Home » Eclipse Projects » GEF » How to place links at specific position on an object.
How to place links at specific position on an object. [message #246185] Thu, 13 November 2008 02:21 Go to next message
Probelm Description:
I need to show the relations between objects with a link and respective
primary and secondary labels and Cardinalities
If there is only one relation between objects then there is no problem,
But, There can be more than one relation between two objects.I need to
distribute my links over an object uniformly. For that I have to provide
the anchors at specific locations.I am using a ChopBoxAnchor but all the
links originate and culminate in the same point, giving it a spider web
kind of appearance. I need to find specific anchors on the figure that so
that I can place my links at specific positions.I have a
ConnectionEditPart (GRMRelationLinkEditPart) and a figure
GRMRelationLinkFigure which extends PolyLineConnection.I can access the
figure in connectionEditPart.Now,I have following functions in
connectionEditPart.
refreshVisuals() :here we set the routingConstraint
getConnectionFigure().setRoutingConstraint( getLink().getBendPoints()
two more functions are there.
getSourceConnectionAnchor()
getTargetConnectionAnchor()
Please tell me where i need to make necessary changes,where to calculate
those points on objects.Do i also need to look into edit policies for some
code changes.
Another problem is:
How to find the height of an object before it is displayed in the UML
Editor.The user may select just one objet ,right click select the object
in the wizard and wants to show the relations. In that case, the second
object is not present in UML editor physically. So how to calculate its
height.
I am not able to understand how to do that and how to handle the change in
location/shape/dimension of the links according to the change in location
or dimension of objects.
can anyone throw some light on the issue.
Re: How to place links at specific position on an object. [message #246186 is a reply to message #246185] Thu, 13 November 2008 03:42 Go to previous messageGo to next message
Originally posted by: lifesting.gmail.com
Santosh Kumari wrote:
> so that I can place my links at specific positions.I have a
> connectionEditPart.
> getConnectionFigure().setRoutingConstraint( getLink().getBendPoints() );
> some code changes.
> Another problem is:
> height.
> in location/shape/dimension of the links according to the change in
> location or dimension of objects.
1 There are two way to archive your goal that more than one relation
between two objects visually.
one is use custom anchor instead of ChopAnchor, which will get the same
result(point). Simply add a field to the class that be the model of
GRMRelationLinkEditPart, assume it's name is GRMRelation, code may like
below:
public class GRMRelation extends Element
public String touchDesc; // north#1, north#2, south#1, south#2...etc..
public void setTouchDesc(String desc) { ... }
public String getTouchDesc(){....}
further, add some properties/relations into the figure who own the
relation, for example:
public class ObjectFigure extends Shape
public static final Map<String, AnchorDescriptior> ANCHORS = new
HashMap(8) // 8 anchors on every figure
static{
ANCHORS.put("south#1",new
AnchorDescriptor(AnchorDescriptior.Direction.SOUTH,
AnchorDescriptior.Order.FIRST);
ANCHORS.put("south#2",AnchorDescriptor(AnchorDescription.Direction.SOUTH,
AnchorDescriptior.Order.SEC);
public ConnectionAnchor getAnchor(Request request)
...find the nearest anchor to link point.
String nearest_desc = findNearestAnchor(request);
return new FixAnchor(this,ANCHORS.get(nearest_desc);
public class AnchorDescriptor{
public static enum Direction{SOUTH,NORTH,EAST,WEST};
public static enum Order{FIRST,SEC}; // every side have two anchor point
public Point getLocation(IFigure figure) //figure must be ObjectFigure
class FixAnchor is simple:
public class FixedAnchor extends AbstractConnectionAnchor {
private IFigure figure;
private AnchorDescriptior desc;
public FixedAnchor(IFigure figure, AnchorDescriptior desc)
this.figure = figure;
this.desc = desc;
public Point getLocation(Point reference) {
return desc.getLocation(figure);
public IFigure getOwner() {
return figure;
public Point getReferencePoint() {
Point center = getOwner().getBounds().getCenter();
getOwner().translateToAbsolute(center);
return center;
the other method is making the relation bendable, M(model)-C(editpart)
all need be changed, details please refer Logic example, which perfectly
meet your requirements.
M: org.eclipse.gef.examples.logicdesigner.model.Wire, **BendPointCommand
V: org.eclipse.gef.examples.logicdesigner.edit.WireEditPart with crucial
method refreshBendpoints,
org.eclipse.gef.examples.logicdesigner.edit.WireEndpointEdit Policy
2 You can't calculate the height of an object when it's not in the GEF
context, because bounds is calculated by Figure with its layout. but why
do calculation? you need persist the object's visual bound before editor
is closed, so directly get the data such as height, width, location etc.
in the next time.
Re: How to place links at specific position on an object. [message #246195 is a reply to message #246186] Thu, 13 November 2008 23:40 Go to previous message
David,
Thanks for the detailed solution.But I need to calculate the height of the
object before it is displayed in the UML Editor.Here is how it is done.
User has one object in the editor.He right clicks chooses "show relations"
from the menu.A dialog box opens and he chooses the secondary object and
relation in the dialog box.
According to his selection the object and relations are displayed in the
editor as soon as he clicks on "Finish".Now when the user is choosing the
object in the dialog box the object is not there in the UML Editor.When he
clicks on "finish" all the processing(creation of anchors on
objects,placing the links etc) has to be done.But since the second object
is not physically present,how can i calculate the height of the object to
create anchors on it uniformly.
I need to uniformly distribute the links.For eg. if the first object's
height is 80 and second object's 60,and they have three relations between
them. The links should be at 20,40,60 for first object and in the same
ratio on second.
Is it possible?if yes,please giude me on this.
Previous Topic:Toolbar Layout with resizable children.
Next Topic:GEF structrogram editor
Current Time: Thu Nov 27 19:55:59 EST 2025
Powered by FUDForum. Page generated in 0.04335 seconds
