Home » Newcomers » Newcomers » directory filter for import exiting projects
directory filter for import exiting projects [message #245961] Fri, 18 January 2008 17:24
Originally posted by: brett.eclipse.rocknut.com
how can i configure the "file->import->existing projects into workspace"
to ignore all directories named ".stuff_i_do_not_care_about"?
our dev group is moving to a new version control system that creates
directories everywhere which contain internally used versioning information
unfortunately that internal information contains copies of files which the
eclipse import tries to import.
this results in many versions of the same projects getting created by the
import wizard
these directories are marked as hidden - is there a way to filter out
hidden directories?
other suggestions welcome
thanks,
brett
OS: win xp pro
eclipse version:
Version: 3.1.2
Build id: M20060118-1600
Previous Topic:How to use MyFaces trinidad
Next Topic:disabling fast view for results of search, type/call hierarchy, etc
Current Time: Sun Jul 13 15:45:33 EDT 2025
Powered by FUDForum. Page generated in 0.04382 seconds
