Home » Eclipse Projects » GEF » [ZEST] Initialize Graph with IGNORE_INVISIBLE_LAYOUT
[ZEST] Initialize Graph with IGNORE_INVISIBLE_LAYOUT [message #246087] Tue, 04 November 2008 19:17 Go to next message
I'm trying to initialize a graph with the IGNORE_INVISIBLE_LAYOUT style.
new Graph(parent, SWT.NONE | ZestStyles.IGNORE_INVISIBLE_LAYOUT) and
new Graph(parent, ZestStyles.IGNORE_INVISIBLE_LAYOUT)
produce an "Could not open the editor: Invalid style being set on
FigureCanvas" error
while
new Graph(parent, SWT.NONE & ZestStyles.IGNORE_INVISIBLE_LAYOUT) passes
this stage but doesn't work.
What is the proper way to do this?
Dimitris
Re: [ZEST] Initialize Graph with IGNORE_INVISIBLE_LAYOUT [message #246128 is a reply to message #246087] Thu, 06 November 2008 12:31 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Looking at your example, it appears you are doing this correctly. The
error is a Draw2D error (Zest should not be passing that style all the
way to draw2d).
Can you open a bug for this?
cheers,
Ian
Dimitrios Kolovos wrote:
> FigureCanvas" error
> while
> Cheers,
> Dimitris
Re: [ZEST] Initialize Graph with IGNORE_INVISIBLE_LAYOUT [message #246149 is a reply to message #246128] Fri, 07 November 2008 07:54 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=254584
Dimitris
> way to draw2d).
> cheers,
> Ian
>> FigureCanvas" error
>> while
>> passes this stage but doesn't work.
>> Cheers,
>> Dimitris
Previous Topic:double line
Next Topic:Command LifeCYcle
Current Time: Sat Nov 08 16:35:09 EST 2025
Powered by FUDForum. Page generated in 0.03639 seconds
