| Xerces exception after using BIRT engine [message #246182] |
Tue, 03 July 2007 13:06  |
This is a multipart message in MIME format.
--=_alternative 005DFCD4C125730D_=
Content-Type: text/plain; charset="US-ASCII"
I'm getting some problems to the WAS classloader I think caused by the
plugins "org.apache.xerces" and jars xercesImpl.jar, xml-apis.jar. I tryed
also to remove them from the platform directory of BIRT and the report
engine still can work and the report are created correctly (I suppose BIRT
use the default xerces libs of the WAS in this case). In any case after I
started the BIRT engine framework I cannot directly use anymore the
xcerces library I'm getting exception below. (I'm using xerces also for
another purpose on my application)
Someone have any idea? Thanks a lot.
0000001b SystemErr R
java.lang.IllegalStateException
0000001b SystemErr R at
org.eclipse.osgi.framework.internal.protocol.MultiplexingURL StreamHandler.toExternalForm(MultiplexingURLStreamHandler.ja va:220)
java.net.URL.toExternalForm(URL.java:933)
java.net.URL.toString(URL.java:919)
java.lang.String.valueOf(String.java:1505)
java.lang.StringBuffer.append(StringBuffer.java:220)
com.ibm.psw.wcl.xerces2.XercesUtility.parseXml(XercesUtility .java:104)
com.ibm.psw.wcl.core.xmlparser.XmlParser.parseXml(XmlParser. java:86)
com.ibm.psw.wcl.core.skin.DefaultSkinManager.parseXml(Defaul tSkinManager.java:636)
com.ibm.psw.wcl.core.skin.DefaultSkinManager.parse(DefaultSk inManager.java:601)
com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:427)
com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:394)
com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:417)
com.ibm.psw.wcl.portlet.WclPortletFacade.setupSkinManager(Wc lPortletFacade.java:1131)
com.ibm.psw.wcl.portlet.WclPortletFacade.createRenderingCont ext(WclPortletFacade.java:776)
com.ibm.mdr.DrStateMgr.getWebPage(DrStateMgr.java:1378)
com.ibm.mdr.DrRenderer.getWebPage(DrRenderer.java:2286)
com.ibm.mdr.common.CommonPortlet.doView(CommonPortlet.java:1 329)
com.ibm.mdr.DrStandardPortlet.doView(DrStandardPortlet.java: 95)
javax.portlet.GenericPortlet.doDispatch(GenericPortlet.java: 235)
com.ibm.mdr.DrStandardPortlet.render(DrStandardPortlet.java: 127)
com.ibm.ws.portletcontainer.core.PortletServlet.doDispatch(P ortletServlet.java:344)
com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:114)
com.ibm.isclite.container.collaborator.PortletServletCollabo rator.doRender(PortletServletCollaborator.java:68)
com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:105)
com.ibm.ws.portletcontainer.cache.CacheCollaborator.doRender (CacheCollaborator.java:84)
com.ibm.ws.portletcontainer.core.PortletServlet.doDispatch(P ortletServlet.java:240)
com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:82)
com.ibm.isclite.container.collaborator.PortletServletCollabo rator.doDispatch(PortletServletCollaborator.java:122)
com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:74)
com.ibm.ws.portletcontainer.cache.CacheCollaborator.doDispat ch(CacheCollaborator.java:66)
com.ibm.ws.portletcontainer.core.PortletServlet.dispatch(Por tletServlet.java:183)
com.ibm.ws.portletcontainer.core.PortletServlet.doGet(Portle tServlet.java:118)
javax.servlet.http.HttpServlet.service(HttpServlet.java:743)
javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:989)
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:501)
com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleReque st(ServletWrapper.java:464)
com.ibm.wsspi.webcontainer.servlet.GenericServletWrapper.han dleRequest(GenericServletWrapper.java:122)
com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.inclu de(WebAppRequestDispatcher.java:639)
com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerImpl. invoke(PortletInvokerImpl.java:146)
com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerColla boratorChainImpl.doCollaborator(PortletInvokerCollaboratorCh ainImpl.java:70)
com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.invoke(PortletInvokerPerformanceCollaborator.java: 247)
com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.doInvoke(PortletInvokerPerformanceCollaborator.jav a:93)
com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.doRender(PortletInvokerPerformanceCollaborator.jav a:68)
com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerColla boratorChainImpl.doCollaborator(PortletInvokerCollaboratorCh ainImpl.java:57)
com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerImpl. render(PortletInvokerImpl.java:83)
com.ibm.ws.portletcontainer.PortletContainerImpl.doRender(Po rtletContainerImpl.java:115)
com.ibm.ws.portletcontainer.PortletContainerInvokerCollabora torChainImpl.doCollaborator(PortletContainerInvokerCollabora torChainImpl.java:79)
com.ibm.ws.portletcontainer.ext.ExtCollaborator.doRender(Ext Collaborator.java:70)
com.ibm.ws.portletcontainer.PortletContainerInvokerCollabora torChainImpl.doCollaborator(PortletContainerInvokerCollabora torChainImpl.java:67)
com.ibm.ws.portletcontainer.PortletContainerImpl.renderPortl et(PortletContainerImpl.java:87)
com.ibm.ws.portletcontainer.pcinvoker.PortletInvokerImpl$2.r un(PortletInvokerImpl.java:81)
java.security.AccessController.doPrivileged(AccessController .java:242)
com.ibm.ws.portletcontainer.pcinvoker.PortletInvokerImpl.inv okeRender(PortletInvokerImpl.java:79)
com.ibm.isclite.runtime.aggregation.handler.PortletHandler.s ervice(PortletHandler.java:87)
com.ibm.isclite.runtime.aggregation.tags.ContentRenderTag.do StartTag(ContentRenderTag.java:111)
_ibmjsp.html.isclite._Content._jspx_meth_isc_contentRender_0 (_Content.java:1799)
_ibmjsp.html.isclite._Content._jspService(_Content.java:1017 )
com.ibm.ws.jsp.runtime.HttpJspBase.service(HttpJspBase.java: 85)
com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:995)
com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:930)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:118)
com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(W ebAppFilterChain.java:87)
com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter( WebAppFilterManager.java:761)
com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter( WebAppFilterManager.java:673)
com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:498)
com.ibm.ws.jsp.webcontainerext.AbstractJSPExtensionServletWr apper.handleRequest(AbstractJSPExtensionServletWrapper.java: 205)
com.ibm.isclite.runtime.aggregation.tags.ElementRenderTag.do StartTag(ElementRenderTag.java:130)
_ibmjsp.html.isclite._RowContainer._jspx_meth_isc_elementRen der_0(_RowContainer.java:147)
_ibmjsp.html.isclite._RowContainer._jspx_meth_isc_elementLoo p_0(_RowContainer.java:166)
_ibmjsp.html.isclite._RowContainer._jspService(_RowContainer .java:88)
com.ibm.isclite.runtime.aggregation.tags.PageRenderTag.doSta rtTag(PageRenderTag.java:105)
_ibmjsp.secure.isclite.tiles._content._jspx_meth_isc_pageRen der_0(_content.java:344)
_ibmjsp.secure.isclite.tiles._content._jspService(_content.j ava:203)
org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRunti meLibrary.java:1034)
org.apache.jasper.runtime.PageContextImpl.include(PageContex tImpl.java:484)
org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImp l.java:137)
org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:1 77)
org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag .java:756)
org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEnd Tag(InsertTag.java:881)
org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag. java:473)
_ibmjsp.secure.isclite.tiles._master._jspx_meth_tiles_insert _2(_master.java:294)
_ibmjsp.secure.isclite.tiles._master._jspService(_master.jav a:182)
com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forwa rd(WebAppRequestDispatcher.java:321)
org.apache.struts.action.RequestProcessor.doForward(RequestP rocessor.java:1070)
org.apache.struts.tiles.TilesRequestProcessor.doForward(Tile sRequestProcessor.java:273)
org.apache.struts.tiles.TilesRequestProcessor.processTilesDe finition(TilesRequestProcessor.java:253)
org.apache.struts.tiles.TilesRequestProcessor.processForward Config(TilesRequestProcessor.java:308)
com.ibm.isclite.container.controller.InformationController.p rocessForwardConfig(InformationController.java:206)
org.apache.struts.action.RequestProcessor.process(RequestPro cessor.java:279)
org.apache.struts.action.ActionServlet.process(ActionServlet .java:1486)
org.apache.struts.action.ActionServlet.doGet(ActionServlet.j ava:510)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:145)
com.ibm.ws.console.core.servlet.WSCUrlFilter.setUpCommandAss istence(WSCUrlFilter.java:792)
com.ibm.ws.console.core.servlet.WSCUrlFilter.continueStoring TaskState(WSCUrlFilter.java:363)
com.ibm.ws.console.core.servlet.WSCUrlFilter.doFilter(WSCUrl Filter.java:229)
com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilte r(FilterInstanceWrapper.java:190)
com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:130)
com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRe quest(CacheServletWrapper.java:90)
com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContai ner.java:744)
com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebCont ainer.java:1433)
com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChanne lLink.java:112)
com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleD iscrimination(HttpInboundLink.java:454)
com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleN ewInformation(HttpInboundLink.java:383)
com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.com plete(HttpICLReadCallback.java:102)
com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCom pletedCallback.complete(SSLReadServiceContext.java:1815)
com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.future Completed(AioReadCompletionListener.java:165)
com.ibm.io.async.AbstractAsyncFuture.invokeCallback(Abstract AsyncFuture.java:217)
com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(As yncChannelFuture.java:161)
com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136)
com.ibm.io.async.ResultHandler.complete(ResultHandler.java:1 95)
com.ibm.io.async.ResultHandler.runEventProcessingLoop(Result Handler.java:743)
com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:873)
com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
0000001b SystemErr R java.lang.IllegalStateException<br>
0000001b SystemErr R at org.eclipse.osgi.framework.internal.protocol.MultiplexingURL StreamHandler.toExternalForm(MultiplexingURLStreamHandler.ja va:220) <br>
0000001b SystemErr R at java.net.URL.toExternalForm(URL.java:933)<br>
0000001b SystemErr R at java.net.URL.toString(URL.java:919)<br>
0000001b SystemErr R at java.lang.String.valueOf(String.java:1505)<br>
0000001b SystemErr R at java.lang.StringBuffer.append(StringBuffer.java:220)<br>
0000001b SystemErr R at com.ibm.psw.wcl.xerces2.XercesUtility.parseXml(XercesUtility .java:104) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.xmlparser.XmlParser.parseXml(XmlParser. java:86) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.skin.DefaultSkinManager.parseXml(Defaul tSkinManager.java:636) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.skin.DefaultSkinManager.parse(DefaultSk inManager.java:601) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:427) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:394) <br>
0000001b SystemErr R at com.ibm.psw.wcl.core.skin.DefaultSkinManager.loadSkins(Defau ltSkinManager.java:417) <br>
0000001b SystemErr R at com.ibm.psw.wcl.portlet.WclPortletFacade.setupSkinManager(Wc lPortletFacade.java:1131) <br>
0000001b SystemErr R at com.ibm.psw.wcl.portlet.WclPortletFacade.createRenderingCont ext(WclPortletFacade.java:776) <br>
0000001b SystemErr R at com.ibm.mdr.DrStateMgr.getWebPage(DrStateMgr.java:1378)<br>
0000001b SystemErr R at com.ibm.mdr.DrRenderer.getWebPage(DrRenderer.java:2286)<br>
0000001b SystemErr R at com.ibm.mdr.common.CommonPortlet.doView(CommonPortlet.java:1 329) <br>
0000001b SystemErr R at com.ibm.mdr.DrStandardPortlet.doView(DrStandardPortlet.java: 95) <br>
0000001b SystemErr R at javax.portlet.GenericPortlet.doDispatch(GenericPortlet.java: 235) <br>
0000001b SystemErr R at com.ibm.mdr.DrStandardPortlet.render(DrStandardPortlet.java: 127) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServlet.doDispatch(P ortletServlet.java:344) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:114) <br>
0000001b SystemErr R at com.ibm.isclite.container.collaborator.PortletServletCollabo rator.doRender(PortletServletCollaborator.java:68) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:105) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.cache.CacheCollaborator.doRender (CacheCollaborator.java:84) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServlet.doDispatch(P ortletServlet.java:240) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:82) <br>
0000001b SystemErr R at com.ibm.isclite.container.collaborator.PortletServletCollabo rator.doDispatch(PortletServletCollaborator.java:122) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServletCollaboratorC hainImpl.doCollaborator(PortletServletCollaboratorChainImpl. java:74) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.cache.CacheCollaborator.doDispat ch(CacheCollaborator.java:66) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServlet.dispatch(Por tletServlet.java:183) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.core.PortletServlet.doGet(Portle tServlet.java:118) <br>
0000001b SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:743) <br>
0000001b SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:856) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:989) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:501) <br>
0000001b SystemErr R at com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleReque st(ServletWrapper.java:464) <br>
0000001b SystemErr R at com.ibm.wsspi.webcontainer.servlet.GenericServletWrapper.han dleRequest(GenericServletWrapper.java:122) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.inclu de(WebAppRequestDispatcher.java:639) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerImpl. invoke(PortletInvokerImpl.java:146) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerColla boratorChainImpl.doCollaborator(PortletInvokerCollaboratorCh ainImpl.java:70) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.invoke(PortletInvokerPerformanceCollaborator.java: 247) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.doInvoke(PortletInvokerPerformanceCollaborator.jav a:93) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.ext.PortletInvokerPerformanceCol laborator.doRender(PortletInvokerPerformanceCollaborator.jav a:68) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerColla boratorChainImpl.doCollaborator(PortletInvokerCollaboratorCh ainImpl.java:57) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.invoker.impl.PortletInvokerImpl. render(PortletInvokerImpl.java:83) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.PortletContainerImpl.doRender(Po rtletContainerImpl.java:115) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.PortletContainerInvokerCollabora torChainImpl.doCollaborator(PortletContainerInvokerCollabora torChainImpl.java:79) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.ext.ExtCollaborator.doRender(Ext Collaborator.java:70) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.PortletContainerInvokerCollabora torChainImpl.doCollaborator(PortletContainerInvokerCollabora torChainImpl.java:67) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.PortletContainerImpl.renderPortl et(PortletContainerImpl.java:87) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.pcinvoker.PortletInvokerImpl$2.r un(PortletInvokerImpl.java:81) <br>
0000001b SystemErr R at java.security.AccessController.doPrivileged(AccessController .java:242) <br>
0000001b SystemErr R at com.ibm.ws.portletcontainer.pcinvoker.PortletInvokerImpl.inv okeRender(PortletInvokerImpl.java:79) <br>
0000001b SystemErr R at com.ibm.isclite.runtime.aggregation.handler.PortletHandler.s ervice(PortletHandler.java:87) <br>
0000001b SystemErr R at com.ibm.isclite.runtime.aggregation.tags.ContentRenderTag.do StartTag(ContentRenderTag.java:111) <br>
0000001b SystemErr R at _ibmjsp.html.isclite._Content._jspx_meth_isc_contentRender_0 (_Content.java:1799) <br>
0000001b SystemErr R at _ibmjsp.html.isclite._Content._jspService(_Content.java:1017 ) <br>
0000001b SystemErr R at com.ibm.ws.jsp.runtime.HttpJspBase.service(HttpJspBase.java: 85) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:995) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:930) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:118) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(W ebAppFilterChain.java:87) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter( WebAppFilterManager.java:761) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter( WebAppFilterManager.java:673) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:498) <br>
0000001b SystemErr R at com.ibm.ws.jsp.webcontainerext.AbstractJSPExtensionServletWr apper.handleRequest(AbstractJSPExtensionServletWrapper.java: 205) <br>
0000001b SystemErr R at com.ibm.isclite.runtime.aggregation.tags.ElementRenderTag.do StartTag(ElementRenderTag.java:130) <br>
0000001b SystemErr R at _ibmjsp.html.isclite._RowContainer._jspx_meth_isc_elementRen der_0(_RowContainer.java:147) <br>
0000001b SystemErr R at _ibmjsp.html.isclite._RowContainer._jspx_meth_isc_elementLoo p_0(_RowContainer.java:166) <br>
0000001b SystemErr R at _ibmjsp.html.isclite._RowContainer._jspService(_RowContainer .java:88) <br>
0000001b SystemErr R at com.ibm.isclite.runtime.aggregation.tags.PageRenderTag.doSta rtTag(PageRenderTag.java:105) <br>
0000001b SystemErr R at _ibmjsp.secure.isclite.tiles._content._jspx_meth_isc_pageRen der_0(_content.java:344) <br>
0000001b SystemErr R at _ibmjsp.secure.isclite.tiles._content._jspService(_content.j ava:203) <br>
0000001b SystemErr R at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRunti meLibrary.java:1034) <br>
0000001b SystemErr R at org.apache.jasper.runtime.PageContextImpl.include(PageContex tImpl.java:484) <br>
0000001b SystemErr R at org.apache.struts.tiles.TilesUtilImpl.doInclude(TilesUtilImp l.java:137) <br>
0000001b SystemErr R at org.apache.struts.tiles.TilesUtil.doInclude(TilesUtil.java:1 77) <br>
0000001b SystemErr R at org.apache.struts.taglib.tiles.InsertTag.doInclude(InsertTag .java:756) <br>
0000001b SystemErr R at org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEnd Tag(InsertTag.java:881) <br>
0000001b SystemErr R at org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag. java:473) <br>
0000001b SystemErr R at _ibmjsp.secure.isclite.tiles._master._jspx_meth_tiles_insert _2(_master.java:294) <br>
0000001b SystemErr R at _ibmjsp.secure.isclite.tiles._master._jspService(_master.jav a:182) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.webapp.WebAppRequestDispatcher.forwa rd(WebAppRequestDispatcher.java:321) <br>
0000001b SystemErr R at org.apache.struts.action.RequestProcessor.doForward(RequestP rocessor.java:1070) <br>
0000001b SystemErr R at org.apache.struts.tiles.TilesRequestProcessor.doForward(Tile sRequestProcessor.java:273) <br>
0000001b SystemErr R at org.apache.struts.tiles.TilesRequestProcessor.processTilesDe finition(TilesRequestProcessor.java:253) <br>
0000001b SystemErr R at org.apache.struts.tiles.TilesRequestProcessor.processForward Config(TilesRequestProcessor.java:308) <br>
0000001b SystemErr R at com.ibm.isclite.container.controller.InformationController.p rocessForwardConfig(InformationController.java:206) <br>
0000001b SystemErr R at org.apache.struts.action.RequestProcessor.process(RequestPro cessor.java:279) <br>
0000001b SystemErr R at org.apache.struts.action.ActionServlet.process(ActionServlet .java:1486) <br>
0000001b SystemErr R at org.apache.struts.action.ActionServlet.doGet(ActionServlet.j ava:510) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:145) <br>
0000001b SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.setUpCommandAss istence(WSCUrlFilter.java:792) <br>
0000001b SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.continueStoring TaskState(WSCUrlFilter.java:363) <br>
0000001b SystemErr R at com.ibm.ws.console.core.servlet.WSCUrlFilter.doFilter(WSCUrl Filter.java:229) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilte r(FilterInstanceWrapper.java:190) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(We bAppFilterChain.java:130) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRe quest(CacheServletWrapper.java:90) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContai ner.java:744) <br>
0000001b SystemErr R at com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebCont ainer.java:1433) <br>
0000001b SystemErr R at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChanne lLink.java:112) <br>
0000001b SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleD iscrimination(HttpInboundLink.java:454) <br>
0000001b SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleN ewInformation(HttpInboundLink.java:383) <br>
0000001b SystemErr R at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.com plete(HttpICLReadCallback.java:102) <br>
0000001b SystemErr R at com.ibm.ws.ssl.channel.impl.SSLReadServiceContext$SSLReadCom pletedCallback.complete(SSLReadServiceContext.java:1815) <br>
0000001b SystemErr R at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.future Completed(AioReadCompletionListener.java:165) <br>
0000001b SystemErr R at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(Abstract AsyncFuture.java:217) <br>
0000001b SystemErr R at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(As yncChannelFuture.java:161) <br>
0000001b SystemErr R at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136) <br>
0000001b SystemErr R at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:1 95) <br>
0000001b SystemErr R at com.ibm.io.async.ResultHandler.runEventProcessingLoop(Result Handler.java:743) <br>
0000001b SystemErr R at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:873) <br>
0000001b SystemErr R at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)<br >
[7/3/07 12:34:35:355 CEST] 0000001b SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:743) <br>
[7/3/07 12:34:35:355 CEST] 0000001b SystemErr R at javax.servlet.http.HttpServlet.service(HttpServlet.java:856) <br>
[7/3/07 12:34:35:355 CEST] 0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servl etWrapper.java:989) <br>
[7/3/07 12:34:35:355 CEST] 0000001b SystemErr R at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest (ServletWrapper.java:501) <br>
[7/3/07 </font>
--=_alternative 005DFCD4C125730D_=--
| Re: Xerces exception after using BIRT engine [message #246187 is a reply to message #246182] |
Tue, 03 July 2007 14:36  |
Originally posted by: mdavis.pashllc.com
Maria,
Not sure, but issue sounds like the infamous jar collision problem.
Same jars, different jar versions, used inside the same JVM.
1. If you remove BIRT completely from WAS, does everything work
correctly?
2. Once WAS is working, if BIRT is added without Xerces, does BIRT
and WAS work correctly?
I think I would get back to the basic configuration of WAS (without
BIRT), and get everything working.
Theoretically, you could always stick BIRT in a separate JVM
instances. The entire concept behind Portlets is the merging of
diverse applications, that could/should be running on separate JVMs,
with the JVM tuned for the application. Basically, a separate Tomcat
instances tuned for BIRT.
- Malcolm
maria baldassarri wrote:
> Hello,
> tryed also to remove them from the platform directory of BIRT and the
> report engine still can work and the report are created correctly (I
> suppose BIRT use the default xerces libs of the WAS in this case). In
> any case after I started the BIRT engine framework I cannot directly use
> anymore the xcerces library I'm getting exception below. (I'm using
> xerces also for another purpose on my application)
> [7/3/07
FUDForum. Page generated in 0.03961 seconds
