Ant Plugins missing in M9 [message #246115] |
Thu, 27 May 2004 05:28  |
Originally posted by: leo_zen.gmx.at
Is there a reason why in M9 the Ant-Dirs are not any longer in the default
package?
The reason for asking, is that I'm missing 'org.apache.xerces_4.0.13' with
the 'xmlParserAPIs.jar' and 'xercesImpl.jar'-files without them I get in
Ant an Error-Message saying SAXException which is fixed with the two
jar-files. Since, it's not included any more, it has to be done manually.
Re: Ant Plugins missing in M9 [message #246721 is a reply to message #246563] |
Fri, 28 May 2004 03:27   |
I never said, they were included in the org.apache.ant, but seems still
confusing for me. It's quite hard to distinguish, if it's the ant-plugin
or the xerces-plugin which is missing, because ant will not run without
the xerces-jars.
Even more I still do not understand, why the 'xerces' are not any longer
included, especially the Error
java.lang.NoClassDefFoundError: org/xml/sax/SAXException
seems to occur quite often (when searching within this forum, there are
many responses, but only few suggestion for fixing).
1) Why the xerces-plugin (or however you wanna call it) is no longer
included in M9?
2) Why is there no 'default' fix for it? e.g. the Ant-Build has per
default the Ant-Home included, then why not also include the xerces-file
per default?
LeO
Darin Swanson wrote:
> The xerces JARs were not included in the org.apache.ant plugin
> The xerces plugin used to be included in the Eclipse SDK
> Darins
> "LeO" <leo_zen@gmx.at> wrote in message news:c95b9i$c08$1@eclipse.org...
> > Sorry, but this 'have never been included with the Ant plugin' I do not
> > understand. In M8 it was included! So, what are you refering to?
> > LeO
> > > The xerces JARs have never been included with the Ant plugin.
> > > You are correct that in some situations you are required to do it
> manually.
> > > We have a bug report to add the Xerces JARs to the Ant plugin but this
> is
> > > likely not going to happen for 3.0
> > > https://bugs.eclipse.org/bugs/show_bug.cgi?id=62055
> > > Darins
> > > "LeO" <leo_zen@gmx.at> wrote in message news:c94cbt$vjc$1@eclipse.org...
> default
> > > > package?
> with
> in
> manually.
Re: Ant Plugins missing in M9 [message #246906 is a reply to message #246721] |
Fri, 28 May 2004 13:06  |
If you run Ant in a 1.4.* VM the JAXP implementation of an XML parser
provided by the VM will be used and builds will generally work fine.
Otherwise you need to add the Xerces JARs manually. We plan to address this
in the future with
The "Xerces" issue has been discussed here many times so if you want the
history please use the archives.
Darins
"LeO" <leo_zen@gmx.at> wrote in message news:c96plh$v5r$1@eclipse.org...
> the xerces-jars.
> included in M9?
> per default?
> LeO
> > Darins
not
> > > LeO
> > manually.
this
> > is
> > > > Darins
> > default
> > > > > package?
> > with
get
> > in
two
> > manually.
FUDForum. Page generated in 0.24499 seconds
