Invoking New / Interface programmatically (from cheatsheet) [message #245523] |
Wed, 11 July 2007 17:37  |
Originally posted by: myawn.ebay.com
I'm trying to put together a cheatsheet for walking developers through a
simple development scenario. One of the first steps is to create a new
Java interface. I'd like this to be a linkable action from the cheatsheet.
- Is there an action already defined I can reference to invoke this
function?
- If not, is there a wizard available where I can write my own simple
action just to invoke the existing wizard?
I have found that NewInterfaceWizardPage is defined in the
org.eclipse.jdt.wizards package, so if neither of the above options
exists, I think I can use this to roll my own Wizard, and then invoke it
from my own custom action -- I just wanted to see if there were reusable
parts for the Wizard and Action before I did that.
Mike
Re: Invoking New / Interface programmatically (from cheatsheet) [message #245617 is a reply to message #245570] |
Thu, 12 July 2007 18:13   |
Paul Webster wrote:
>> a simple development scenario. One of the first steps is to create a
>> new Java interface. I'd like this to be a linkable action from the
>> cheatsheet.
>> function?
>> it from my own custom action -- I just wanted to see if there were
>> reusable parts for the Wizard and Action before I did that.
> There is the new wizard command, org.eclipse.ui.newWizard, and it takes
> an optional ID, newWizardId.
> The 3.3 cheatsheet editor has a command composer that can list available
> options. In 3.3 it looks like it would embed the link for you. It says
> the magic information is:
> org.eclipse.ui.newWizard(newWizardId=org.eclipse.jdt.ui.wiza rds.NewInterfaceCreationWizard)
> Later,
> PW
That's cool -- thanks. I should be moving to Eclipse 3.3 in the next
week or so, as soon as our tools team completes testing with it
(assuming no issues are found).
Mike
Re: Invoking New / Interface programmatically (from cheatsheet) [message #245885 is a reply to message #245617] |
Tue, 17 July 2007 10:15  |
>> available options. In 3.3 it looks like it would embed the link for
>> you. It says the magic information is:
>> Later,
>> PW
Just as an aside, the command itself would be available in 3.2 and
possibly even in 3.1 ...
The command composer can a more friendly way to track down commands than
searching through the Plug-in Registry view :-)
PW
FUDForum. Page generated in 0.26650 seconds
