| BIRT 2.2 - "Can't re-generate content" errors [message #246129] |
Tue, 03 July 2007 10:09 |
Originally posted by: phil.issler.dataflux.com
I have a report that worked great in BIRT 2.1, but is having problems in
BIRT 2.2.
The report in question references report items from a report library.
One such item contains images that are embedded in the report library.
The same item also contains some dynamic text elements. When I try to
generate the report in the BIRT 2.2 web viewer, as well as withiin my
own web application that embeds the BIRT 2.2 report engine, I get the
following errors:
java.lang.IllegalStateException: can't create the content for image item
org.eclipse.birt.report.engine.internal.document.v4.ImageIte mExecutor.doCreateContent(ImageItemExecutor.java:40)
org.eclipse.birt.report.engine.internal.document.v4.ReportIt emExecutor.execute(ReportItemExecutor.java:270)
org.eclipse.birt.report.engine.internal.document.v4.Containe rExecutor.prepareChildExecutor(ContainerExecutor.java:213)
...snip..
and
java.lang.IllegalStateException: can't re-generate content for MultiLineItem
org.eclipse.birt.report.engine.internal.document.v4.DynamicT extItemExecutor.doCreateContent(DynamicTextItemExecutor.java :41)
...snip..
The embedded images and dynamic text elements under consideration simply
do not show up in the report output. The rest of the report renders OK.
The really odd thing is that the report renders fine in the designer
using the Preview tab, as well as the "View Report as" drop down menu
(with the exception of View Report in Web Viewer, of course).
Embedded images that are included directly in the report (not from a
report library) render fine in all cases.
Is there some new setting or API call that I need to make in order for
this case to work properly in BIRT 2.2?
-Phil
FUDForum. Page generated in 0.04795 seconds
