Home » Eclipse Projects » Eclipse Platform » EXCEPTION_ACCESS_VIOLATION
EXCEPTION_ACCESS_VIOLATION [message #245363] |
Wed, 26 May 2004 01:23  |
Originally posted by: john.starfriend.net
Eclipse doesn't fire up any more. I don't know what has changed - it used
to run fine. Other Java programs work ok.
Any help would be very much appreciated.
Here is the log output:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77F83378
Function=RtlInitUnicodeString+0x1B
Library=C:\WINNT\system32\ntdll.dll
Current Java thread:
at org.eclipse.swt.internal.win32.OS.ExpandEnvironmentStringsW( Native
Method)
org.eclipse.swt.internal.win32.OS.ExpandEnvironmentStrings(O S.java:1353)
at org.eclipse.swt.program.Program.getKeyValue(Program.java:113 )
at org.eclipse.swt.program.Program.getProgram(Program.java:135)
at org.eclipse.swt.program.Program.getPrograms(Program.java:165 )
org.eclipse.ui.internal.registry.EditorDescriptor.findProgra m(EditorDescriptor.java:76)
org.eclipse.ui.internal.registry.EditorDescriptor.loadValues (EditorDescriptor.java:212)
org.eclipse.ui.internal.registry.EditorRegistry.loadAssociat ions(EditorRegistry.java:521)
org.eclipse.ui.internal.registry.EditorRegistry.initializeFr omStorage(EditorRegistry.java:453)
org.eclipse.ui.internal.registry.EditorRegistry.<init>(EditorRegistry.java:64)
org.eclipse.ui.internal.WorkbenchPlugin.getEditorRegistry(Wo rkbenchPlugin.java:234)
at org.eclipse.ui.internal.EditorManager$7.run(EditorManager.ja va:908)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.ui.internal.EditorManager.busyRestoreEditor(Edit orManager.java:864)
at org.eclipse.ui.internal.EditorManager$6.run(EditorManager.ja va:857)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.restoreEditor(EditorMa nager.java:853)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:756)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2263)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1327)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Dynamic libraries:
0x00400000 - 0x00407000 C:\WINNT\system32\javaw.exe
0x77F80000 - 0x77FFD000 C:\WINNT\system32\ntdll.dll
0x7C2D0000 - 0x7C332000 C:\WINNT\system32\ADVAPI32.dll
0x7C570000 - 0x7C628000 C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77DA1000 C:\WINNT\system32\RPCRT4.DLL
0x77E10000 - 0x77E75000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7E000 C:\WINNT\system32\GDI32.DLL
0x78000000 - 0x78045000 C:\WINNT\system32\MSVCRT.dll
0x08000000 - 0x08136000 C:\Program
Files\Java\j2re1.4.2_01\bin\client\jvm.dll
0x77570000 - 0x775A0000 C:\WINNT\system32\WINMM.dll
0x681A0000 - 0x681A7000 C:\WINNT\system32\serwvdrv.dll
0x66740000 - 0x66747000 C:\WINNT\system32\umdmxfrm.dll
0x6BD00000 - 0x6BD0D000 C:\WINNT\system32\SYNCOR11.DLL
0x10000000 - 0x10007000 C:\Program Files\Java\j2re1.4.2_01\bin\hpi.dll
0x007E0000 - 0x007EE000 C:\Program Files\Java\j2re1.4.2_01\bin\verify.dll
0x007F0000 - 0x00808000 C:\Program Files\Java\j2re1.4.2_01\bin\java.dll
0x00810000 - 0x0081D000 C:\Program Files\Java\j2re1.4.2_01\bin\zip.dll
0x34A40000 - 0x34A48000
C:\eclipse\plugins\org.eclipse.core.resources.win32_2.1.0\os \win32\x86\core_2_1_0a.dll
0x34B60000 - 0x34BA7000
C:\eclipse\plugins\org.eclipse.swt.win32_2.1.1\os\win32\x86\ swt-win32-2135.dll
0x77A50000 - 0x77B3F000 C:\WINNT\system32\ole32.dll
0x71710000 - 0x71794000 C:\WINNT\system32\COMCTL32.dll
0x76B30000 - 0x76B6E000 C:\WINNT\system32\comdlg32.dll
0x70A70000 - 0x70AD5000 C:\WINNT\system32\SHLWAPI.DLL
0x782F0000 - 0x78538000 C:\WINNT\system32\SHELL32.DLL
0x779B0000 - 0x77A4B000 C:\WINNT\system32\OLEAUT32.dll
0x75E60000 - 0x75E7A000 C:\WINNT\system32\IMM32.dll
0x350D0000 - 0x351A4000 C:\WINNT\system32\nView.dll
0x690A0000 - 0x690AB000 C:\WINNT\system32\PSAPI.DLL
0x77820000 - 0x77827000 C:\WINNT\system32\VERSION.dll
0x759B0000 - 0x759B6000 C:\WINNT\system32\LZ32.DLL
0x695E0000 - 0x69609000 C:\WINNT\system32\OLEPRO32.DLL
0x72800000 - 0x72846000 C:\WINNT\system32\DDRAW.dll
0x728A0000 - 0x728A6000 C:\WINNT\system32\DCIMAN32.dll
0x35720000 - 0x35727000 C:\Program
Files\Logitech\MouseWare\System\LgWndHk.dll
0x35730000 - 0x35744000 C:\freeserve\freeserveconnectionkit\Freehook.dll
0x35770000 - 0x357A1000 C:\Program Files\TextBridge Pro
Millennium\Bin\TBMHOOK.dll
0x719B0000 - 0x719B8000 C:\WINNT\system32\SHFOLDER.dll
0x77800000 - 0x7781E000 C:\WINNT\system32\WINSPOOL.DRV
0x76620000 - 0x76630000 C:\WINNT\system32\MPR.DLL
0x69640000 - 0x6965F000 C:\WINNT\system32\oleacc.dll
0x77920000 - 0x77943000 C:\WINNT\system32\imagehlp.dll
0x72A00000 - 0x72A2D000 C:\WINNT\system32\DBGHELP.dll
Heap at VM Abort:
Heap
def new generation total 576K, used 416K [0x10010000, 0x100b0000,
0x12770000)
eden space 512K, 71% used [0x10010000, 0x1006b818, 0x10090000)
from space 64K, 79% used [0x100a0000, 0x100acb78, 0x100b0000)
to space 64K, 0% used [0x10090000, 0x10090000, 0x100a0000)
tenured generation total 2472K, used 2356K [0x12770000, 0x129da000,
0x30010000)
the space 2472K, 95% used [0x12770000, 0x129bd160, 0x129bd200,
0x129da000)
compacting perm gen total 7168K, used 7159K [0x30010000, 0x30710000,
0x34010000)
the space 7168K, 99% used [0x30010000, 0x3070ddd0, 0x3070de00,
0x30710000)
Local Time = Wed May 26 06:08:48 2004
Elapsed Time = 14
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_01-b06 mixed mode)
John Pedersen
Re: EXCEPTION_ACCESS_VIOLATION [message #245552 is a reply to message #245363] |
Wed, 26 May 2004 09:15   |
Hi John,
This has been fixed in the 3.0 stream. The reports for it (including the
perceived causes, which are likely of interest to you if you can't upgrade
to 3.0) are:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=40884
https://bugs.eclipse.org/bugs/show_bug.cgi?id=47279
Grant
"John Pedersen" <john@starfriend.net> wrote in message
news:c919jk$r6d$1@eclipse.org...
> PC=0x77F83378
> Method)
> at
> at
or.java:76)
> at
r.java:212)
> at
try.java:521)
> at
Registry.java:453)
> at
4)
> at
va:234)
> at
:1006)
> at
64)
> at
> at
> at
> at
27)
> at
:1006)
> at
1093)
> at
a:858)
> Dynamic libraries:
2_1_0a.dll
ll
> Heap at VM Abort:
> Heap
> 0x12770000)
> 0x30010000)
> 0x129da000)
> 0x34010000)
> 0x30710000)
> Elapsed Time = 14
> John Pedersen
Current Time: Sat Jul 26 18:11:08 EDT 2025
Powered by FUDForum. Page generated in 0.03113 seconds
