Home » Newcomers » Newcomers » How to change the default workspace settings
How to change the default workspace settings [message #245724] Wed, 16 January 2008 13:12 Go to next message
Hello
I look around but only found a thread with this topic:
Back in 2005 there was this thread with this question "Default
configuration possible?"
( http://dev.eclipse.org/newslists/news.eclipse.newcomer/msg00 569.html)
No solutions at that time and didn't find more recent thread.
So basicaly here is what I'd like:
when I create a new workspace I'd like it to have my default settings for
all the installed plugins and not the general default settings.
Ie: for Network settings I'd like when the workspace is created to have
automaticaly proxy enabled with the proxy adress and the port.
I know I can do it by import/export..but for a developer station
deployment it means that each time the developer create a workspace he
will have to import default settings. Since eclipse installation is just a
zip file I was wondering if the zip could contains the default settings.
So is this possible to with current eclipse version ? is there plan to
have this ?
regards
Lg
Re: How to change the default workspace settings [message #245729 is a reply to message #245724] Wed, 16 January 2008 13:41 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
You can do some of this with "plugin_customization.ini". Unfortunately, which
settings you can change this way is poorly documented. I think it also means you
have to have a plugin to customize...
Derek
LG wrote:
> Hello
> for all the installed plugins and not the general default settings.
> a zip file I was wondering if the zip could contains the default settings.
> have this ?
> regards
> Lg
Re: How to change the default workspace settings [message #245761 is a reply to message #245729] Thu, 17 January 2008 03:00 Go to previous messageGo to next message
Thanks Derek
So basically what you are saying is that default settings that are dumped
the first time in .../myWorkspace/.metadata are hardcoded in Eclipse ?
lg
which
you
Re: How to change the default workspace settings [message #245766 is a reply to message #245761] Thu, 17 January 2008 03:42 Go to previous messageGo to next message
The are not hardcoded - because you *can* change them with
It's just that the documentation of what the options are, is hard to find...
Derek
LG wrote:
> Thanks Derek
> dumped the first time in .../myWorkspace/.metadata are hardcoded in
> Eclipse ?
> lg
> which
>> means
> you
Re: How to change the default workspace settings [message #245798 is a reply to message #245766] Thu, 17 January 2008 07:01 Go to previous message
Ok, I misunderstood your first reply..
I'll make some tests with "plugin_customization.ini".
thks
lg
Previous Topic:Where to find the identity SAX ContentHandler ?
Next Topic:How to use created Plug in
Current Time: Tue Jul 15 23:51:13 EDT 2025
Powered by FUDForum. Page generated in 0.13428 seconds
