Customisation of Generated Viewer [message #24095] |
Wed, 22 February 2006 06:31  |
Hello All,
I'm quite new to the EMF and I have few questions regarding
editor generator configuration. Any suggestions/links are welcomed.
1. Is there a way to configure property viewer to show for some of the
properties a multiline text area instead of a text field?
In fact, the question has a larger impact: how can I configure EMF
generator to generate a custom view? For example I would like to
configure the images to display for each node, the kind of editors to
use for each property (eg. textarea instead of textfield)? To go deeper,
it would be nice to be able to hide some of the properties using a
expandable composite.
2. I also saw there is a tabbed properties pane which looks much cooler
than the traditional properties view. Is there a plan to integrate
something similar?
3. Is there an example of a customised view?
Thank you,
Stefan.
PS: ....and not to forget...emf rocks...yaaa
Re: Customisation of Generated Viewer [message #24205 is a reply to message #24095] |
Wed, 22 February 2006 07:00  |
--------------060206020305090704000701
Stefan,
My comments are below.
stefan wrote:
>Hello All,
You need to create customized PropertyDescriptor and override
createPropertyEditor. Using search like this can help turn up previous
answers:
E.g., this one
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 1880.html
The images are determined by the item provider's getImage method.
Typically you'll just replace the generated images with your own. The
image used in the property can be passed to the property descriptor as
you create it in the feature-specific methods called by
getPropertyDescriptors.
The editor is determined by the createPropertyEditor method. You might
change that method to recognize particular types as needing a particular
type of cell editor. Or you might add annotations to your Ecore model
which can be examined at runtime.
> To go deeper,
Have a look at how the GenModel item providers do the grouping; it's
just more data to pass to the property descriptor as you create it.
>something similar?
There is a desire to do this, but no actual resource to make it happen.
You might want to look at the forms editor support contributed to EMF
corner.
Looking at the models we provide, such as GenModelItemProvider might help.
>Thank you,
> Stefan.
Thanks. We like to think so. ;-)
Content-Type: multipart/related;
boundary="------------080008030905070503070609"
--------------080008030905070503070609
<html>
<head>
</head>
Stefan,<br>
<br>
My comments are below.<br>
<br>
stefan wrote:
<blockquote cite="middthi2p$j3d$1@utils.eclipse.org" type="cite">
<pre wrap="">Hello All,
</pre>
</blockquote>
answers:<br>
<blockquote><img src="cid:part1.06060509.09060509@ca.ibm.com" alt=""><br>
</blockquote>
E.g., this one <a
href=" http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 1880.html"> http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 1880.html</a><br>
<pre wrap="">
configure the images to display for each node, </pre>
</blockquote>
getPropertyDescriptors.<br>
<pre wrap="">the kind of editors to
use for each property (eg. textarea instead of textfield)?</pre>
</blockquote>
particular type of cell editor. Or you might add annotations to your
Ecore model which can be examined at runtime.<br>
<pre wrap=""> To go deeper,
</pre>
</blockquote>
just more data to pass to the property descriptor as you create it.<br>
<pre wrap="">
something similar?
</pre>
</blockquote>
happen. You might want to look at the forms editor support contributed
to EMF corner.<br>
<pre wrap="">
</pre>
</blockquote>
help.<br>
<pre wrap="">
Thank you,
Stefan.
</pre>
</blockquote>
Thanks. We like to think so. ;-)<br>
<br>
</body>
</html>
Content-Type: image/jpeg;
name="moz-screenshot-7.jpg"
Content-ID: <part1.06060509.09060509@ca.ibm.com>
Content-Disposition: inline;
filename="moz-screenshot-7.jpg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAGHA4kDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD1CiiqGo3awSW9u8wt0nJU zngLj+EHoGPb
PofpWFSapxcnsjSK5nZD5NTtYpHjZpCUOHZIXZVPXBYAgH2zT7bULS8Zkt7i OR1GWQN8wHuO
oqG4ljsbVY0iaOKP5Y4kPzOx5wD3J5JJ9yayJdIv55G1KOQDU4GBLYO1ARkI fVCOP161w4HF
1sW5NQtFdTWrCFNJN6s6aq1/qNpplv8AaL2dYYtwXe2cZNRaXqcWp2zOo2TR OY54SeY3HUH+
h7iq+uf63Rf+wvaf+jBXorUxZD/wmPh7/oKwfr/hR/wmPh7/AKCsH6/4VleK fE/jU/Ei+0HQ
L+CC2iiWUGeOMIiiNWbLMp9Seff0rktQ+JPj2y3FNXhmVf4ltIwD+BTNdscF JxUroSuz0L/h
MfD3/QVg/X/Cj/hMfD3/AEFYP1/wrpvAGrXuueB9N1LUZfNu51cyPtC5xIwH AAHQCtm31Wxu
tLtdTiuY/sd2kTwSv8gcSY8v72DliygA85IHWuaUOVtPoK5wH/CY+Hv+grB+ v+FH/CY+Hv8A
oKwfr/hXo8c8MzzJFLG7wvslVWBKNtDYb0O1lOD2IPepKnlQXPNP+Ex8Pf8A QVg/X/Cj/hMf
D3/QVg/X/Cu7k1vTovtO+4x9mu4rKX5G+WaXy9i9Oc+dHyOBu5IwcaFHKgue af8ACY+Hv+gr
B+v+FH/CY+Hv+grB+v8AhXpdFHKgueaf8Jj4e/6CsH6/4Uf8Jj4e/wCgrB+v +Fel1Xv7630z
Trm/vJPLtbWJ5pn2k7UUEscDk4APSjlQXPPP+Ex8Pf8AQVg/X/Cj/hMfD3/Q Vg/X/CvR4Z4b
lC8EscqB2QsjBgGVirDjuGBBHYgipKOVBc80/wCEx8Pf9BWD9f8ACj/hMfD3 /QVg/X/CvS6K
OVBc80/4THw9/wBBWD9f8KP+Ex8Pf9BWD9f8K9Lqvb31vdz3cMEm+S0lEM42 kbHKLIBz1+V1
PHr65o5UFzzz/hMfD3/QVg/X/Cj/AITHw9/0FYP1/wAK9Loo5UFzzT/hMfD3 /QVg/X/Cj/hM
fD3/AEFYP1/wr0O9vrfT4FmupPLjaWOEHaTl5HWNBx6syj2zzxRe31vp8CzX UnlxtLHCDtJy
8jrGg49WZR7Z54o5UFzzz/hMfD3/AEFYP1/wo/4THw9/0FYP1/wr0uijlQXP NP8AhMfD3/QV
g/X/AAo/4THw9/0FYP1/wr0uq9vfW93PdwwSb5LSUQzjaRscosgHPX5XU8ev rmjlQXPPP+Ex
8Pf9BWD9f8KP+Ex8Pf8AQVg/X/CvS6jnnhtbeW4uJY4YIkLySSMFVFAySSeA AOc0cqC55x/w
mPh7/oKwfr/hR/wmPh7/AKCsH6/4V39nq2m6hcXVvZahaXM9o+y5jhmV2hbJ GHAOVOVIwfQ+
lXKOVBc80/4THw9/0FYP1/wo/wCEx8Pf9BWD9f8ACvS6KOVBc80/4THw9/0F YP1/wo/4THw9
/wBBWD9f8K9LqOGeG5QvBLHKgdkLIwYBlYqw47hgQR2IIo5UFzzj/hMfD3/Q Vg/X/Cj/AITH
w9/0FYP1/wAK7u613R7HUYNOvNVsbe+n2+TbTXCJJJuO1dqk5OSCBjqa0KOV Bc80/wCEx8Pf
9BWD9f8ACj/hMfD3/QVg/X/CvS6KOVBc80/4THw9/wBBWD9f8KP+Ex8Pf9BW D9f8K9HE8LXD
26yxmdEV3jDDcqsSFJHUAlWAPfafSq+patpujW63GqahaWMDOEWS6mWJS2Cc AsQM4BOPY0cq
C5wH/CY+Hv8AoKwfr/hR/wAJj4e/6CsH6/4V3Z1zS/7Dm1uO/gm0yGJ5nuoH 81NiZ3EFc5xt
PTPTFWLe/s7uWSK2u4JpIv8AWJHIGKfMycgdPmR1+qMOoNHKgueef8Jj4e/6 CsH6/wCFH/CY
+Hv+grB+v+Fel1Xhv7O4vLmzhu4JLq12/aIUkBeLcMruUcrkcjPWjlQXPPP+ Ex8Pf9BWD9f8
KP8AhMfD3/QVg/X/AAr0uijlQXPNP+Ex8Pf9BWD9f8KP+Ex8Pf8AQVg/X/Cv Q7O+t9Qgaa1k
8yNZZISdpGHjdo3HPoysPfHHFV9T13R9E8r+1tVsbDzs+X9ruEi34xnG4jOM jp6ijlQXOE/4
THw9/wBBWD9f8KP+Ex8Pf9BWD9f8K9Loo5UFzzT/AITHw9/0FYP1/wAKP+Ex 8Pf9BWD9f8K9
Dvb630+BZrqTy42ljhB2k5eR1jQcerMo9s88UXV/Z2PkfbLuC38+VYIfOkCe ZI33UXPVjg4A
5NHKgueef8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+FejxzwzPMkUsbvC+yVVYEo 20NhvQ7WU4PY
g96p2uu6PfadPqNnqtjcWMG7zrmG4R449o3NuYHAwCCc9BRyoLnCf8Jj4e/6 CsH6/wCFH/CY
+Hv+grB+v+FehzX9nb3ltZzXcEd1dbvs8LyAPLtGW2qeWwOTjpUceqWk2qTa dE8j3EKbpdsT
lE6Ha0mNgfDKdhO7BBxg5o5UFzgP+Ex8Pf8AQVg/X/Cj/hMfD3/QVg/X/CvS 6KOVBc80/wCE
x8Pf9BWD9f8ACj/hMfD3/QVg/X/CvS6KOVBc80/4THw9/wBBWD9f8KP+Ex8P f9BWD9f8K9HM
8K3CW7Sxid0Z0jLDcyqQGIHUgFlBPbcPWpKOVBc80/4THw9/0FYP1/wo/wCE x8Pf9BWD9f8A
CvS6r2F9b6np1tf2cnmWt1Ek0L7SNyMAVODyMgjrRyoLnnn/AAmPh7/oKwfr /hR/wmPh7/oK
wfr/AIV391qtjY3CwXdzHA5t5brMnyqIoigkcseAB5idT39jixBPDdW8Vxby xzQSoHjkjYMr
qRkEEcEEc5o5UFzzj/hMfD3/AEFYP1/wo/4THw9/0FYP1/wrv9S1S00m3Wa7 eQB3CRpFE8sk
jYJwiICzHAJIAOApPQE1co5UFzzT/hMfD3/QVg/X/Cj/AITHw9/0FYP1/wAK 7M+LPDa3k1mf
EGlC6h3+bCb2PfHsBL7lzkbQrE56YOelWNM13R9b83+ydVsb/wAnHmfZLhJd mc4ztJxnB6+h
o5UFzhP+Ex8Pf9BWD9f8KP8AhMfD3/QVg/X/AAr0eCeG6t4ri3ljmglQPHJG wZXUjIII4II5
zWfD4l0G51Q6XBremy6gHZDaJdI0oZc7hsBzkYORjjBo5UFziP8AhMfD3/QV g/X/AAo/4THw
9/0FYP1/wrv7nVtNsre5uLvULSCC1cJcSSzKqwsQpAck4UkOhAP94eoq5Ryo Lnmn/CY+Hv8A
oKwfr/hR/wAJj4e/6CsH6/4V6XRRyoLnmn/CY+Hv+grB+v8AhR/wmPh7/oKw fr/hXfz6tptr
YS39xqFpDZxOUkuJJlWNGD7CCxOAQ3y49eOtC6tprPZIuoWhe/QvZqJlzcKF DEx8/OApByM8
HNHKgucB/wAJj4e/6CsH6/4Uf8Jj4e/6CsH6/wCFel0UcqC55p/wmPh7/oKw fr/hR/wmPh7/
AKCsH6/4V6XWPZeKtCv7WK5g1OAQzSxQRNMTF5kksSSxoofGWZJFIA55x1BA OVBc4z/hMfD3
/QVg/X/Cj/hMfD3/AEFYP1/wr0cTwtcPbrLGZ0RXeMMNyqxIUkdQCVYA99p9 KJ54bW3luLiW
OGCJC8kkjBVRQMkkngADnNHKguecf8Jj4e/6CsH6/wCFH/CY+Hv+grB+v+Fd nD4s8N3Fnc3k
PiDSpLW12/aJkvYykW44XcwOFyeBnrWxRyoLnmn/AAmPh7/oKwfr/hR/wmPh 7/oKwfr/AIV6
Hb31vdz3cMEm+S0lEM42kbHKLIBz1+V1PHr65our+zsfI+2XcFv58qwQ+dIE 8yRvuouerHBw
ByaOVBc88/4THw9/0FYP1/wo/wCEx8Pf9BWD9f8ACvR454ZnmSKWN3hfZKqs CUbaGw3odrKc
HsQe9Zf/AAlnhv8As7+0f+Eg0r7D5vkfaftsfl+Zjds3ZxuxzjrijlQXOM/4 THw9/wBBWD9f
8KP+Ex8Pf9BWD9f8K9Dsb+z1OzjvLC7gu7WTOyaCQSI2CQcMODggj8KsUcqC 55p/wmPh7/oK
wfr/AIUf8Jj4e/6CsH6/4V6XVO51Wxs72CzubmOGe4RniV+AwDxp16Z3SxqB nJLDGaOVBc4D
/hMfD3/QVg/X/Cj/AITHw9/0FYP1/wAK9HknhheFJZY0eZ9kSswBdtpbC+p2 qxwOwJ7UTzw2
tvLcXEscMESF5JJGCqigZJJPAAHOaOVBc84/4THw9/0FYP1/wo/4THw9/wBB WD9f8K9Dhv7O
4+z+RdwS/aYjPBskDebGNuXXH3l+deRx8w9RVd9d0eO8urOTVbFLq0iM9zC1 wgeGMAEu65yq
4IOTxyKOVBc4T/hMfD3/AEFYP1/wo/4THw9/0FYP1/wru9M13R9b83+ydVsb /wAnHmfZLhJd
mc4ztJxnB6+hrQo5UFzzT/hMfD3/AEFYP1/wo/4THw9/0FYP1/wr0uijlQXP NP8AhMfD3/QV
g/X/AAo/4THw9/0FYP1/wr0uqeoarY6UIWv7mO3SZ2RHk4XKxvI2W6KAkbnJ wOKOVBc4D/hM
fD3/AEFYP1/wo/4THw9/0FYP1/wr0uijlQXPNP8AhMfD3/QVg/X/AAo/4THw 9/0FYP1/wr0e
aeG2QPPLHEhdUDOwUFmYKo57liAB3JAqSjlQXOQqhqVvBdPZw3SgwvMVbJwM mNwP1I/Gr9Rz
Qx3ELxSqGRhgg0ouzuNq6sR6BoMcF1I0ksk0UGBCkjE+XnOQPyH5VD4d8Sal qvjXU9JuYLZL
G2WYRFFbexSVUBJJI6E9BUtncanpqyQxJDcocbJJXIZQM8Efxdeuc/Ws6z0u /tNTuNQivBDc
XBkLmNBgB3DEDdnuBVpQXw6Ij3updsIY4p9QMaKpN7PkgdcSMB+lVtc/1ui/ 9he0/wDRgq9a
W5t43DOXZ3aRmPUljkn8yabeWBv5bE+ckQtryK6JcE7tjbtowO+Me36VDfvX L6HA+NtStbf4
jeILOSKMTzQRETPtVQBHHhHYjgMRgdeSOB1rkdR1+1gjcSwLvHBU7Cc/9817 fq/hbwpr2oS3
2p6XBcXMpUu7XEwyQAo4AA6CqH/CvfAf/QBtf/AievTjjoqCjd6ehPKuprfC 9xL8OdJkChQw
lYAY4zK/pXJR+HtQtfCPhuwjg1n7PLplrc6nC09w7RPBcWbkICxaJwn2jCR7 SduACVUDv9Lb
T9F02HT9PhhgtIc+XGJJG25JJ5Kk9Sat/wBrR+sX/fTf/E1wzmpScu47Hnup wxaYms3WfEEA
vb3TXhdJL0F7MtZRP0OROSsikH9+Rnseek0Tz/Mgz/bn9n/2q39n+d5u/wAn 7Id32jzf3vl+
b52N/O7ysfLtramv7W5QJPFbSoHVwr7mAZWDKeU6hgCD2IBqT+1o/WL/AL6b /wCJqLoLHI6X
/wATD/hHsfvv7R1W81mTd/y3sx5vkSPnrt8yy2qfmXCcDy/lr6da+MBBpUVz cTnfLbWMzl5t
y/ZHR5JmJ/hm8u7Xefvq9qCBlq66G40+3+z+Ra2cX2aIwQbFK+VGduUXCfKv yLwOPlHoKsf2
tH6xf99N/wDE0XQWOJ0618YCDSorm4nO+W2sZnLzbl+yOjyTMT/DN5d2u8/f V7UEDLUada+M
BBpUVzcTnfLbWMzl5ty/ZHR5JmJ/hm8u7Xefvq9qCBlq7b+1o/WL/vpv/iaP 7Wj9Yv8Avpv/
AImi6Cxyvi+bVNROnvbvqWn6ar3Udxss7qWRpkkVIjttZEl2MqzMGzsIK5GS mMvVbbU7jQte
tdYXXLrWZNKkjsRFFMIZVNiA29IC1v5hm8/5WJbJUKSNld9/a0frF/303/xN H9rR+sX/AH03
/wATRdBY81mn1RtV1y3eXxAdYS3lfSI4muvKWZr2+ERkC/ughCwAGX5Cij+E GtDUB4ga715b
CTUp5C/zX7JdxLBD9ojDQpbEhZSIRJiW3IdtvGHZWfthf2q3D3CxWwndFR5B u3MqklQTsyQC
zEDtuPrUn9rR+sX/AH03/wATRdBYxfCU17ZabFDdvqV9Hc3rR280tnLF5Mfl byXE0jzBN6OA
0hzucADZsNcukfiGazsYrWbxBBfOlqutysJjsujdW25ofNBj2BftRPlAxbcb gV216F/a0frF
/wB9N/8AE0f2tH6xf99N/wDE0XQWOJ1wzadqwjnn1yOZNV02HTXjmumgNoZL dHErqTGzFjOD
5pLnI6gpVe4+3TaDY6hafbrv+0bu8vY7S2+0wtfrJL/ozPdQcwYhMYAl+Xbh WC7AydlJ/ZU2
qQ6pLYae+oQpsiu2jzKi88K+zIHzNwD3PrViC/tbW3it7eK2hgiQJHHHuVUU DAAATAAHGKLo
LHG2v/CT2/ii+u/Mvru6jlu3GnfZpo4ZYQJPs6ee8v2ZcjyOY4/MBOG/5ams /SbbXbrWrfTR
qOuNpBu4XlnFre2pwYLzzELXLvJtJW3BIYBSyldr/MfRv7Wj9Yv++m/+Jo/t aP1i/wC+m/8A
iaLoLHE6lYzajDeWt5HrkmrPqsJkCNdLALQahEY2jZcQqwhCEshDjDEkEPVy OG5HiS00Jzdy
2ltrDXUMd3I8m+0js0JcvISZAt1PGRksQ2McR/L1X9rR+sX/AH03/wATUZv7 VrhLhorYzojI
kh3blViCwB2ZAJVSR32j0ougsee7PEMmkyLHPqphN3F9t1V4dQD3C+XKW22e 5JYcSGHPkMFO
7PCq6Ka7L4mt/Dlr5M+q/bLW0mmsrhLC8d7qQu/lxtFFKdm1VhwbnzC3mfMN yyA+jf2tH6xf
99N/8TR/a0frF/303/xNF0FjkTa6nFpn2m/uNcktptbuxepE83mxWayXPkiJ Yv3gUuYTlMsV
IBPlqAsdtpdxb3Wpavpyaykraxp624llucSWrRWccjPE5w5CGUM7qWUqSSCm R2X9rR+sX/fT
f/E0f2tH6xf99N/8TRdBYwddumvLqxlvLfXINGX7XFMlklwsxuElRImxb/vP LZVnYH7hBUnk
rXJ+KJ9UhMqRS+IE8QTXGpoqwtdCB4fs121sI9v7gvtWAgJ8+4En5g1elf2t H6xf99N/8TVO
P+yodUm1SKw09NQmTZLdrHiV144Z9mSPlXgnsPSi6Cxm67Z39xLqWooZzLay w2kAtUkV0sna
3kuiuAGeRlD8xliPLQJiTdnD01Ne1A6qnhnUNSjtLfU2QLqN48Uqqba2YD/S raeTG4yED5fv
Z5BGO6/taP1i/wC+m/8Aiajjv7WF5niitkeZ98rLuBdtoXLfJydqqMnsAO1F 0FjlZrfW7b7E
nii41WewPnmRtMnllkEv7nyQTaQQybcfaONpXONxJ2AV76y18aDJOL/VUM+t 3QuiyTzNDZrL
ceUI44WSXaWMJyh3FWGSY12jtv7Wj9Yv++m/+Jo/taP1i/76b/4mi6Cx5zrs via38OWvkz6r
9stbSaayuEsLx3upC7+XG0UUp2bVWHBufMLeZ8w3LIDYudO1Gz0y9trR9VtJ n1u4m1JxFeTo
LaSS5khMKxOpOS0O77OwIz+84DCu+/taP1i/76b/AOJo/taP1i/76b/4mi6C xwuneH9e1aa/
s7u/kSxvdHhtLm4u9OdZZoTNdgLGWlJjdYnXmTzH+ZC43bgbhtdTi0z7Tf3G uSW02t3YvUie
bzYrNZLnyREsX7wKXMJymWKkAny1AXrv7Wj9Yv8Avpv/AImj+1o/WL/vpv8A 4mi6Cx5q8+qN
d6hbtL4gOqJpivokcbXW1Wa4vBbmcL8gJRbcMbjrtO/o9SanD4r8/wAQyx32 q/bvK1DZb29n
c7fK2S/Ztkpl8jd/qCPJTzd3B/5aGvQhf2q3D3CxWwndFR5Bu3MqklQTsyQC zEDtuPrUn9rR
+sX/AH03/wATRdBY5mTw6F8Wzx3F3rg+2aUlrb38FxNkyhrlpWcp+7VgJUKb 1CgkCMDbgY93
JrGqW+i6/e3V9Cp1BED6NbPcrHHHa3KNPHGUkysksjYfaQ0RhPB5rvv7Wj9Y v++m/wDiajgv
7W1t4re3itoYIkCRxx7lVFAwAAEwABxii6CxwvjEzapoepJKviO6t5tEMWmi G1uonmu/3yy+
fHEi43fuOJVCHJ2jBaiGx1uPVNbv1j1UavNaXkOjuWl8tpUub4oJB/q9oSSD Z53y4I2dDXff
2tH6xf8AfTf/ABNH9rR+sX/fTf8AxNF0FjiUtb6+1qyttKuPEcHh+S7iErzv cpNu8i784Fp/
3qxn/RRnhQxyhD5IjWPUtN1wzW9rqQnivbkzxxWDPHa2kl0JnkhcgLKZVRN8 YaSQGQmML5Zj
Pdf2tH6xf99N/wDE0f2tH6xf99N/8TRdBY4mwsrnULfQrW5fxGl+93H/AG8T PewoHFrcFtj5
CCPzgP8AUnYfkHTbVe0/t9bXT/7S/tz+z7i0sbzVvL88zCaSK584Js/epiVb XMcWAg/hVS2e
+/taP1i/76b/AOJo/taP1i/76b/4mi6CxwukaV4r/seH+w7i7s7P7ReMsd3d CCUhruZlZlns
5pCSjIcswJzyM5JuXy6ppkCTC51VvFTWm3bb2v2q2vCryGCKaYWyRooLsCR5 RAc7m4Vq67+1
o/WL/vpv/iaP7Wj9Yv8Avpv/AImi6CxxNr/wk9v4ovrvzL67uo5btxp32aaO GWECT7OnnvL9
mXI8jmOPzAThv+WprP0m21261q300ajrjaQbuF5Zxa3tqcGC88xC1y7ybSVt wSGAUspXa/zH
0b+1o/WL/vpv/iaP7Wj9Yv8Avpv/AImi6CxxOpWM2ow3lreR65Jqz6rCZAjX SwC0GoRGNo2X
EKsIQhLIQ4wxJBD1cuNAWW014Xy6zNaac80FtHGzTT3dlJbwSTQBpNzSB5Aw 3Bg4K7VdQMV1
X9rR+sX/AH03/wATR/a0frF/303/AMTRdBY5G2m1jSWvLHVNF/tKGaKW51FL e1eY3RaIu7pI
2Fdd+LZLdh5mxUYnaMVX1gQ634G8WXNxYX13qt3p/kmA6TcqqkB/s8cSyRKZ NjuWMmM7iWOx
dqr239rR+sX/AH03/wATR/a0frF/303/AMTRdBY5HxIs82tDUbeyvpVmtLOW 0gSzlK3s0U0k
qxTnbm32kxlWbywGkbf5ioUFPTbDVf7N1/U5BrI1CS9tIblmWSBpoFitFunS FGKb8JOA8WW4
xGx+Wu6/taP1i/76b/4mj+1o/WL/AL6b/wCJougscjo1rqd34otQtxrkXh+L 7VLbLcPMjSKo
syizGX97/rftBAchioIGYyVOfo1lr9pY6XMX1xriO00eZxcTzyZmnmKXodXJ BxGqkqQRH95Q
hJJ77+1o/WL/AL6b/wCJo/taP1i/76b/AOJougsczYaZ47j1G2e81PfarKhm X+0YG3Jkbhga
epPGeAy/Udax/DsOvpBcPq19rktybRftcNtZzxsl7vTb5ck0rRtht4/dKsBX Jkwm0V339rR+
sX/fTf8AxNH9rR+sX/fTf/E0XQWORhsbqTxDod/rUeqm5h+0w3T27T+Wt272 xQII/wDl2Kxt
jd8mB+9/eFqw9Ps/FE1mI7zUNZkuJns01OKK2u4NkhuoPN2TNMRgJ54JtlWP bknAEYr0r+1o
/WL/AL6b/wCJo/taP1i/76b/AOJougscbPDd2mrXFlqJ8QN4btriVIGtZLuS cuYbV48yREzO
m5rvkkqDhTyqAY/hqy8SwS6BFcXOpWhgt9PSC1WwuGXyFgh84O3mrbod3ngi VDIMfLk+WK9K
/taP1i/76b/4mj+1o/WL/vpv/iaLoLHmL2F9dXGnTSWmuS6rBp4bVpbiO5dI bgXVk7vbh8xM
y+XM6pCGRvLUbXXCnQgk8SW2z+yo7428V20tp9pspIkvGl89XlmUYdcT3ULO jBF2wNJEMfIv
ff2tH6xf99N/8TR/a0frF/303/xNF0FjhToOs3uu6ZaanLqU1hY3sdoJo7id HZY7a8YXBkUg
5ZZrZHcEbpFdcYAzqX+meO5NRuXs9T2WrSuYV/tGBdqZO0YOnsRxjgs31PWu m/taP1i/76b/
AOJo/taP1i/76b/4mi6CxzulJd6b4lFjYS6y9vJe3Mt5bX1ogt4I5DJL5kUy xgOTK0eF8xyF
kbKgqdgNB1LXtGe+a4jsrrVLhbi4t720aUG1CkRWsib0ZQAVd03FfMaUcq5B 6L+1o/WL/vpv
/iaP7Wj9Yv8Avpv/AImi6Cx5jeDxNp/gHQIIlvrW/sdEje2NrY3khluNnELx wyBUZNkYJnDI
xc4UAMtd5d2V9rOt38kcsliNPt2ttPmkh3gXMiAtcBG+VwisiKRg5M6ng1pf 2tH6xf8AfTf/
ABNH9rR+sX/fTf8AxNF0Fjz210DVdGe+84yJbw66lx9s03T5DPGDYBGnjR2m MpZ2WNiVkOTK
5OeY69rcvBqmkaTrUfiC10+KyuPslrp0N5GPJT7LHC37hjIQQsrlZTvjMu1v 4Wb0r+1o/WL/
AL6b/wCJqM39q1wlw0VsZ0RkSQ7tyqxBYA7MgEqpI77R6UXQWONsE8TyarbJ ePfXOqtp6CZt
01pDYS/ZRuOQrWtzumJ5CsyFujqmE2NE0/xlBrEEmrah5tiN3mJ9uhkz8px8 q2MRPOOjr+PQ
739rR+sX/fTf/E0f2tH6xf8AfTf/ABNF0FjidHQWmh6LcwaXfW9jpniC+meB dOmR44JPtYiK
Q7A7LieL7qnGTnG1sZ40+/tZpbptOvi1xKbuztktZGW+cX9zcRRzkAm32iSJ lZjHhpG8wOEZ
F9G/taP1i/76b/4mj+1o/WL/AL6b/wCJougscLpljrOoX0bajN4gPn6mlnds 0k9qDCmnqzMq
RvsjBuk+/GcEkqHZW5sWtr8QdQ03T7tb+SB5rK3eWOS7hgZZTEvmZjaxkKnf u43H8Og7L+1o
/WL/AL6b/wCJo/taP1i/76b/AOJougscTqsviKHxDpZLX0d1BLZQMsMF1cx3 UTOgnlaSMpbJ
gPMp3xBsR7ht3Jt5vSNCvYtFjj1Ky1Kyt5bIWsssenyzu2+w09DC8SAv5TGK UOyhWBiCiRCS
G9a/taP1i/76b/4mj+1o/WL/AL6b/wCJougscTpcOsXfiG6v9SttVs9Yn0/y LUZdIYpg9zJ5
bvGHhZUSaELJIrAnOF3h0FhtB8X3lreWmtXk91ptxaTwzwW+oW7yOHiZQEBs ohuyRjMigHk5
GQeu/taP1i/76b/4mj+1o/WL/vpv/iaLoLHE3EuqXTQSi51y40yzu45V1ObT Nl9bu0Vwknlw
eSu9RugXJhfiaQ5+XMZoF9qej3lj9vs9Vh0i1tJbaCCDT5nQJi3W3YIm+T5h DO+JPni8zY3V
C/bf2tH6xf8AfTf/ABNH9rR+sX/fTf8AxNF0Fjz3w5pvjSTRd9tNd2l3I9u9 011OsDyt9gs1
JPm20xYh1kBPy4IIOT03J/D17P4eurnxLLfXd1bxXCNHYzRzyXNo6IZLcYt4 h85jH3VDggYk
GSB039rR+sX/AH03/wATR/a0frF/303/AMTRdBY5G2m1jSWvLHVNF/tKGaKW 51FLe1eY3RaI
u7pI2Fdd+LZLdh5mxUYnaMVXe2n8QarpN/FJqtrqb6gv2q5j06WFbWFbW78t E+0Q7XUNIwLl
SS0n8GUVe2/taP1i/wC+m/8AiaP7Wj9Yv++m/wDiaLoLHI61pWsRS67PFf65 eXWn6JHNpsom
dBLdbrlsGKEJFK3EIKlDkbQQc858mn+K77WNXgj1a+t76f7dEi/ZblIY4mWR bZvPMvkDGYGz
DH5oPB/5aGu+/taP1i/76b/4mj+1o/WL/vpv/iaLoLHGufFV3LHdfabvT4Lx J9UVhbyyvZqI
JIkhaHBBcCS1k8nndIlwc8KDlw2+tG90i4t7HVY1jlMf2lpbuRpozeadvcrP mSFWVJsxMSAq
Ocsp3H0b+1o/WL/vpv8A4mj+1o/WL/vpv/iaLoLHnMVje3aWk2pR65d2dnqC TXWpRtfwTTk2
9whMdqf3kOHkiB8nKMH7KrKm5aabcat4j1a0vW1K4gLtKmoMbm2W2kSdGgjS CUGGQrsDCZAQ
2zDr8+ZOq/taP1i/76b/AOJo/taP1i/76b/4mi6CxxMcesaFdSX2n6bPcbpb i3txcwPJJIVl
3OCFwIWuZmlcz/6pUjhyo4Aj8SvHrWm6/YJpWpQyW1vqC6fZx6VOqy3DRTK8 7SiPYS++QIoY
g+ZuO53VY+6/taP1i/76b/4mj+1o/WL/AL6b/wCJougsYOp6FqJudGtZtc1y /tZ9Q/0kiRbc
xxrbTkZe2SMhS/l5ySMhR355e9h8VyXCxm+1W1jg86HTSlnc3Du6XU6oWKSo h/dLbYa53I2c
k48wn0b+1o/WL/vpv/iaP7Wj9Yv++m/+JougscTqNr4wMGqxW1xONktzYwuH m3N9rd3jmUj+
GHzLRd4+4qXQAOFrQ066vrHxDrt5Nb6rqcMEVxN5ypcw4w42W0VtJ+6lbapC yxfe2/MAW3P0
39rR+sX/AH03/wATR/a0frF/303/AMTRdBY5G/h19/iAz/br6KEXcH2SGGzn kje22x+bucSr
brlvPB8xWkA5XJ8sVh6pBqk3hW1e2i8QP4khSV79nW6IS6/s67XMG792B5rY Bh+XJQDgrXpX
9rR+sX/fTf8AxNH9rR+sX/fTf/E0XQWOBsri+uJbuTTb7XI79dQ1RL25kiub mCK3VrlYjFG+
YnZXFvhIvnOCOm+q80WuSadZKG1Wx0wS3HmXG3U7qS5cCERv5SyJdQqf3/yM xQFcnduRj6FD
f2tshSCK2iQuzlU3KCzMWY8J1LEknuSTUn9rR+sX/fTf/E0XQWOd1uK+1Hwj Fpd5b6lNd26a
bdXlwsflNIFuFabZ5LH96qxOxWMkjcu0kkVT/wCKY/6nn/yt1139rR+sX/fT f/E0f2tH6xf9
9N/8TRdBY57bd/8ATj/3/k/+NUbbv/px/wC/8n/xqqdhr2j6pO0Gn6tY3cyr vMdvcpIwXIGc
AnjJH51U8X393pfha9vbF9lzEF2NtB5LqOh46GlGPNJRXUZr7bv/AKcf+/8A J/8AGqNt3/04
/wDf+T/41XlL6945g0i01C41O0QXcfmQwiJDIVzjLDb8vPr/AENSeDvGPiPU /GFtpupXKtbu
rkqIkXOEJHIHqK6p4KcYuTa0A9S23f8A04/9/wCT/wCNUbbv/px/7/yf/Gqb LeWsHnebcwx+
RGJpt7geWnPzN6L8rcnj5T6VVm17R7e8ks59WsYrqNS7wPcorqoXcSVJyAF+ b6c1xgXNt3/0
4/8Af+T/AONUbbv/AKcf+/8AJ/8AGqhsNSsNUgafT722u4VbYZLeVZFDYBxk E84I/Os7xff3
el+Fr29sX2XMQXY20Hkuo6HjoaqMeaSiuoGvtu/+nH/v/J/8ao23f/Tj/wB/ 5P8A41XlL694
5g0i01C41O0QXcfmQwiJDIVzjLDb8vPr/Q1J4O8Y+I9T8YW2m6lcq1u6uSoi Rc4Qkcgeorqn
gpxi5NrQD1Lbd/8ATj/3/k/+NUbbv/px/wC/8n/xqqd/r2j6XOsGoatY2kzL vEdxcpGxXJGc
EjjIP5VoVxgR7bv/AKcf+/8AJ/8AGqNt3/04/wDf+T/41TZ7uC2mtopX2vcy GKEYJ3MEZ8e3
yox59Kg1DWNM0ny/7S1Gzs/Nz5f2mdY9+MZxuIzjI/OgCztu/wDpx/7/AMn/ AMao23f/AE4/
9/5P/jVSUyaaK3gknnkSKGNS7yOwVVUDJJJ6ACgBNt3/ANOP/f8Ak/8AjVG2 7/6cf+/8n/xq
mreWreXtuYT5kjQphx8zru3KPVhsbI6jafQ1NQBHtu/+nH/v/J/8ao23f/Tj /wB/5P8A41Ul
LHG011BAjqhlYruZd2MKT0yPSmld2B6EW27/AOnH/v8Ayf8Axqjbd/8ATj/3 /k/+NVZvrR9P
RnkuYnCjJXbsJHOcZY5xjpUIIYAjkGnKPKJO4zbd/wDTj/3/AJP/AI1Rtu/+ nH/v/J/8aqt/
bGmf2n/Zn9o2f9of8+vnr5v3d33M56c9OnNXakZHtu/+nH/v/J/8ao23f/Tj /wB/5P8A41Vb
UNY0zSfL/tLUbOz83Pl/aZ1j34xnG4jOMj86u0AR7bv/AKcf+/8AJ/8AGqNt 3/04/wDf+T/4
1UlYfinULrTdMjmtJfLkaYKTtB42se49hV04OpJQXUmclCLkzY23f/Tj/wB/ 5P8A41Rtu/8A
px/7/wAn/wAarzr/AISrWv8An9/8hJ/hW34X1nUdR1SSG8n8xBCXC7FXnK88 D0NddTAVKcXN
taephDFQnJRVzqtt3/04/wDf+T/41Rtu/wDpx/7/AMn/AMaqF9SsItQi0+S9 tkvZV3x2zSqJ
HXnkLnJHyn8j6VarhOkj23f/AE4/9/5P/jVG27/6cf8Av/J/8aqSoZ7uC2mt opX2vcyGKEYJ
3MEZ8e3yox59KAHbbv8A6cf+/wDJ/wDGqNt3/wBOP/f+T/41UlMmmit4JJ55 EihjUu8jsFVV
AySSegAoATbd/wDTj/3/AJP/AI1Rtu/+nH/v/J/8aqSmJNFK8qRyI7RNskVW BKNgNg+hwwP0
I9aAE23f/Tj/AN/5P/jVG27/AOnH/v8Ayf8AxqoU1Kwl1CXT4722e9iXfJbL KpkReOSucgfM
PzHrS6jK8GmXc0bbZI4XZTjOCFJFNK7sDdlcl23f/Tj/AN/5P/jVG27/AOnH /v8Ayf8AxqvO
v+Eq1r/n9/8AISf4VZ07xJq8+pWkUt1ujkmRGHlIMgkZHT3rveXVUr3X4/5H KsZBu2p3m27/
AOnH/v8Ayf8Axqjbd/8ATj/3/k/+NVDf6lYaXAs+oXttaQs2wSXEqxqWwTjJ I5wD+VMttY0y
8vpbK11Gznu4c+bBFOrSJg4O5QcjBODnvXnnUWdt3/04/wDf+T/41Rtu/wDp x/7/AMn/AMap
sV5az+T5VzDJ58Zmh2OD5icfMvqvzLyOPmHrVWLXtHn1A6fDq1jJehmQ2yXK GQMudw2g5yMH
Ppg0AXNt3/04/wDf+T/41Rtu/wDpx/7/AMn/AMaqt/bGmf2n/Zn9o2f9of8A Pr56+b93d9zO
enPTpzV2gCPbd/8ATj/3/k/+NUbbv/px/wC/8n/xqpKKAI9t3/04/wDf+T/4 1Rtu/wDpx/7/
AMn/AMaqSmSzRQIHmkSNSyoGdgAWYhVHPckgD1JFACbbv/px/wC/8n/xqjbd /wDTj/3/AJP/
AI1UlQxXlrP5PlXMMnnxmaHY4PmJx8y+q/MvI4+YetADtt3/ANOP/f8Ak/8A jVG27/6cf+/8
n/xqpKKAI9t3/wBOP/f+T/41Rtu/+nH/AL/yf/GqntoHu7xbdJFjzGz7mTd0 KjHUetJewtp5
HmTxSDdtIA2MOmDgk5HNWoNq5LlZkO27/wCnH/v/ACf/ABqjbd/9OP8A3/k/ +NUs00VvBJPP
IkUMal3kdgqqoGSST0AHeoLDUrDVIGn0+9truFW2GS3lWRQ2AcZBPOCPzqCi bbd/9OP/AH/k
/wDjVG27/wCnH/v/ACf/ABqpKYZolnSAyIJnVnWMsNzKCASB3ALLn6j1oATb d/8ATj/3/k/+
NUbbv/px/wC/8n/xqliminQvDIkihmQsjAgMpKsOO4IIPoQaIZoriCOeCRJY ZFDpIjBlZSMg
gjqCKAE23f8A04/9/wCT/wCNUbbv/px/7/yf/Gq434g65rOjtpUejShJbqR0 YFFYHlQCcg4A
zXNavr/jfRrh7WfVLSS4jOJFhiRlU+m7bgn+VddPCTqQU01qB6vtu/8Apx/7 /wAn/wAao23f
/Tj/AN/5P/jVcT8NvEereIItSOqzCR4GjVAI1XGd2egHoK6qXXtHg1AafNq1 jHellQWz3KCQ
s2No2k5ycjHrkVz1IOnJxYFzbd/9OP8A3/k/+NUbbv8A6cf+/wDJ/wDGqhvd Rs9OETXlwkCy
syqz8LlUaQ5PQAKjHJwOKtVAEe27/wCnH/v/ACf/ABqjbd/9OP8A3/k/+NVJ VW/1Kw0uBZ9Q
vba0hZtgkuJVjUtgnGSRzgH8qAJtt3/04/8Af+T/AONUbbv/AKcf+/8AJ/8A GqWGaK4gjngk
SWGRQ6SIwZWUjIII6giiWaKBA80iRqWVAzsACzEKo57kkAepIoATbd/9OP8A 3/k/+NUbbv8A
6cf+/wDJ/wDGqkpgmiad4BIhmRVdoww3KpJAJHYEq2PofSgBNt3/ANOP/f8A k/8AjVG27/6c
f+/8n/xqq39saZ/af9mf2jZ/2h/z6+evm/d3fcznpz06c1doAj23f/Tj/wB/ 5P8A41Rtu/8A
px/7/wAn/wAaprXcCX0Vmz4uJY3lRMHlUKhjnpwXX8/rU1AEe27/AOnH/v8A yf8Axqjbd/8A
Tj/3/k/+NVJRQBHtu/8Apx/7/wAn/wAao23f/Tj/AN/5P/jVXLawlurE3QuE QbnGzyiT8rEd
d3tVQuFuHgLxuyc7kYEMPX26dKtwaVyVK4m27/6cf+/8n/xqjbd/9OP/AH/k /wDjVKZolnSA
yIJnVnWMsNzKCASB3ALLn6j1qD+0rDZA/wBttttwoeFvNXEqkqoK88gl0HHd l9RUFE227/6c
f+/8n/xqjbd/9OP/AH/k/wDjVSVDBdwXM1zFE+57aQRTDBG1iivj3+V1PHrQ A7bd/wDTj/3/
AJP/AI1Rtu/+nH/v/J/8aqSigCPbd/8ATj/3/k/+NUbbv/px/wC/8n/xqntk lFUgF5ETJGcb
mAzj8atXenS2aFjdQscZCsmzPtktjNXGDauJysUtt3/04/8Af+T/AONUbbv/ AKcf+/8AJ/8A
GqWKRZolkQ5VhkVVttY0y8vpbK11Gznu4c+bBFOrSJg4O5QcjBODnvUDLO27 /wCnH/v/ACf/
ABqjbd/9OP8A3/k/+NVJRQBHtu/+nH/v/J/8ao23f/Tj/wB/5P8A41TReWpt YroXMJt5dnly
hxsfeQEweh3EgD1yMVG+pWEWoRafJe2yXsq747ZpVEjrzyFzkj5T+R9KAJtt 3/04/wDf+T/4
1Rtu/wDpx/7/AMn/AMaqhbeJNCvPN+y61p0/kxmaXyrpG2IOrNg8KM8k8U99 e0eLT4tQk1ax
SylbZHctcoI3bngNnBPyn8j6UAXNt3/04/8Af+T/AONUbbv/AKcf+/8AJ/8A GqkqlqGsaZpP
l/2lqNnZ+bny/tM6x78YzjcRnGR+dAFnbd/9OP8A3/k/+NUbbv8A6cf+/wDJ /wDGqkqG6u4L
KFZbh9iNJHEDgn5ncIo49WYD8aAHbbv/AKcf+/8AJ/8AGqNt3/04/wDf+T/4 1TWu4EvorNnx
cSxvKiYPKoVDHPTguv5/WpqAI9t3/wBOP/f+T/41Rtu/+nH/AL/yf/Gqkqrq Oo2mk6fPf39w
kFrAu6SR+gH9STwAOSSAKAJtt3/04/8Af+T/AONUbbv/AKcf+/8AJ/8AGq5y XxbdeUr2/hXx
CzD5pEm0y4Q7cKSF2xsC+WIAJVSUbLAbS1+38SWU+sR6Y8F/a3E0Zkg+22ct uJ9v31TzFBYq
MEjHRh15w7Aam27/AOnH/v8Ayf8Axqjbd/8ATj/3/k/+NVDf6lYaXAs+oXtt aQs2wSXEqxqW
wTjJI5wD+VTwzRXEEc8EiSwyKHSRGDKykZBBHUEUgE23f/Tj/wB/5P8A41Rt u/8Apx/7/wAn
/wAaptndwX9jb3lq/mW9xGssT4I3KwyDg8jg96moA5vwZpd7YeHdKN3qF85F hChs7iOJVhbY
vHEavkYI+Yn3yead47kSLwZqEkqq0aeWzBhkECRc54P8jWx/aEP9y5/8BpP/ AImq1+bDU7KS
zvLe5lgkxuT7PKM4II5Az1Aq6cuWal2YHlc+tW0kUV0kCLC8MYKEoGhIGAjL tJAwARz0PbpU
ngzVrfUPHllFDEqlBISwC/8APNuOFB/WuyPgzwcSSdEkJJySYp+TVrTfDvhn SL5Lyw0qaC4T
O11hnOMgg8EY6E16FTHKcWtduyJUUtQ8RQPPfPLHp000VtbCS9VNw+3Q5fFu oAxIwKs2D6hP
uzORka9HcfYNZ0/RV1SaOeC9FxZy2LLEheOVi8TtGC7NMVwA7giRsDABXtP7 Qh/uXP8A4DSf
/E0f2hD/AHLn/wABpP8A4mvMKMyzkOp+Io9StYbmG1jtHgma4t3gaZy6Mg2u AzBAJOSMDzfl
Jy+IvHciReDNQklVWjTy2YMMggSLnPB/ka2P7Qh/uXP/AIDSf/E1WvzYanZS Wd5b3MsEmNyf
Z5RnBBHIGeoFXTlyzUuzA8rn1q2kiiukgRYXhjBQlA0JAwEZdpIGACOeh7dK k8Gatb6h48so
oYlUoJCWAX/nm3HCg/rXZHwZ4OJJOiSEk5JMU/Jq1pvh3wzpF8l5YaVNBcJn a6wznGQQeCMd
Ca9CpjlOLWu3ZEqKWpoaxDLLqnh9443dYr93kZVJCL9mnXJ9BlgPqR61zl1/ bvnXX9nf2j/b
fmXm/wAzf9m8nZN9n2b/ANxuz9m+7833t38ddh/aEP8Acuf/AAGk/wDiaP7Q h/uXP/gNJ/8A
E15hRyVrDPL4h017KPVH0iK7Rw18s5dJfs90sh/ffOFw0A/u5PHJatf7SNF1 nU576C8lF5Ij
281taS3GI1jVfLPlqxXDh2wQB+8yCSWxrf2hD/cuf/AaT/4mj+0If7lz/wCA 0n/xNAHEat/b
P2fUvsn9r/2t/p3m7PO8r7P5c32fyv8Allvz9m/1fz5znnfRrNrrNlbaoNMb V2KST21viaaU
+SbFpVI3E5b7QcCT72cIDj5a7f8AtCH+5c/+A0n/AMTR/aEP9y5/8BpP/iaA OIfSVj2/aYNX
Hka1cXV55D3PyxSfafKaHYec+bHuEXIz8/Q4h1CLxH52tyR3mo/a/LvdsEFr Pjy9knkbZDJ5
W7/UkeUnmZ4P/LQ13v8AaEP9y5/8BpP/AImj+0If7lz/AOA0n/xNMCS0tvsl qkPnTTlclpZm
3O5JySew5J4AAHQAAAVLHJ5epWDf9Nm/9FvVb+0If7lz/wCA0n/xNRzXFncp snt5pFBzh7SQ
jP8A3zTg7O7B6o2dZuN+nXZKHiCQ5K9PlNUIP+PeP/dFZnkaR/0D2/8AAOT/ AOJq4t9AqgCO
5AHT/RpP/iaupNSSSREI8vUw9JvptK0SHSTp95PrFtbMGX7PIsVzOFLFvtG3 y/3jZbcxzl/m
AbIrm4W1VIL2H7fqklkjW8ig6dqKNMxE2+IOzPOg+WIl1JVeBtO5g3oP9oQ/ 3Ln/AMBpP/ia
P7Qh/uXP/gNJ/wDE1kWc/ptzJoklxNqtjfJJeLC0XlRS3zRIsKKYWkQM2VcS Nk8N5hIJJfGR
q39s/Z9S+yf2v/a3+nebs87yvs/lzfZ/K/5Zb8/Zv9X8+c55312/9oQ/3Ln/ AMBpP/iaP7Qh
/uXP/gNJ/wDE0AZ+lWs2n63fWkbXjaeLaCWJrmaSb96zShwHkJPRY/lzgdcD cc2NYtbe/it7
K4XP2iUxxNuxtkKPsP8A31gfjVj+0If7lz/4DSf/ABNVr02GoRLFdQXLorBw BBKuCO+QPetK
UuSakyZx5otGTqPh/TdOtftdkVedZI7OISONv2pXO9jnjbgdDxzV3RPPk8iS 7F0tyqzK/wBr
OXY5jztPB2Ag8Y4JPJzxEdH0EjBsbojOf9XP1qzZ2+l2E5ntra6SQpsLGGZu OuOQfSuypioT
puOrfp/wTmhQlGV9Lf15FPXbm4m1SwTTrG5urrTp5Lpo2iaKNx9mlVVEzDYS WkReCSMkkfKc
YWltrFv9umiuNRurew8i7jjktLuIz/61Z4wtwzPI3l7Sqhgu/ZwPmz2/9oQ/ 3Ln/AMBpP/ia
P7Qh/uXP/gNJ/wDE1551nEeI11+y0yFUmvP7QhtpLlJrWK6uVmunZmaJRGwC oh2hfOVlKsBj
5WyzVYdUlvo3tY9UfX4ru9eNmWY2yJ5FwtuRu/0cHDQj1yTu5LV3X9oQ/wBy 5/8AAaT/AOJo
/tCH+5c/+A0n/wATTA49vP8AOP2X+3f+Ee8yL7R5n2r7TnZPv2bv3+3d9l+5 x97t5la3iiCG
5+HmowR2tzdLJYMsETwySys5X93lWBfcG2nLDIIycYJra/tCH+5c/wDgNJ/8 TR/aEP8Acuf/
AAGk/wDiaQENxcy3cAtrM3NvNd2kkkN21sSsDYULvVsYbLghCOdjZxisLw1Z 3vh9taW5i8+K
TUYRH9ltXUuXjhVpcu7FlycsxJOUkYkk4HR/2hD/AHLn/wABpP8A4mj+0If7 lz/4DSf/ABNA
GFZ3Fve+IViksry1SzuZjaw/YJUjaU7w87S7NnzBn2gNghyxyzAJu6kyLpd2 0ib0ELllzjcN
pyKP7Qh/uXP/AIDSf/E0ya6tp4ZIZIrlo5FKsPs0oyCMH+Gqi7STE1dWMw+E 9EjDM0jFYyb9
vnPNmQ21R75A5681S0b7XJGI7tZljxA8DEg26p5iFQoHAc8jOSfvAjOTVz+y NC/58rvpt+5P
09KfFpmiQSRyR2V0GjcOn7ucgEcg4r0Hi4OLTbfy/wCCciw8k01Zf16C+LpD J4dv9NihuZbq
/tJoLdYrd3UuyFQGZQVQZYcsQOvPBrIs1mubZdMitLyO+g1qa686W2kjjji+ 2O7MshUA74mK
AKSSJMH5dxHVf2hD/cuf/AaT/wCJo/tCH+5c/wDgNJ/8TXmnYc54Ds7rTNEs rXUbab7a9lC3
2l0IyiqAIWH/ACzaPdt29G5cZZpAr9OS5sdeFpZSao8D3dxJdW93bKIYUcyS b45VQBiZCmF3
sQrnKgqdvQf2hD/cuf8AwGk/+Jo/tCH+5c/+A0n/AMTQByt8s0z+KdJitLz7 bf3KtZS/ZpBE
rfZoVWXztuxdjoWzncCnygtgGG6/t3zrr+zv7R/tvzLzf5m/7N5Oyb7Ps3/u N2fs33fm+9u/
jrsP7Qh/uXP/AIDSf/E0f2hD/cuf/AaT/wCJoA5y2uodPvrS7tV11tLEdxFM s8N5NJ5zGEod
kgMm3asmGxtByMgtzkaHYavcw2B1F9aDTzwQXO65njxCNPRyeGGw+euC4wS2 VJ5IPdf2hD/c
uf8AwGk/+Jo/tCH+5c/+A0n/AMTQBwum/wDCS3Opadcahd30Nyy2jCEWUxVo zFGZt5DrAh3+
cCHQuP4efLFMfStS/sHRonGryi4soLrUxLPPJIskc9q7bcsWjcKZyFTBJHAJ UY73+0If7lz/
AOA0n/xNH9oQ/wBy5/8AAaT/AOJpgcfqM2ojW9Oew/tGGKOS0ihRre8l8+3Z k8x5GLeWjBWk
BEqFxs3ZBKkUrK01Kw0bSLOzTV4xb2Ri1JCZztZZLQSiMt1/dibZ5X+15fNd 7/aEP9y5/wDA
aT/4mj+0If7lz/4DSf8AxNIDkrGwudR1qKGV9aTRQty1sXubmB8YtQPMYsJC d5uNokOcZx8o
FdPoMt5P4d0ybUA4vZLSJrgOmxhIUBbK4GDnPGOKm/tCH+5c/wDgNJ/8TR/a EP8Acuf/AAGk
/wDiaALtlL5WsxH/AKd5P/Qo6XXp9+nykoR80Y3Ef9NFrLnlsboKJ7WWXb03 2khx/wCO1CsO
kqwZbBwQcgizk4/8dreFSMY2a1IlC7vcTxTDLceDtaggjeWaTT50SNFLMzGN gAAOpJrnIGvY
dZj1VH1e6sY5IVuLmezeOd1EdyPL8lY0LoryRMCIzy5JJCfJ2H2+H+5c/wDg NJ/8TR/aEP8A
cuf/AAGk/wDiawLPO9Uu74aDq95fvrsKC2u5dNeIXUZSTz7ggyBMFVCfZ8eb hQOn8Vddq9yL
DxTpl5LBeSW4srqJntrSWfazPblQRGrEZCN19KuXS6Vez2893p/2ia2bfBJL Ys7RNkHKkr8p
yB09BVr+0If7lz/4DSf/ABNAHHxf2r/bFp539o3P+mzBbU/aYFjT7XKRKZl/ duojCYik4KqN
pG7a214KtBYeFrOzZLyO4t40iuUuTKdsqooYIX4KZHGz5OuK1v7Qh/uXP/gN J/8AE0f2hD/c
uf8AwGk/+JoA474g6hBpup6BcT25uB5sgRFQM27KYK57jnuPrXG3er21rvVx BImWKSxvGyyL
k4YHb3r1HVrDRtcWNdSsricRBggMMy43Yz0Az0FZX/CFeDf+gHJ/35nr0aGM VOmoa/ciXFPc
y/hXfRagdYnijVE3RDAA5+/zwBWxZyPZ+MtWM0+rxpPexmOCLT2e2lBt4U3t KIjjDAg/OANv
PfOhpGnaJoKyrpljPbibG8LBMc4zjqD6mtP+0If7lz/4DSf/ABNcdaftJuSK R59qEOoS+HLd
4I9afXYlke8ZluCEuPsVyuYs/IB5jYHlfLkrjqtWrSe7mkuXsLvV47wXuoJd TvHcTwxwq06x
mNHzG7K4gwsfzHBHTdXb/wBoQ/3Ln/wGk/8AiaZFdWkCFIbeaNSzOVS0kALM SzHhepJJPqSa
zA4WWPV3sbVQ2o2mniSbfNi/uZJ3AiEb+WHW4iU/vvkJKAr/ABbkY9BqNrq8 1r4X8uT/AImE
VyGnnntt4U/ZZlZnSNwBknHDYBYYJ77v9oQ/3Ln/AMBpP/iaP7Qh/uXP/gNJ /wDE0gOV/sfV
7G41ZbG7vHnj04z2qqdkEl7LJcuxCtxwXXCkkAFd24hWEMplRHlsZdXi05L3 TfJN3LcJIZWu
dkwPmkOyGNoxg5TJOOQa7D+0If7lz/4DSf8AxNMe6tJXieS3mdom3xs1pISj YK5Hy8HDEfQn
1oA4XTovEa2kr3F5qMk5ji/tGJbWdNp82PzfLd5GDMI/PA+zKAeowfLFbWl2 lsnimK8jTVxb
y2UcVq85uuWR5zIJg/PAddvm+vyV0f8AaEP9y5/8BpP/AImj+0If7lz/AOA0 n/xNAHK3yzTP
4p0mK0vPtt/cq1lL9mkESt9mhVZfO27F2OhbOdwKfKC2Aat/PrX/AAkskkE9 9ZGRp4pFSxub
hIolhk8uUEsYWJZYm2IgbLbCSd2e0/tCH+5c/wDgNJ/8TR/aEP8Acuf/AAGk /wDiaAOL0rSZ
dS1Sw+12+qQ20UF4FuBe3kbSktbYY72EkQbD4iYkfISCwwx6HS9WvF8Owzah ZX0l7DpcN1cB
bfDSyMjFo0Xj94ChyuBjcvrWn/aEP9y5/wDAaT/4mj+0If7lz/4DSf8AxNAE i3O6+ltfJmHl
xpJ5pX9224sNoPdhsyR2DL61NVX+0If7lz/4DSf/ABNH9oQ/3Ln/AMBpP/ia ANbSLorpW0An
97N0H/TRqzbht2tkbdv+jKcYx/G9UJI9KldnewdmY5JNm+Sf++akgfT7ViYL WWMnrttJBn/x
2t5VIuLSRChaV7lDxTbaj5dtfaOduoR+ZbK+3ftWZdoOMEbVlEDsccLG3XkH Fi0rU7QlVSYJ
ptza2Nj5QYFbdrtHfBAyyeR5CMTnmKTPct2H9oQ/3Ln/AMBpP/iaP7Qh/uXP /gNJ/wDE1gWc
LJZ61H4d8Pi4v9UVZLTzL6R4rmeUXBSIIpWB0kUACQf3cjLZchqgmtNeWaX7 VPfQQSTh7mZL
OdnlmFraKp22sisBkT52sYwQQcnaa9B/tCH+5c/+A0n/AMTR/aEP9y5/8BpP /iaYHH41ldRx
NdajLciy+e4+zTRixYW/L+UhMFyxkOdikspbA3Bfl3fCYnGlyiaC5jAnISS4 mndp1CqN+2f9
5ECcjYc4xkFgdx0/7Qh/uXP/AIDSf/E0f2hD/cuf/AaT/wCJpASzNs8lv+ni H/0Ytbk1z5rK
DGSNw6rXNy3drNGY5YZ3Q9Va1kIP/jtVfI0j/oHt/wCAb/8AxNbU6kYqzRE4 83Ut6Ud2l259
UBrgJbHVZ4Ly1sTqj3qXepyxQy25gity4uRHLFNsXcxMiAZdhiRjgbQV7+O7 toYxHHFcKijA
AtZMD/x2nf2hD/cuf/AaT/4msm7u5ZyV9f3Oo61LNEmtJooW2W5CW1zA+MXR PlqFEhO82+4x
jOMZ+UGtPw3LDceEJmuhc3Vr596hS5SSaRoVnlUIyuC7HaAu0gntitS7k0+/ tXtbyze5t3xv
imsndGwcjIK4PIB/Cnw3VpbwRwQW80UMahEjS0kVVUDAAAXgAUgOSKBfhx4a E+n3j3FrJp/7
v7DK8sLRSJ5h2BSy4VZBnHIOBncM6etr5+pQWlvaXizG9gnkjW2/0e6CvGTK 8oXhkVDgF1JM
YBVlKht3+0If7lz/AOA0n/xNH9oQ/wBy5/8AAaT/AOJoA5zUrO6v0vNVktpi 0N7bpbwlCXS3
guUeVwvJLOUdvlzvRIeMjFVTFdrfXviCxW5innu2jtEl06SQyxvBbq26PKNG d9vgO5VQMk8M
Grrf7Qh/uXP/AIDSf/E0f2hD/cuf/AaT/wCJoAz9P03U9P8AC2laba3dnDd2 ltDDLJLA00bb
UCnaA6HqOCT07ekOr3IsPFOmXksF5Jbiyuome2tJZ9rM9uVBEasRkI3X0rW/ tCH+5c/+A0n/
AMTR/aEP9y5/8BpP/iaAOC1iLXNO0aOK2jvLWa3jnuLFbaG4uMs0jtHAVgcI nlqIl/eB4/mw
oKqczahaX19fX1syajeRPewF7kG6txEovIiI1jOEbaisfOixwhJwTubt/wC0 If7lz/4DSf8A
xNH9oQ/3Ln/wGk/+JpgcRc2nkeJhHqCa62mWv2mK2ltjdySAMlm4Bkiy7KW8 77xIyuP4QB09
jqN9baIn9p2d5LqFrp0Vxc+VEredKVbeke04Z8oeBx8y461of2hD/cuf/AaT /wCJo/tCH+5c
/wDgNJ/8TSAkW53X0tr5Mw8uNJPNK/u23FhtB7sNmSOwZfWuV+KUslv8OtUm hkeOWNoHR0Yh
lYTxkEEdDXTf2hD/AHLn/wABpP8A4mqmpx6ZrOnTafqFrPPazACSM28ozggj kDI5APFCBnmH
h251W40vQ1X+0dQsr5CdR1Nr6cmzJcqwDK4WPYgV/mB61k/De9N942ie8vnv buO9EdvLcS+Z
L5It7rdtJ525KE44yR7V6EngDwVHE0SaRerG2dyK92AfqM1Z0jwh4R0HUY9Q 03SJ4bqMEJIU
uH25GDgNkdCR+NRTg4vXt566t3d21ezS0S2+7orVlONl/wAN5Ly/rzNK8kOm eIpNSuobma1k
tEgha3t3naFw7s42oCyhwY+QMHyvmIwmcXV7vU5vEVlc2YvoF8+1SOMWl06z QO6eY74YRREB
5FKyIXGzORlcdb/aEP8Acuf/AAGk/wDiaP7Qh/uXP/gNJ/8AE1Zznn2jw6hb +H9Og06PWoo4
7CFNUjnW4VlYSQBhCJOQRF9p/wBT/s452Vr/APFP/wDU3f8AlWrqv7Qh/uXP /gNJ/wDE0f2h
D/cuf/AaT/4mgDQ86P8A59ovzb/4qjzo/wDn2i/Nv/iqwo9diXwvNrk5tpYY YJZ3+wXAuEZU
3Z2OQu44X0HPHbNZlr4svbkLAdFeK9mnWGATGaKByUkc5eSFWyFifOEYcpzy doB2HnR/8+0X
5t/8VR50f/PtF+bf/FV5+/iTUdO12/geHz53uVRLc3WIUZlsI8BjGW2hrhjk AfxZUkjGhdeL
ri0DQzWFtDcwztDcyz3TJZxEJG4zP5ZwWEqAblUEhhnIXcAdh50f/PtF+bf/ ABVHnR/8+0X5
t/8AFVDRQMDNvv0QRRLEsEkjKN2WIaMDkngfMc+vqKztV8XaFodylvqUkFvK 6b1UrKcjJGcj
Poaur/yEP+3ST/0ZFXA+LNNt77x7p9xeW8dza2loJZYHJxKMyfLgA56fX2PS ujDUlVqcrE3Y
6I/EfwkBk3tt/wB+5q2NK17TNbtDdacIZ4Q5QuBIOQAcckeorxzU9Gi1BmkM MEIYcRxRMFQe
g+XoPfmtzw1bSWXw+ltFnlQtrFtCzwSPE2x5oFYBhhhlWI4x1roxOEjShzK/ 4CUk9j1Xzo/+
faL82/8AiqPOj/59ovzb/wCKrlRrtxZXk9qLFG02yu7fT2uGvGednkWLadrL 8wzMgJL54J5P
BpWHjqS9jjn/ALGuUtrhoPIlZJVUpLNHGN7PGq7sShgEZwdrfMBgnzxnb+dH /wA+0X5t/wDF
UedH/wA+0X5t/wDFVxi+OY5oQ9pp81yzRyyKkO9zgPB5TFQhba0dxHIcAlBk YJBFa0euxL4X
m1yc20sMMEs7/YLgXCMqbs7HIXccL6DnjtmgDd86P/n2i/Nv/iqPOj/59ovz b/4quPtfFl7c
hYDorxXs06wwCYzRQOSkjnLyQq2QsT5wjDlOeTtz38Sajp2u38Dw+fO9yqJb m6xCjMthHgMY
y20NcMcgD+LKkkYAPQPOj/59ovzb/wCKo86P/n2i/Nv/AIquPuvF1xaBoZrC 2huYZ2huZZ7p
ks4iEjcZn8s4LCVANyqCQwzkLu6qgCbzo/8An2i/Nv8A4qs+61DZremWYgjW K684OVJ3Aohc
ckn+6R07g9sG1WTe/wDI1aB9br/0nehAWtX8TaPoQiOpmC3E2dhKyHOMZ6E+ orM/4WN4S/5/
bf8A79zVifEHS11bUtAtnCmMSyO4YkZUGPI4HOemDj6iuX1jTbXUp3eCxtrO 3yRFbxRMAi9u
duSfWvTw+ChUpKbvr6Ccktz1XSPE2j68JTpjQXAhxvIEgxnOOpHoa0/Oj/59 ovzb/wCKrx3w
tbS6L4R8Z+ROySx2TSxyR7kZCI5cEEgEEEdRXa3msTeH5Lu0trL7RY6ZZLe3 M1xfyNNsZpSQ
m5WLsBE2NzqOQMgdOKvTVOo4oZ1vnR/8+0X5t/8AFUedH/z7Rfm3/wAVXEXP jqSF9SdNGuZb
WzW52yhJQC8AfduYx+WqkxsoIdjkrlRkhbU3jOCO7mgis5rgx3LxBYMtJIqR TMWVccsZLeaI
LnkruzgjOIHW+dH/AM+0X5t/8VR50f8Az7Rfm3/xVY2haq+r2LzyCzV0kMbJ bXDS7CACVfci
MjjPKFcjjPoMGx8dSXtv9oGjXKQzrE1nIySojmSRI0EjPGqqSZFP7syDAcgn A3AHb+dH/wA+
0X5t/wDFUedH/wA+0X5t/wDFV5/q3iTUdE1m4nvIeUso5GtILrdFlY76Q/M0 YPzCFMkKpyBy
QMHTu/FF7p/nW95pkK3kflOTHcO9tHHJ5mHkl8rcijyXydhAymSASVAOt86P /n2i/Nv/AIqj
zo/+faL82/8Aiqp2c/2qxt7jMLebGr5gk8yM5GflbA3L6HAyO1TUAEs265tY kiiRXkbzCNxJ
URu2Bk4Byo5wap6v4m0fQhEdTMFuJs7CVkOcYz0J9RVg/wDH9Z/78n/omSuJ +IOlrq2paBbO
FMYlkdwxIyoMeRwOc9MHH1Fb4emqtRQfUGbf/CxvCX/P7b/9+5q0tI8TaPrw lOmNBcCHG8gS
DGc46kehryrWNNtdSnd4LG2s7fJEVvFEwCL2525J9am8LW0ui+EfGfkTsksd k0scke5GQiOX
BBIBBBHUV14jBwp03JX/AAEpJ7HsXnR/8+0X5t/8VR50f/PtF+bf/FVyV5rE 3h+S7tLay+0W
OmWS3tzNcX8jTbGaUkJuVi7ARNjc6jkDIHSrc+OpIX1J00a5ltbNbnbKElAL wB925jH5aqTG
ygh2OSuVGSF80Z2/nR/8+0X5t/8AFUedH/z7Rfm3/wAVXJTeM4I7uaCKzmuD HcvEFgy0kipF
MxZVxyxkt5ogueSu7OCM6mhaq+r2LzyCzV0kMbJbXDS7CACVfciMjjPKFcjj PoADZ86P/n2i
/Nv/AIqjzo/+faL82/8Aiq4ix8dSXtv9oGjXKQzrE1nIySojmSRI0EjPGqqS ZFP7syDAcgnA
3VtW8Sajoms3E95DyllHI1pBdbosrHfSH5mjB+YQpkhVOQOSBggHoHnR/wDP tF+bf/FUedH/
AM+0X5t/8VXJXfii90/zre80yFbyPynJjuHe2jjk8zDyS+VuRR5L5OwgZTJA JK9DZz/arG3u
Mwt5savmCTzIzkZ+VsDcvocDI7UAXPOj/wCfaL82/wDiqz9U1A2z6esdvEBc XsVs5G7IDnbk
ZPYkH3xjjORarJ1z/W6L/wBhe0/9GChAy9qmu6ZolqtzqAihgLhA7B25wSM7 foe1ZH/Cx/CX
/P7b/wDfuasz4lWTaj4etrRSA0t4oBJIx8j9wD/KuV1jS7Kd/s1pp9tZwQAR hY4my7AYLsdv
UnPAOPr1r0cNg4VafM7/AICcktz0vSfF2ha5cvb6bLBcSom9lVZRgZA6nHqK 1/Oj/wCfaL82
/wDiq8l+G+l/2Z4rvAGBWS0YgBWGMOnqB610GgX9/a6J4etbKD7fd6jp326e XUNRlGCqwhsE
rIeTIDgYAwfWuXEUlTnyod0d150f/PtF+bf/ABVHnR/8+0X5t/8AFVxlp44G o39tHZaTeS2k
vkB5fKlLoZURwflRo9oWRCxaRSMNwcLuLXx1BdQ2rLaYe4js2CeYeGmeEOud v/LNbiBs/wAW
/AxtbGAHZ+dH/wA+0X5t/wDFUedH/wA+0X5t/wDFVz+ga6+t/aC8ENsY9p+z tM32mMNnAmiZ
FMbYAIGWB5IJGCcx/HAiur5n0m8bT7T7QGuI4pScwB95JKCIKTGwBEhOSoIG TtAOz86P/n2i
/Nv/AIqjzo/+faL82/8Aiq4jU9W1Wz1vSvtsaWxlVkMNpdmRGDXVnGGJeMcg SOMbc4JwwJyJ
Lfxjetpltd3GjfPe2QvLSKzme4JXdGp8wCMMuPOQnaH4DnHADAHZ+dH/AM+0 X5t/8VR50f8A
z7Rfm3/xVZmk339paZDd77N/M3fNZ3PnxHDEfK+1c9OeBg5HartABcTErEkU MMbSTxR7iGOA
0iqeN3XBNV9U13TNEtVudQEUMBcIHYO3OCRnb9D2qSX/AFlr/wBfcH/o1a5H 4lWTaj4etrRS
A0t4oBJIx8j9wD/KtaMFUqKL6gzT/wCFj+Ev+f23/wC/c1XtJ8XaFrly9vps sFxKib2VVlGB
kDqceorzTWNLsp3+zWmn21nBABGFjibLsBgux29Sc8A4+vWrHw30v+zPFd4A wKyWjEAKwxh0
9QPWu6vgoU4OSv8AgJSi9j1rzo/+faL82/8AiqPOj/59ovzb/wCKrhdAv7+1 0Tw9a2UH2+71
HTvt08uoajKMFVhDYJWQ8mQHAwBg+tT2njgajf20dlpN5LaS+QHl8qUuhlRH B+VGj2hZELFp
FIw3Bwu7zBnZ+dH/AM+0X5t/8VR50f8Az7Rfm3/xVcZa+OoLqG1ZbTD3Edmw TzDw0zwh1zt/
5ZrcQNn+LfgY2tjT0DXX1v7QXghtjHtP2dpm+0xhs4E0TIpjbABAywPJBIwS AdB50f8Az7Rf
m3/xVHnR/wDPtF+bf/FVxj+OBFdXzPpN42n2n2gNcRxSk5gD7ySUEQUmNgCJ CclQQMnbHqer
arZ63pX22NLYyqyGG0uzIjBrqzjDEvGOQJHGNucE4YE5AB2/nR/8+0X5t/8A FUedH/z7Rfm3
/wAVXGW/jG9bTLa7uNG+e9sheWkVnM9wSu6NT5gEYZcechO0PwHOOAG6DSb7 +0tMhu99m/mb
vms7nz4jhiPlfauenPAwcjtQBp+dH/z7Rfm3/wAVWbr+qnTNEub2K1hLQgPg luRuGR14JGRn
nHoauVh+Mf8AkUdS/wCuX9RQgNvU9QstFtp57xY1t4Dh5WDk9cZwp9T6VgD4 j+Ej0vbf/v3N
UnxEiM/hnVoRjMkiqM5xzKo7An8hXn1zpFpDplppsNjbRPDCvnzrGzPcOecl tvQZA4685x0H
oYXCRrQcnffyE5Jbno+neNvDurXyWVjPbzXD52oElGcAk9eOgNbnnR/8+0X5 t/8AFV4v4O0Y
af48sZlZdriRdoVhz5beoArsdPvruxt1lto3vr3UtYu7ULd38ixosclwy4yH CALFtwqjPGel
YYmiqU+VDTT2O386P/n2i/Nv/iqPOj/59ovzb/4quIn8dSJKsMGjXNxNErNd JCkspUrLJERG
UjYMS0MmN5jBG3kZbbJdeOoLWG6ZrTL28d4xTzDy0LzBFzt/5aLbztn+HZg5 3LnmA7Pzo/8A
n2i/Nv8A4qjzo/8An2i/Nv8A4quf07XXv9bu7BoIbcQb9qTTMty4VgvmCIoB 5ROcOrMDx0OQ
Ks/iqSPxI+lw6XczwxTx2800ccrFXdVYEbYzHtAkUktIpADfKcDcAdV50f8A z7Rfm3/xVHnR
/wDPtF+bf/FV5/rXiTUToen60sP2W0l8y5t/Iusyyx/YriRRIrR7VYbUOP3g yO+OdNfFV1Hu
nuNK3WjXN1bW/wBlmMs8rweaSPLKKBuED4wxOSo7kgA63zo/+faL82/+Ko86 P/n2i/Nv/iqx
tC1V9XsXnkFmrpIY2S2uGl2EAEq+5EZHGeUK5HGfQadADb+78nTrmWK3gEiR OyFt5AIBxkbu
aXU9QstFtp57xY1t4Dh5WDk9cZwp9T6VW1P/AJBV5/1wf/0E1m/ESIz+GdWh GMySKoznHMqj
sCfyFXTipTUX1YMjHxH8JHpe2/8A37mq1p3jbw7q18llYz281w+dqBJRnAJP XjoDXnFzpFpD
plppsNjbRPDCvnzrGzPcOecltvQZA4685x0EXg7Rhp/jyxmVl2uJF2hWHPlt 6gCvSq4GEIOS
vpfsJSTdj2jzo/8An2i/Nv8A4qjzo/8An2i/Nv8A4quI0++u7G3WW2je+vdS 1i7tQt3fyLGi
xyXDLjIcIAsW3CqM8Z6UT+OpElWGDRrm4miVmukhSWUqVlkiIjKRsGJaGTG8 xgjbyMtt8oZ2
/nR/8+0X5t/8VR50f/PtF+bf/FVxl146gtYbpmtMvbx3jFPMPLQvMEXO3/lo tvO2f4dmDncu
dPTtde/1u7sGghtxBv2pNMy3LhWC+YIigHlE5w6swPHQ5AAOg86P/n2i/Nv/ AIqjzo/+faL8
2/8Aiq5WfxVJH4kfS4dLuZ4Yp47eaaOOViruqsCNsZj2gSKSWkUgBvlOBuyd a8SaidD0/Wlh
+y2kvmXNv5F1mWWP7FcSKJFaParDahx+8GR3xyAegedH/wA+0X5t/wDFUedH /wA+0X5t/wDF
VyS+KrqPdPcaVutGubq2t/ssxlnleDzSR5ZRQNwgfGGJyVHckamhaq+r2Lzy CzV0kMbJbXDS
7CACVfciMjjPKFcjjPoADZ86P/n2i/Nv/iqr3935OnXMsVvAJEidkLbyAQDj I3c06qup/wDI
KvP+uD/+gmgCSDU7caJBqU8CLG9ol1IWLNsDIHI4xnAPpzj8Kxv+FjeEj/y+ 2/8A37mp0/8A
yTtP+wJH/wCk4rzy20e1svD1tZCxtftcu+Wa72M7spOFQEr0GD6HoPc9+Fws aybd9O1hOSW5
6LbePvC95dxWtvdW8k8rhEQJNkknAFdD50f/AD7Rfm3/AMVXhOm6Etp4s0m6 RlAW7iBUI4zl
wO64r0N72awv/EGooJrq4TUbaxgglvJEhUSpbAfL8yr80hYkKTyfWssVQVKS URpp7HZ+dH/z
7Rfm3/xVHnR/8+0X5t/8VXGXfjK5tJvsP9leZqaSOksUTTSxKFSJyQ0cLOeJ 4+sYGdwzwN00
PjOCS7hgls5rcyXKRFZ8rJGrxQsGZccMJLiGIrngtuzgHHKB1vnR/wDPtF+b f/FUedH/AM+0
X5t/8VXJaP4tfV7uwiNnDaJdW0cw+0zskkhaISEQLs2zKu4BiGBBByo43P1z xVJpOqCxt9Lu
b1o4FuJvJjldtjMwAQJG4LfI3DlB0+bqVAOq86P/AJ9ovzb/AOKo86P/AJ9o vzb/AOKrj9R1
i/u7MzW8KQWS6pb2yzrcsJnZb2OKQFAuApw4++cjGRyQING8XXl3YW91LYIb INZ28s7XWZzJ
PHCynYI1UjdOoJBXoSF6LQB2/nR/8+0X5t/8VR50f/PtF+bf/FVz+ga6+t/a C8ENsY9p+ztM
32mMNnAmiZFMbYAIGWB5IJGCdqgCbzo/+faL82/+KqrHex22jxXd4kRxarcT SYYAZQMcAHOB
6cmpKytW/wCRMm/7BI/9ECqirtICr/wsbwkf+X23/wC/c1H/AAsfwl/z+2// AH7mrz620e1s
vD1tZCxtftcu+Wa72M7spOFQEr0GD6HoPc5//CPQ/wByP/vh/wD4mvX/ALOp +f4E88T2BND0
xEjT7IjrHBLBtkJcMkpVpA2Sd5YqCS2STnJ5OYB4Z0sQPGY7lmZlbz3vJmnU gEDbKW3qAGcY
DAfO3945z/8AhYDcf8S2Pn/c/wDiaP8AhYLcf8S2Pn/c/wDia8z6vV7D5kT6 h4P029hxH50M
5kidp/PkaRgrwEjduzuYW0Y3ZyCM9c5snwzpbQJC0dy0YZmdWvJj55IAPm5b 96MKFw+4bRjp
xWf/AMLBbj/iWx8/7n/xNH/CwW4/4lsfP+5/8TR9Xq9g5kbT6TYyefvgz59z HdSfO3zSx7Nj
deMeUnA4OOepzPBaQW01zLEm17mQSzHJO5gipn2+VFHHpXPf8LBbj/iWx8/7 n/xNH/CwW4/4
lsfP+5/8TR9Xq9g5kdGv/IQ/7dJP/RkVcH420DxBf+JrPU9GgEot7cLhpVRX fc3ytk5K4PIH
XpWyPiAdwYabHuIK5+TOMgkfd9h+Qo/4WC3H/Etj5/3P/ia0p061N8yiF0ed XPgjxhKhSDSr
eBMYCi5Qhfpz09q7Dwv4U1W18FPpd40dnei/jukdlEy5jeOQZCsMglMdQa1f +Fgtx/xLY+f9
z/4mj/hYLcf8S2Pn/c/+JrSo601Zx/r7w5ka6aRbPA4uY0kmnniurhk3Irzx iPa4G47QDEny
5PTnPOYF8M6QkFzB9mdobiBrdo3nkZUiYYaOMFv3SkY4TaPlX+6MZ/8AwsFu P+JbHz/uf/E0
f8LBbj/iWx8/7n/xNc/1er2DmRtXOlWl1JcSOJkluI44pJIZ5InKozMoDIwI wXbpjOcHIpia
HpiJGn2RHWOCWDbIS4ZJSrSBsk7yxUElsknOTyc5H/CwW4/4lsfP+5/8TR/w sFuP+JbHz/uf
/E0fV6vYOZGgPDOliB4zHcszMree95M06kAgbZS29QAzjAYD52/vHNbUPB+m 3sOI/OhnMkTt
P58jSMFeAkbt2dzC2jG7OQRnrnMH/CwW4/4lsfP+5/8AE0f8LBbj/iWx8/7n /wATR9Xq9g5k
aB8M6W0CQtHctGGZnVryY+eSAD5uW/ejChcPuG0Y6cVafSbGTz98GfPuY7qT 52+aWPZsbrxj
yk4HBxz1OcX/AIWC3H/Etj5/3P8A4mj/AIWC3H/Etj5/3P8A4mj6vV7BzI6G C0gtprmWJNr3
MglmOSdzBFTPt8qKOPSs+9/5GrQPrdf+k71nf8LBbj/iWx8/7n/xNMPjtHlj lbSoTJHny3IT
K5GDg7OMgkULD1OwcyKnxA0LV9abSn0mN2a2d3cpKsbD7uAGJyMkdRyK4268 H+MrlmddHtIJ
JCWkEVwoTcTkkDPH0zXoH/CwW4/4lsfP+5/8TR/wsFuP+JbHz/uf/E10wdeE eRR0/rzC6Oe8
G+DdXtPD3iHTNXVbZ9Sg8lJVKyAbldScA9tw44rtRo0dza3S6oIbm4vLb7Ld PCrxJJEC+FC7
2K8SNyDnn6AZf/CwW4/4lsfP+5/8TR/wsFuP+JbHz/uf/E1jUpVZy5nELo14 tE0+HUDfJC4m
3M6qZnMaO2dzrGTsVjlssACdzZPzHJHomnxQW0MULxrbWjWUJSZ1aOFggKhg c5/dp82cjHBr
I/4WC3H/ABLY+f8Ac/8AiaP+Fgtx/wAS2Pn/AHP/AImo+r1ewcyNe30TT7YQ eXC5aCc3CSST
PI5kKGPczMSznYxX5icDA7DECeGdIjSVBbOVddiq08jCFchgIst+5AKqR5e3 BRcfdXGf/wAL
Bbj/AIlsfP8Auf8AxNH/AAsFuP8AiWx8/wC5/wDE0fV6vYOZE+o+D9NvtNuL dfOW4ktngS5m
nkmdMpMgJ3NlsC4l4J/i9hiyPDWnLA8Qa+BdlZpRqFx5rYBwpk37yo3MQudu STjJzWf/AMLB
bj/iWx8/7n/xNH/CwW4/4lsfP+5/8TR9Xq9g5ka8mh6ZJBcwG0RYbm0WyljQ lFMChwqAAjaA
JH6Y6+wq0tpAl9LeKmLiWNInfJ5VCxUY6cF2/P6Vz3/CwW4/4lsfP+5/8TR/ wsFuP+JbHz/u
f/E0fV6vYOZHRn/j+s/9+T/0TJXHfEDQtX1ptKfSY3ZrZ3dykqxsPu4AYnIy R1HIq9/wsAll
b+zY8jO0/JxwQf4fQkfjR/wsFuP+JbHz/uf/ABNXTp1YSUlELo8/uvB/jK5Z nXR7SCSQlpBF
cKE3E5JAzx9M1v8Ag3wbq9p4e8Q6Zq6rbPqUHkpKpWQDcrqTgHtuHHFdD/ws FuP+JbHz/uf/
ABNH/CwW4/4lsfP+5/8AE1rUdeaacd/67hdGoNGjubW6XVBDc3F5bfZbp4Ve JJIgXwoXexXi
RuQc8/QB8WiafDqBvkhcTbmdVMzmNHbO51jJ2Kxy2WABO5sn5jnI/wCFgtx/ xLY+f9z/AOJo
/wCFgtx/xLY+f9z/AOJrn+r1ewcyNePRNPigtoYoXjW2tGsoSkzq0cLBAVDA 5z+7T5s5GODR
b6Jp9sIPLhctBObhJJJnkcyFDHuZmJZzsYr8xOBgdhjI/wCFgtx/xLY+f9z/ AOJo/wCFgtx/
xLY+f9z/AOJo+r1ewcyNBPDOkRpKgtnKuuxVaeRhCuQwEWW/cgFVI8vbgouP uritqPg/Tb7T
bi3XzluJLZ4EuZp5JnTKTICdzZbAuJeCf4vYYg/4WC3H/Etj5/3P/iaP+Fgt x/xLY+f9z/4m
j6vV7BzI0B4a05YHiDXwLsrNKNQuPNbAOFMm/eVG5iFztyScZOank0PTJILm A2iLDc2i2Usa
EopgUOFQAEbQBI/THX2FZH/CwW4/4lsfP+5/8TR/wsFuP+JbHz/uf/E0fV6v YOZHQraQJfS3
ipi4ljSJ3yeVQsVGOnBdvz+lZ+uf63Rf+wvaf+jBWd/wsFuP+JbHz/uf/E0x /HaSmMyaVC5R
xIm4IdrA5DD5OCD3oWHqdg5kHj/RtQ13w/FaaahacXKuSGUFVCsCRuOM81wl z4T8ZXJ8z+yL
dJjw8gu1JcAAAtk8tgct39K77/hYLcf8S2Pn/c/+Jo/4WC3H/Etj5/3P/ia6 Kbr048qj/X3h
dHO/Dvwrr2ha7d3er26IksBRWWRW53KccH2NdfoOhPpVjYRXc8N1cWFt9kt5 4oWixDiPIZS7
AsTGpJ49gOc0v+Fgtx/xLY+f9z/4mj/hYLcf8S2Pn/c/+JrKpTqzd3ELo0IP DOkWz2xhtnRb
dY1SITyeWfLACMybtrsoVcMwLDavPyjFpNJsY/I2QY8i5kuo/nb5ZZN+9uvO fNfg8DPHQYxf
+Fgtx/xLY+f9z/4mj/hYLcf8S2Pn/c/+JqPq9XsHMjUh8P6bDC0flTS7pIpW ee5klkJjcPGN
7sW2qwyFzjJPHJyHw9pTXUs72vmeZv3QySM8ILghyIiSiswZskKCdzZ+8c5f /CwW4/4lsfP+
5/8AE0f8LBbj/iWx8/7n/wATR9Xq9g5kaC+GdLBiZ47mZoW3RtcXk0rKd8cn V2JxuhjOOnHu
c1tK8IWGm6RBZNLeTSx2yW7XH2uZXAXbnyzvzErFQSqEA4AOQBUH/CwW4/4l sfP+5/8AE0f8
LBbj/iWx8/7n/wATR9Xq9g5kbVtpNjaSW8kEG17eOSKNi7E4kZWckk/MzMik scknJzyclrpN
jZ/Yvs8Gz7FbG1t/nY7IjsyvJ5/1acnJ49zWL/wsFuP+JbHz/uf/ABNH/CwW 4/4lsfP+5/8A
E0fV6vYOZHRy/wCstf8Ar7g/9GrXM+P9G1DXfD8VppqFpxcq5IZQVUKwJG44 zzT/APhYBO3/
AIlsZwQw+5wQcg/d7Gj/AIWC3H/Etj5/3P8A4mrhSqwakohdHA3PhPxlcnzP 7It0mPDyC7Ul
wAAC2Ty2By3f0rc+HfhXXtC127u9Xt0RJYCissitzuU44Psa6L/hYLcf8S2P n/c/+Jo/4WC3
H/Etj5/3P/ia2nKvNWcf6+8OZF3QdCfSrGwiu54bq4sLb7JbzxQtFiHEeQyl 2BYmNSTx7Ac5
fB4Z0i2e2MNs6LbrGqRCeTyz5YARmTdtdlCrhmBYbV5+UYz/APhYLcf8S2Pn /c/+Jo/4WC3H
/Etj5/3P/ia5vq9XsHMjaTSbGPyNkGPIuZLqP52+WWTfvbrznzX4PAzx0GIY fD+mwwtH5U0u
6SKVnnuZJZCY3Dxje7FtqsMhc4yTxyc5f/CwW4/4lsfP+5/8TR/wsFuP+JbH z/uf/E0fV6vY
OZGofD2lNdSzva+Z5m/dDJIzwguCHIiJKKzBmyQoJ3Nn7xzGvhnSwYmeO5ma Ft0bXF5NKynf
HJ1dicboYzjpx7nOf/wsFuP+JbHz/uf/ABNH/CwW4/4lsfP+5/8AE0fV6vYO ZE+leELDTdIg
smlvJpY7ZLdrj7XMrgLtz5Z35iVioJVCAcAHIArTttJsbSS3kgg2vbxyRRsX YnEjKzkkn5mZ
kUljkk5OeTnF/wCFgtx/xLY+f9z/AOJo/wCFgtx/xLY+f9z/AOJo+r1ewcyN q10mxs/sX2eD
Z9itja2/zsdkR2ZXk8/6tOTk8e5qh4x/5FHUv+uX9RVT/hYLcf8AEtj5/wBz /wCJpk3jqO5h
aGfSYJYnGGR1RlYe4KUfV6nYOZGp460+71XQdVsrFA9zK4CAkdRID346CvMH 8IeMGgjjOlQu
8KCJJ3u1MjIMn5+eeSceg4rvz8QnZtx05CW5ydnP/jtJ/wALBbj/AIlsfP8A uf8AxNb0vbU1
yqP9feF0cf4M8HeJdM8YW+o6paxpbqrgssqttyhA4Bz1IrvdN0J7SRvtc8Nz FFezXlmEhaN4
WlaUtuO8h+JWA4H0zjFL/hYLcf8AEtj5/wBz/wCJo/4WC3H/ABLY+f8Ac/8A iaipCrUd3ELo
0JPDOkSnLWzgFnaRUnkVZt7s7LIA2JF3O52tlRuYAYJFWn0mxk8/fBnz7mO6 k+dvmlj2bG68
Y8pOBwcc9TnF/wCFgtx/xLY+f9z/AOJo/wCFgtx/xLY+f9z/AOJrP6vV7BzI 1JPD+mzfbfOi
mm+2RvDL51zJJhH++qbmPlqeMhMDhfQYfLomnzagL54XM25XZRM4jd1xtdow djMMLhiCRtXB
+UYyP+Fgtx/xLY+f9z/4mj/hYLcf8S2Pn/c/+Jo+r1ewcyLr+E9Gkt3t5LeZ 7dt2IWupTHGD
G8ZCLuwi7JHXCgAAj0GGWPhWytDPJLJczzSz3Eob7RKqxea7sfLXfiNgrld6 4bknI3Gqv/Cw
W4/4lsfP+5/8TR/wsFuP+JbHz/uf/E0fV6vYOZGvb6Jp9sIPLhctBObhJJJn kcyFDHuZmJZz
sYr8xOBgdhh6aTYx+Rsgx5FzJdR/O3yyyb97dec+a/B4GeOgxi/8LBbj/iWx 8/7n/wATR/ws
FuP+JbHz/uf/ABNH1er2DmRu6n/yCrz/AK4P/wCgmqfjrT7vVdB1WysUD3Mr gICR1EgPfjoK
zW8feYhRtMiZWBBBCEEf9804/EJ2bcdOQlucnZz/AOO1UaNWLTUdgujgH8Ie MGgjjOlQu8KC
JJ3u1MjIMn5+eeSceg4q94M8HeJdM8YW+o6paxpbqrgssqttyhA4Bz1IrsP+ Fgtx/wAS2Pn/
AHP/AImj/hYLcf8AEtj5/wBz/wCJrolOvJWcf6+8Lou6boT2kjfa54bmKK9m vLMJC0bwtK0p
bcd5D8SsBwPpnGHyeGdIlOWtnALO0ipPIqzb3Z2WQBsSLudztbKjcwAwSKz/ APhYLcf8S2Pn
/c/+Jo/4WC3H/Etj5/3P/ia5fq9XsHMjafSbGTz98GfPuY7qT52+aWPZsbrx jyk4HBxz1OYZ
PD+mzfbfOimm+2RvDL51zJJhH++qbmPlqeMhMDhfQYy/+Fgtx/xLY+f9z/4m j/hYLcf8S2Pn
/c/+Jo+r1ewcyNeXRNPm1AXzwuZtyuyiZxG7rja7Rg7GYYXDEEjauD8oxVfw no0lu9vJbzPb
tuxC11KY4wY3jIRd2EXZI64UAAEegxS/4WC3H/Etj5/3P/iaP+Fgtx/xLY+f 9z/4mj6vV7Bz
ItWPhWytDPJLJczzSz3Eob7RKqxea7sfLXfiNgrld64bknI3Grtvomn2wg8u Fy0E5uEkkmeR
zIUMe5mYlnOxivzE4GB2GMj/AIWC3H/Etj5/3P8A4mj/AIWC3H/Etj5/3P8A 4mj6vV7BzI2k
0mxj8jZBjyLmS6j+dvllk37268581+DwM8dBh+p/8gq8/wCuD/8AoJrC/wCF gtx/xLY+f9z/
AOJpG8feYhRtMiZWBBBCEEf980fV6nYOZF8QSXXgS3t4V3Sy6PEiLkDLGBQB zXmUfg7xhHZR
2raZDN5WTHM9ygdSxBYAA4CcDC+uTnmu+Tx8I40jj0uJURQiKoQBVAwABt4A HFL/AMLBbj/i
Wx8/7n/xNb0vbU7pR/r7wujgdG8EeK4PFGnX17ZxLbwXCO+2ZDgBhk9a9LTQ nOp6hLcTwzWN
3cxXYt/JZZEmjWIKfMD4Kgwg429T1xwaX/CwW4/4lsfP+5/8TR/wsFuP+JbH z/uf/E1NSFap
a8QujUufD+m3U0szxTRzyyea80FzJDITsRCNyMCFIjTKg4JUEjIzT5ND0ySC 5gNoiw3NotlL
GhKKYFDhUABG0ASP0x19hWR/wsFuP+JbHz/uf/E0f8LBbj/iWx8/7n/xNZfV 6vYOZG1/ZVod
T/tFhM9wPuiSeRo0O3blIy2xWxkZUA4LepzVfwzpDwW0H2Z1ht4Ft1jSeRVe JRhY5AG/eqBn
h9w+Zv7xzn/8LBbj/iWx8/7n/wATR/wsFuP+JbHz/uf/ABNH1er2DmRqN4f0 1riSYxTfPIsx
iFzIIg6yLIGEe7YG3qGJAyTnOdxzS07wfpunXcsy+c8XmRPBbmeTyohHFHGg KFirsPLDBmGQ
cd1BqD/hYLcf8S2Pn/c/+Jo/4WC3H/Etj5/3P/iaPq9XsHMjUh8P6bDC0flT S7pIpWee5klk
JjcPGN7sW2qwyFzjJPHJzM+k2Mnn74M+fcx3Unzt80sezY3XjHlJwODjnqc4 v/CwW4/4lsfP
+5/8TR/wsFuP+JbHz/uf/E0fV6vYOZHT1nX0El14Va3hXdLLpioi5AyxhAA5 rJ/4WC3H/Etj
5/3P/iaF+IBCqq6bGFACqBswABgD7tNUKqd7BzI4CPwd4wjso7VtMhm8rJjm e5QOpYgsAAcB
OBhfXJzzUX/CGeNf+gdb/wDgQn+Neif8LBbj/iWx8/7n/wATSf8ACwj/ANA6 P/xz/wCJrq9p
Xf2P6+8Lo4bd04/XrQG6cfrVff04/WgP04/Wu0yLAbpx+tAbpx+tVw/Tj9aA /Tj9aALAbpx+
tAbpx+tVw/Tj9aA/Tj9aALAbpx+tAbpx+tVw/Tj9aA/Tj9aALAbpx+tAbpx+ tVw/Tj9aA/Tj
9aALAbpx+tAbpx+tVw/Tj9aA/Tj9aALAbpx+tAbpx+tVw/Tj9aA/Tj9aALAb px+tAbpx+tVw
/Tj9aA/Tj9aALAbpx+tAbpx+tVw/Tj9aA/Tj9aALAbpx+tAbpx+tVw/Tj9aA /Tj9aALAbpx+
/Tj9aA/Tj9aALAbpx+tN31CH6cfrTd9AFff0+X9etAfpx+vWqu/p8v69aQP0 4/XrU3GWw/Tj
9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFs P04/XrQH6cfr
1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+ nH69aqB+nH69
aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfp x+vWgP04/XrQ
BbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP 160AWw/Tj9et
Afpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04 /XrQH6cfr1qo
H6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH6 9aqB+nH69aA/
Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+v WgP04/XrQBbD
9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160 AWw/Tj9etAfp
x+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/Xr QH6cfr1qoH6c
fr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aq B+nH69aA/Tj9
etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP 04/XrQBbD9OP
160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw /Tj9etAfpx+v
Wqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6 cfr1qoH6cfr1
oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+n H69aA/Tj9etA
FsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/ XrQBbD9OP160
B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj 9etAfpx+vWqg
fpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr 1qoH6cfr1oD9
OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69 aA/Tj9etAFsP
04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQ BbD9OP160B+n
H69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9et Afpx+vWqgfpx
+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qo H6cfr1oD9OP1
60AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD9OP160B+nH69aqB+nH69aA/ Tj9etAFsP04/
XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfpx+vWqgfpx+vWgP04/XrQBbD 9OP160B+nH69
aqB+nH69aA/Tj9etAFsP04/XrQH6cfr1qoH6cfr1oD9OP160AWw/Tj9etAfp x+vWqgfpx+vW
gP04/XrQBbD9OP1603zKrB+nH69ab5lMCtv+7x19+tAfpx19+tVd/wB35f16 0gfpxn8etTcC
2H6cdffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8e tAfpxn8etFwL
Yfpx19+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx6 0B+nGfx60XAt
h+nHX360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/Hr QH6cZ/HrRcC2
H6cdffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8et Afpxn8etFwLY
fpx19+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60 B+nGfx60XAth
+nHX360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQ H6cZ/HrRcC2H
6cdffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etA fpxn8etFwLYf
px19+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B +nGfx60XAth+
nHX360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH 6cZ/HrRcC2H6
cdffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAf pxn8etFwLYfp
x19+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+ nGfx60XAth+n
HX360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6 cZ/HrRcC2H6c
dffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAfp xn8etFwLYfpx
19+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+n Gfx60XAth+nH
X360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6c Z/HrRcC2H6cd
ffrQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAfpx n8etFwLYfpx1
9+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+nG fx60XAth+nHX
360B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6cZ /HrRcC2H6cdf
frQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAfpxn 8etFwLYfpx19
+tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+nGf x60XAth+nHX3
60B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6cZ/ HrRcC2H6cdff
rQH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAfpxn8 etFwLYfpx19+
tAfpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+nGfx 60XAth+nHX36
0B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6cZ/H rRcC2H6cdffr
QH6cdffrVQP04z+PWgP04z+PWi4FsP046+/WgP046+/Wqgfpxn8etAfpxn8e tFwLYfpx19+t
Afpx19+tVA/TjP49aA/TjP49aLgWw/Tjr79aA/Tjr79aqB+nGfx60B+nGfx6 0XAth+nHX360
B+nHX361UD9OM/j1oD9OM/j1ouBbD9OOvv1oD9OOvv1qoH6cZ/HrQH6cZ/Hr RcC2H6cdffrQ
H6cdffrVQP04z+PWgP04z+PWi4FsP046+/Wm+ZVYP04z+PWm+ZRcCDd935f1 60Bvu8Z/HrVb
eOOPrz1oDjjj681IyyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx6 0Bvu8Z/HrVYO
OOPrzQHHHH15oAshvu8Z/HrQG+7xn8etVg444+vNAcccfXmgCyG+7xn8etAb 7vGfx61WDjjj
680Bxxx9eaALIb7vGfx60Bvu8Z/HrVYOOOPrzQHHHH15oAshvu8Z/HrQG+7x n8etVg444+vN
AcccfXmgCyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx60Bvu8Z/H rVYOOOPrzQHH
HH15oAshvu8Z/HrQG+7xn8etVg444+vNAcccfXmgCyG+7xn8etAb7vGfx61W Djjj680Bxxx9
eaALIb7vGfx60Bvu8Z/HrVYOOOPrzQHHHH15oAshvu8Z/HrQG+7xn8etVg44 4+vNAcccfXmg
CyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx60Bvu8Z/HrVYOOOPr zQHHHH15oAsh
vu8Z/HrQG+7xn8etVg444+vNAcccfXmgCyG+7xn8etAb7vGfx61WDjjj680B xxx9eaALIb7v
Gfx60Bvu8Z/HrVYOOOPrzQHHHH15oAshvu8Z/HrQG+7xn8etVg444+vNAccc fXmgCyG+7xn8
etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx60Bvu8Z/HrVYOOOPrzQHHHH15 oAshvu8Z/HrQ
G+7xn8etVg444+vNAcccfXmgCyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaAL Ib7vGfx60Bvu
8Z/HrVYOOOPrzQHHHH15oAshvu8Z/HrQG+7xn8etVg444+vNAcccfXmgCyG+ 7xn8etAb7vGf
x61WDjjj680Bxxx9eaALIb7vGfx60Bvu8Z/HrVYOOOPrzQHHHH15oAshvu8Z /HrQG+7xn8et
Vg444+vNAcccfXmgCyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx6 0Bvu8Z/HrVYO
Vg444+vNAcccfXmgCyG+7xn8etAb7vGfx61WDjjj680Bxxx9eaALIb7vGfx6 03fUAcccfXmk
3UAfVf8Awr7wd/0Ltl/3xR/wr7wd/wBC7Zf98VWvfFyab44GkX91ZWtg2mi6 E07hGMvmbdu4
kDGATjGeKpaH4/W58MWWoalETdzQzXM0dpH8sUMchRpCGboBjuSecA15fM+5 Rrf8K+8Hf9C7
Zf8AfFH/AAr7wd/0Ltl/3xVe68eaXaSakJFujDpwgM86xqU2zAFCOckcjPGf rU7+MdPia8id
bhbm1migNsUXzHeUAxhRnHzZ4yRjBzjBo5n3AX/hX3g7/oXbL/viornwL4Mt rd5n8O2ZCDOA
nJ9BWtperw6taGeDemyRopY5FAaORThlOCRkH0JHoadqLk2qgk8zRDp/00Wj mfcDEtfh/wCH
GiBu9DsMnkRRwKAgznG7G5j7k1Y/4V94O/6F2y/74rd3t6/pS7z6/pRzPuBg /wDCvvB3/Qu2
X/fFH/CvvB3/AELtl/3xUdprep6tfX39mGz+zWF4bSRJw26UqFLkMDhMbiMb WzjqM8Wf+Eps
f7UFjmb/AI+Psnn7B5Yn27/LznO7bz0xxjOeKOZ9wIv+FfeDv+hdsv8Avij/ AIV94O/6F2y/
74qtp/j3T9Si014be+DaksptUaJcyGM/MOGwD3yTj3pkfxC0mcBoEu5U/s5t SLpGuBErlWB+
b7wKnj2654o5n3Auf8K+8Hf9C7Zf98Uf8K+8Hf8AQu2X/fFU7z4haTZWc1zI t2US0ivVVY13
SwyOEDKCR3POcVLe+OdPsdXm0ySG8aeK7trQlI1Kl51LIR82cAKc8Z6YBo5n 3An/AOFfeDv+
hdsv++KP+FfeDv8AoXbL/visfVviJDZmNrOKaZ1a8jmtjCu7fboGYF/MAQDO chXyOgz1u2Hj
m3m0aS9vba4tpYNOjv5YyEO9HBxsIbnlTjOOozg5wcz7gW/+FfeDv+hdsv8A viql14G8LC4i
t7Pw/YLO3ztI8W4RqD12ngk9geOtdNFO0sKSYdN6htrAZXPY+9V0c/2tOc8i CL/0J6OZ9wMp
Ph74RA/eaFZyN3YxBc/goAp3/CvvB3/Qu2X/AHxW7vb1/SsLxnr114d8J3uq 2axPPB5e1ZlJ
U7pFU5wQeh9aOZ9wD/hX3g7/AKF2y/74o/4V94O/6F2y/wC+K5+88dapBc+H IIo7FmvJ4rfU
Rhj5btIUIT5uOY5euegrbPjjTQlxLtufJjhnmil2LtuVh/1nl/NnIPHzYz2y OaOZ9wJf+Ffe
Dv8AoXbL/vij/hX3g7/oXbL/AL4qsPHmnGLf5F6G/s8amE8pc/Zz1b72OO4z 9M1UtfHqNrWr
x3AH9l232MwXMUfRZ0BDSEnpkqBgd/xo5n3A1P8AhX3g7/oXbL/vij/hX3g7 /oXbL/vipP8A
hK7E6t9gHnY+0fZPtO1fK8/bu8rOc7tvPTHbOeKqW/jnT7nw7BrYgu47W4lE MCyKgaRyxUAf
Ngcr1Yge9HM+4E//AAr7wd/0Ltl/3xR/wr7wd/0Ltl/3xVK78XXSa7oFpDZS pDqBuVmjnhIm
UxICNuDtIJP3uVI5B71Tn+JWnQN9rV55bD+zlvdkdsN/M4h+8ZAMgnBXb2J3 dqOZ9wNn/hX3
g7/oXbL/AL4pr+AfBkaM7+H7IKoyTs6CtHT9ag1Ge8t4vNSe0kCTRyoAwyoZ T9CCDUmpuf7K
vPmP+oft/smjmfcDBs/Afhu4j82XQrGKFzujhEC5A9WYjOfYHAq3/wAK+8Hf 9C7Zf98VuhiA
ADwKXefX9KOZ9wMH/hX3g7/oXbL/AL4o/wCFfeDv+hdsv++KyrvxTrEeseJ0 h+xfZNDhim8t
4W8ycNEXI378KeD/AAnrWkfGumBYXDTvC8cEskqoNsCzf6svkg8njgHGecCj mfcB/wDwr7wd
/wBC7Zf98Uf8K+8Hf9C7Zf8AfFK/i/To7+3spGkS4nvJLJUIXIdBnJwehBXH f51yBVT/AIT7
TvMZVgvGC2D6jvVEKmFXKE5Dd
Re: Customisation of Generated Viewer [message #568337 is a reply to message #24095] |
Stefan,
stefan wrote:
>Hello All,
answers:
E.g., this one
> To go deeper,
>something similar?
corner.
>Thank you,
> Stefan.
<html>
<head>
</head>
Stefan,<br>
<br>
<br>
</pre>
</blockquote>
answers:<br>
</blockquote>
E.g., this one <a
<pre wrap="">
</blockquote>
</blockquote>
</pre>
</blockquote>
<pre wrap="">
something similar?
</pre>
</blockquote>
to EMF corner.<br>
<pre wrap="">
</pre>
</blockquote>
help.<br>
<pre wrap="">
Thank you,
Stefan.
</pre>
</blockquote>
<br>
</body>
</html>
TvMZVgvGC2D6jvVEKmFXKE5Dd9u4exHfijmfcC1/wr7wd/0Ltl/3xR/wr7wd /wBC7Zf98VnW
Xj
FUDForum. Page generated in 0.04818 seconds
