/61f+uaf+gioamu f9av/XNP/QRU
NIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbpf+uSfyr2SvG/iN/wAjdL/1yT+V OO4me1XP+tX/
AK5p/wCgioamuf8AWr/1zT/0EVDSAKKKKBhRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXjfxG/wCR ul/65J/KvZK8
b+I3/I3S/wDXJP5U47iZ7Vc/61f+uaf+gioamuf9av8A1zT/ANBFQ0gCiiig YUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAV438Rv+Rul/65J/KvZK8b+I3/I3S/8AXJP5U47iZ7Vc/wCtX/rmn/oI qGprn/Wr/wBc
0/8AQRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbpf8Arkn8q9krxv4jf8jd L/1yT+VOO4me
1XP+tX/rmn/oIqGprn/Wr/1zT/0EVDSAKKKKBhRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABXjfxG/ 5G6X/rkn8q9k
rxv4jf8AI3S/9ck/lTjuJntVz/rV/wCuaf8AoIqGprn/AFq/9c0/9BFQ0gCi iigYUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
FABRRRQAV438Rv8Akbpf+uSfyr2SvG/iN/yN0v8A1yT+VOO4me1XP+tX/rmn /oIqGprn/Wr/
ANc0/wDQRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbpf+uSfyr2SvG/iN/y N0v/AFyT+VOO
4me1XP8ArV/65p/6CKhqa5/1q/8AXNP/AEEVDSAKKKKBhRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BXjfxG/5G6X/
AK5J/KvZK8b+I3/I3S/9ck/lTjuJntVz/rV/65p/6CKhqa5/1q/9c0/9BFQ0 gCiiigYUUUUA
FFFFABRRRQAV438Rv+Rul/65J/KvZK8b+I3/ACN0v/XJP5U47iZ7Vc/61f8A rmn/AKCKhqa5
/wBav/XNP/QRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/AJG6X/rkn8q9krxv 4jf8jdL/ANck
/lTjuJntVz/rV/65p/6CKhqa5/1q/wDXNP8A0EVDSAKKKKBhRRRQAUUUUAFF FFABRRRQAUUU
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABXjfxG/5G
6X/rkn8q9krxv4jf8jdL/wBck/lTjuJntVz/AK1f+uaf+gioamuf9av/AFzT /wBBFQ0gCiii
gYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
QAUUUUAFFFFABRRRQAV438Rv+Rul/wCuSfyr2SvG/iN/yN0v/XJP5U47iZ7V c/61f+uaf+gi
oamuf9av/XNP/QRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbpf+uSfyr2Sv G/iN/wAjdL/1
yT+VOO4me1XP+tX/AK5p/wCgioamuf8AWr/1zT/0EVDSAKKKKBhRRRQAUUUU AFFFFABRRRQA
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABXjfxG
/wCRul/65J/KvZK8b+I3/I3S/wDXJP5U47iZ7Vc/61f+uaf+gioamuf9av8A 1zT/ANBFQ0gC
iiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
RRRQAUUUUAFFFFABRRRQAV438Rv+Rul/65J/KvZK8b+I3/I3S/8AXJP5U47i Z7Vc/wCtX/rm
n/oIqGprn/Wr/wBc0/8AQRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbpf8A rkn8q9krxv4j
f8jdL/1yT+VOO4me1XP+tX/rmn/oIqGprn/Wr/1zT/0EVDSAKKKKBhRRRQAU UUUAFFFFABRR
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABXj
fxG/5G6X/rkn8q9krxv4jf8AI3S/9ck/lTjuJntVz/rV/wCuaf8AoIqGprn/ AFq/9c0/9BFQ
0gCiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
FABRRRQAUUUUAFFFFABRRRQAV438Rv8Akbpf+uSfyr2SvG/iN/yN0v8A1yT+ VOO4me1XP+tX
/rmn/oIqGprn/Wr/ANc0/wDQRUNIAooooGFFFFABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
UAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/kbp f+uSfyr2SvG/
iN/yN0v/AFyT+VOO4me1XP8ArV/65p/6CKhqa5/1q/8AXNP/AEEVDSAKKKKB hRRRQAUUUUAF
FFFABXjfxG/5G6X/AK5J/KvZK8b+I3/I3S/9ck/lTjuJntVz/rV/65p/6CKh qa5/1q/9c0/9
BFQ0gCiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
FFFFABRRRQAUUUUAFFFFABRRRQAV438Rv+Rul/65J/KvZK8b+I3/ACN0v/XJ P5U47iZ7Vc/6
1f8Armn/AKCKhqa5/wBav/XNP/QRUNIAooooGFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/Eb/ AJG6X/rkn8q9
krxv4jf8jdL/ANck/lTjuJntVz/rV/65p/6CKhqa5/1q/wDXNP8A0EVDSAKK KKBhRRRQAUUU
UAFFFFABXjfxG/5G6X/rkn8q9krxv4jf8jdL/wBck/lTjuJntVz/AK1f+uaf +gioamuf9av/
AFzT/wBBFQ0gCiiigYUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAV438Rv+Rul/wCuSfyr2SvG/iN/ yN0v/XJP5U47
iZ7Vc/61f+uaf+gioamuf9av/XNP/QRUNIAooooGFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFeN/ Eb/kbpf+uSfy
r2SvG/iN/wAjdL/1yT+VOO4me1XP+tX/AK5p/wCgioamuf8AWr/1zT/0EVDS AKKKKBhRRRQA
UUUUAFFFFABXjfxG/wCRul/65J/KvZK8b+I3/I3S/wDXJP5U47iZ7Vc/61f+ uaf+gioamuf9
av8A1zT/ANBFV3R3xsnWLHXMPmZ/8eXH60gHUVH5M3/P9H/4Bn/47R5M3/P9 H/4Bn/47RYCS
io/Jm/5/o/8AwDP/AMdo8mb/AJ/o/wDwDP8A8dosBJRUfkzf8/0f/gGf/jtH kzf8/wBH/wCA
Z/8AjtFgJKKj8mb/AJ/o/wDwDP8A8do8mb/n+j/8Az/8dosBJRUfkzf8/wBH /wCAZ/8AjtHk
zf8AP9H/AOAZ/wDjtFgJKKj8mb/n+j/8Az/8do8mb/n+j/8AAM//AB2iwElF R+TN/wA/0f8A
4Bn/AOO0eTN/z/R/+AZ/+O0WAkoqPyZv+f6P/wAAz/8AHaPJm/5/o/8AwDP/ AMdosBJRUfkz
f8/0f/gGf/jtHkzf8/0f/gGf/jtFgJKKj8mb/n+j/wDAM/8Ax2jyZv8An+j/ APAM/wDx2iwE
lFR+TN/z/R/+AZ/+O0eTN/z/AEf/AIBn/wCO0WAkoqPyZv8An+j/APAM/wDx 2jyZv+f6P/wD
P/x2iwElFR+TN/z/AEf/AIBn/wCO0eTN/wA/0f8A4Bn/AOO0WAkoqPyZv+f6 P/wDP/x2jyZv
+f6P/wAAz/8AHaLASUVH5M3/AD/R/wDgGf8A47R5M3/P9H/4Bn/47RYCSio/ Jm/5/o//AADP
/wAdo8mb/n+j/wDAM/8Ax2iwElFR+TN/z/R/+AZ/+O0eTN/z/R/+AZ/+O0WA koqPyZv+f6P/
AMAz/wDHaPJm/wCf6P8A8Az/APHaLASUVH5M3/P9H/4Bn/47R5M3/P8AR/8A gGf/AI7RYCSi
o/Jm/wCf6P8A8Az/APHaPJm/5/o//AM//HaLASUVH5M3/P8AR/8AgGf/AI7R 5M3/AD/R/wDg
Gf8A47RYCSio/Jm/5/o//AM//HaPJm/5/o//AADP/wAdosBJRUfkzf8AP9H/ AOAZ/wDjtHkz
f8/0f/gGf/jtFgJKKj8mb/n+j/8AAM//AB2jyZv+f6P/AMAz/wDHaLASUVH5 M3/P9H/4Bn/4
7R5M3/P9H/4Bn/47RYCSio/Jm/5/o/8AwDP/AMdo8mb/AJ/o/wDwDP8A8dos BJRUfkzf8/0f
/gGf/jtHkzf8/wBH/wCAZ/8AjtFgJKKj8mb/AJ/o/wDwDP8A8do8mb/n+j/8 Az/8dosBJRUf
kzf8/wBH/wCAZ/8AjtHkzf8AP9H/AOAZ/wDjtFgJKKj8mb/n+j/8Az/8do8m b/n+j/8AAM//
AB2iwElFR+TN/wA/0f8A4Bn/AOO0eTN/z/R/+AZ/+O0WAkrxv4jf8jdL/wBc k/lXsleN/Eb/
AJG6X/rkn8qcdwZ7Vc/61f8Armn/AKCKhqa5/wBav/XNP/QRUNIAooooGFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFeN/Eb/AJG6X/rkn8q9krxv4jf8jdL/ANck/lTjuJntVz/rV/65p/6CKhqa 5/1q/wDXNP8A
0EVDSAinure1QPcTxQqe8jhR+tPR0kQPG6up6MpyDVWWFIfD1prct9NbJInm T/ZolaeQv/q4
1Yg4AJxjHPc09ba7srLSZr5ES/ui0d0sYADHazKxA43AKASO5+laOnZXIU9S zRRRWZoFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFAGPLLqt1rt3ZWV7Z2kFrbW8pM1k07O0rTDtKg AAhHr1qT7Hr3
/Qd03/wTP/8AJVFn/wAjVrP/AF5WH/od3WpQIy/sevf9B3Tf/BM//wAlUfY9 e/6Dum/+CZ//
AJKrUoouBl/Y9e/6Dum/+CZ//kqj7Hr3/Qd03/wTP/8AJVXQsk5mcTNEIn8p FUAhm2q2WyOn
zAYGD156VDZXD3UhEjGJfkl7HcrRxsETjk5Y7iegI9RhgQfY9e/6Dum/+CZ/ /kqj7Hr3/Qd0
3/wTP/8AJValFK4GX9j17/oO6b/4Jn/+Sqxtc1bW9AutIWS/0+7W+v4bZ0XT XhKozhWIbz25
544/+v1tcT4//wCP7wv/ANhe3/8ARqU0B3kSx+S8kiu2GVQFYDrn2PpRutv+ eUv/AH9H/wAT
Qv8Ax5y/9dE/k1Q0gJt1t/zyl/7+j/4mjdbf88pf+/o/+JqGsIm91jUtQhh1 O506GwnW3Atk
iZpWMSSFmMiNxiQAAAdCSTkBQDo91t/zyl/7+j/4mjdbf88pf+/o/wDia4zV vG40q7vE+w/a
LeKOYxTRGXDyRRPIyMxiEY/1bqdrsQRyv3ttl/Ed/DeDS5tNthqsjRiGNLtm gKusrAtIYwwO
LeXgIf4eeTtAOq3W3/PKX/v6P/iaN1t/zyl/7+j/AOJrkj4ruV10aadImk8q SKC6kgWaQRyO
qN8rCLYUUSKSzOhwGO3pu0PCs0tx4P0SeeR5ZpLCB3kdizMxjUkknqSaAN3d bf8APKX/AL+j
/wCJrO17Uo9K0K9vobd2lhiLIHkG3d0GcDke3H4VbrD8Y/8AIo6l/wBcv6ih AbleN/Eb/kbp
f+uSfyr2SvG/iN/yN0v/AFyT+VOO4M9quf8AWr/1zT/0EVDU1z/rV/65p/6C KhpAVJ47oWf2
SIrJbCVZVQzNEykNuI3AHKk9sd+vTFmSS5vLlbm8ZNyKVjjjztTOM8nqeOvF OoqnNtWFyq9w
oooqSgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigAooooAKKKKACiiigAooooAx4Z4bfxPrDzSpGpsrAAuwAzvv PWr39p2H/P7b
f9/V/wAazdY8H6Hr18t5qVpJLcLGIg6XMsfygkgYRgOrH86z/wDhWvhT/oHz /wDgfcf/ABdG
gjov7TsP+f22/wC/q/40f2nYf8/tt/39X/Gud/4Vr4U/6B8//gfcf/F0f8K1 8Kf9A+f/AMD7
j/4ujQDea60mSTfLcWsnG0g3G0MPQhWG4deDkcn1p76jpshBe6tWPm+dnzgP mwq9jwMKBgY4
yO9c9/wrXwp/0D5//A+4/wDi6P8AhWvhT/oHz/8Agfcf/F09AOi/tOw/5/bb /v6v+NH9p2H/
AD+23/f1f8a53/hWvhT/AKB8/wD4H3H/AMXR/wAK18Kf9A+f/wAD7j/4uloB 0X9p2H/P7bf9
/V/xrjvHNzBcX3hnyJ45dur2+djhsfvU9Kv/APCtfCn/AED5/wDwPuP/AIup bb4eeGLS7guo
bCUSwSLLGWvJ2AZSCpwXIOCB1p6Adav/AB5y/wDXRP5NUNU9Q0u11SNI7sSs iHcFSd4xn1IU
jP49Mn1rP/4RDRf+fef/AMC5v/i6QG5Wff6LZajOs832mOYLsMltdS27MoJI DGNl3AEnGc43
HGMmqf8AwiGi/wDPvP8A+Bc3/wAXR/wiGi/8+8//AIFzf/F0AOuvCejXs0kl xbzMJPM3RC6l
WLMiMjkRhtgZg75IGcsT1OatXmiaffzyTzwv57qi+bHM8bqEL7drKQVP7yQZ BBIYg5HFU/8A
hENF/wCfef8A8C5v/i6P+EQ0X/n3n/8AAub/AOLoAsjw/pouorgxTM8ew4a5 kZHZAArupbbI
42rh2Bb5V5+UYu2dpBYWNvZ2qeXb28axRJknaqjAGTyeB3rJ/wCEQ0X/AJ95 /wDwLm/+Lo/4
RDRf+fef/wAC5v8A4ugDcrD8Y/8AIo6l/wBcv6ij/hENF/595/8AwLm/+LpG 8HaG6lWtpipG
CDdzYI/76o0A3a8b+I3/ACN0v/XJP5V7JXjfxG/5G6X/AK5J/KnHcGenXPjL w752Bq1udqqp
IJIyFAPOOelQ/wDCY+Hv+grB+v8AhRRT5UK4f8Jj4e/6CsH6/wCFH/CY+Hv+ grB+v+FFFHKg
uH/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hRRRyoLh/wmPh7/oKwfr/AIUf8Jj4 e/6CsH6/4UUU
cqC4f8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FFFHKguH/CY+Hv+grB+v8AhR/w mPh7/oKwfr/h
RRRyoLh/wmPh7/oKwfr/AIUf8Jj4e/6CsH6/4UUUcqC4f8Jj4e/6CsH6/wCF H/CY+Hv+grB+
v+FFFHKguH/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hRRRyoLh/wmPh7/oKwfr/ AIUf8Jj4e/6C
sH6/4UUUcqC4f8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FFFHKguH/CY+Hv+grB +v8AhR/wmPh7
/oKwfr/hRRRyoLh/wmPh7/oKwfr/AIUf8Jj4e/6CsH6/4UUUcqC4f8Jj4e/6 CsH6/wCFH/CY
+Hv+grB+v+FFFHKguH/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hRRRyoLh/wmPh 7/oKwfr/AIUf
8Jj4e/6CsH6/4UUUcqC4f8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FFFHKguH/C Y+Hv+grB+v8A
hR/wmPh7/oKwfr/hRRRyoLh/wmPh7/oKwfr/AIUf8Jj4e/6CsH6/4UUUcqC4 f8Jj4e/6CsH6
/wCFH/CY+Hv+grB+v+FFFHKguH/CY+Hv+grB+v8AhR/wmPh7/oKwfr/hRRRy oLh/wmPh7/oK
wfr/AIUf8Jj4e/6CsH6/4UUUcqC4f8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FF FHKguH/CY+Hv
+grB+v8AhR/wmPh7/oKwfr/hRRRyoLh/wmPh7/oKwfr/AIUf8Jj4e/6CsH6/ 4UUUcqC4f8Jj
4e/6CsH6/wCFH/CY+Hv+grB+v+FFFHKguH/CY+Hv+grB+v8AhR/wmPh7/oKw fr/hRRRyoLh/
wmPh7/oKwfr/AIUf8Jj4e/6CsH6/4UUUcqC4f8Jj4e/6CsH6/wCFH/CY+Hv+ grB+v+FFFHKg
cqC4f8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FFFHKguH/CY+Hv+grB+v8AhXl/ jm+tdR8Svc2c
6TQtEgDqeMgc0UU0rBc//9k=
--------------060402070705090504060601--
Re: Custom hyperlink [message #246594 is a reply to message #246419] Thu, 05 July 2007 21:26 Go to previous messageGo to next message
> Hello,
> Report Engine?
>> dialog?
>> Regards
>> Qs
For this case, I think you need point the link in the hyperlink dialog
to a server code(a servlet maybe?) of yours with appropriate parameters
In that servlet, you write the code to access the database, and run the
report by calling the report engine and forward the page to the result
report page.
Is this making sense to you?
regards
Qs
Re: Custom hyperlink [message #246810 is a reply to message #246594] Sun, 08 July 2007 22:55 Go to previous messageGo to next message
Thanks for advice!
It will be work in the web application. I need a way to resolve it in
RCP application too.
> report page.
> regards
> Qs
Boris Stepanov
Re: Custom hyperlink [message #246821 is a reply to message #246810] Sun, 08 July 2007 23:07 Go to previous message
> Thanks for advice!
>> the report by calling the report engine and forward the page to the
>> result report page.
>> regards
>> Qs
What's your meaning of RCP application?
Do you mean want to get the report list in the hyper link builder?
Qs
Previous Topic:[birt 2.2] default cell padding
Next Topic:birt from europa's update site. requirement missing
Current Time: Sun Nov 09 10:39:22 EST 2025
Powered by FUDForum. Page generated in 0.04047 seconds
