Home » Language IDEs » Java Development Tools (JDT) » eclipse and cvs ignore
eclipse and cvs ignore [message #245903] Wed, 18 July 2007 01:52 Go to next message
Originally posted by: fluca1978.infinito.it
Hi all,
I'm not very expert in using eclipse with cvs, thus you have some
documentation to point me at please advice. By the way, is there a way to
configure eclipse to ignore some files/folder from the cvs commit? For
instance I don't like to get the ide committing the .project file and some
other environment specific files.
Luca
Re: eclipse and cvs ignore [message #245909 is a reply to message #245903] Wed, 18 July 2007 04:13 Go to previous messageGo to next message
Luca Ferrari wrote:
>Hi all,
Add a .cvsignore file into your project and commit it.
Dani
>Thanks,
>Luca
Re: eclipse and cvs ignore [message #245924 is a reply to message #245903] Wed, 18 July 2007 09:14 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Luca Ferrari wrote:
> Hi all,
It is usually a good idea to check in the .project and .classpath files,
since those define your project to Eclipse. If they were to be lost or
corrupted you'd have to re-configure the project; or if the project were
to be checked out into another Eclipse installation, you'd usually want
them there so that Eclipse would automatically congfigure the project.
Having said that, you can right-click any file in a CVS-shared project
and choose Team > Add to .cvsignore. Then check in the .cvsignore file.
Hope this helps,
Eric
Re: eclipse and cvs ignore [message #245934 is a reply to message #245924] Wed, 18 July 2007 10:34 Go to previous messageGo to next message
I've tried to do that from the navigator view but the add to .cvsignore item
is not enabled. What am I doing wrong?
Luca
Re: eclipse and cvs ignore [message #245938 is a reply to message #245934] Wed, 18 July 2007 12:13 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
If it has already been committed once or if the parent folder has not
yet been committed once, then it is not available.
In other words the parent folder must have been committed (or at least
registered as going to CVS) and the file itself must never of been
committed.
> Luca
Re: eclipse and cvs ignore [message #245984 is a reply to message #245938] Thu, 19 July 2007 05:26 Go to previous messageGo to next message
How can I remove it from the cvs using the command line without corrupting
the project? Should I checkout the project again?
Luca
Re: eclipse and cvs ignore [message #245989 is a reply to message #245984] Thu, 19 July 2007 06:27 Go to previous messageGo to next message
> Luca
Make a backup copy of your file, then delete it from your project within
Eclipse and commit the deletion. Then, restore the backup copy (now it
should be marked as "new") and do Team => Add to .cvsignore.
By the way, as long as you don't need to store in the CVS the fact you
want to ignore one or more files, you don't need to commit the
..cvsignore file itself: however, in order to avoid Eclipse to force you
to commit it, you may need to add .cvsignore to .cvsignore itself
(sorry, it's not a pun!). As you don't see .cvsignore in the navigator
view, you can do that as follows: type ctrl+shift+R, type .cvsignore,
select the one you're interested in, then, in the editor, add a row for
just .cvsignore
Hope to have been of help.
Mauro.
Re: eclipse and cvs ignore [message #245999 is a reply to message #245989] Thu, 19 July 2007 08:55 Go to previous messageGo to next message
I recommend checking in the .cvsignore too if you will be checking the
project out into another workspace or someone else will check it out. If
you don't check it in, then it is possible that the other workspace
could regenerate the offending file and then check it back in, thereby
defeating the purpose of the .cvsignore in the first place.
Rich
Re: eclipse and cvs ignore [message #246024 is a reply to message #245989] Thu, 19 July 2007 13:11 Go to previous message
> just .cvsignore
It seems it worked!
Thanks.
P.S.
I'll not commit the .cvsignore because I hope other developers will do the
same, and after all they're not supposed to use eclipse!
Previous Topic:Cannot access file from view
Next Topic:Java content assist: Typing in '(' after the method name automatically selected the method...?
Current Time: Tue Jul 22 02:46:21 EDT 2025
Powered by FUDForum. Page generated in 0.27674 seconds
