Home » Archived » XML Schema Definition (XSD) » Help on Adding Identity Constraint to an element
Help on Adding Identity Constraint to an element [message #24089] Thu, 03 July 2003 02:49 Go to next message
Originally posted by: prabhakar.arunagiri.ssiworldwide.com
I am using eclipse to automatically generate a new schema (ie without gui
and using java) - wanted to know how to implement the following unique,key
and keyref constraints for a element as below
<xsd:element name="ROOT_ELEMENT" type="ROOT_ELEMENT">
<xsd:unique name="PERSON_PK">
<xsd:selector xpath="PERSON"/>
<xsd:field xpath="PERSON_ID"/>
</xsd:unique>
<xsd:key name="PERSON_KEY">
</xsd:key>
<xsd:keyref name="PERSON_FK" refer="PERSON_ID">
<xsd:selector xpath="MAILING_ADDRESS"/>
</xsd:keyref>
</xsd:element>
<xsd:complexType name="ROOT_ELEMENT">
<xsd:sequence>
........ and expanding the complex type mentioned above
I had seen the XSDIdentityConstraintDefinition class with xpath, selector
etc and know that the functionality can be implemented.
Couldnt really add it to the schema (getting some exception or the
other)as there is no similar kind of example implementation
Request to help in this regard( with a code snippet may be!)
thanks & regards
prabhakar
Re: Help on Adding Identity Constraint to an element [message #24200 is a reply to message #24089] Thu, 03 July 2003 10:07 Go to previous messageGo to next message
--------------5F8431D81A59BA8EA87DDEF0
Content-Type: text/plain; charset=us-ascii
Prabhakar,
I'm updating XSDPrototypicalSchema to include this example:
public void initializeSimpleRecursiveElementDeclaration()
// Create an element declaration and name it
simpleRecursiveElementDeclaration.
XSDElementDeclaration simpleRecursiveElementDeclaration =
xsdFactory.createXSDElementDeclaration();
simpleRecursiveElementDeclaration.setName("simpleRecursiveElementDeclaration ");
// Create an annotation placeholder and set it to the
element.
XSDAnnotation annotation = xsdFactory.createXSDAnnotation();
simpleRecursiveElementDeclaration.setAnnotation(annotation);
// Set the element type definition to complex
SimpleRecursiveComplexTypeDefinition from this schema.
simpleRecursiveElementDeclaration.setTypeDefinition
(prototypeSchema.resolveComplexTypeDefinition("SimpleRecursiveComplexTypeDefinition "));
// Create a unique identity constraint called unique.
XSDIdentityConstraintDefinition unique =
xsdFactory.createXSDIdentityConstraintDefinition();
unique.setIdentityConstraintCategory(XSDIdentityConstraintCa tegory.UNIQUE_LITERAL);
unique.setName("unique");
XSDXPathDefinition uniqueSelector =
xsdFactory.createXSDXPathDefinition();
uniqueSelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL);
uniqueSelector.setValue("simpleRecursiveElementDeclaration");
unique.setSelector(uniqueSelector);
XSDXPathDefinition uniqueField =
uniqueField.setVariety(XSDXPathVariety.FIELD_LITERAL);
uniqueField.setValue("simpleAttributeDeclarationGroupMember ");
unique.getFields().add(uniqueField);
simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(unique);
// Create a key identity constraint called key.
XSDIdentityConstraintDefinition key =
key.setIdentityConstraintCategory(XSDIdentityConstraintCateg ory.KEY_LITERAL);
key.setName("key");
XSDXPathDefinition keySelector =
keySelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL);
keySelector.setValue("simpleRecursiveElementDeclaration");
key.setSelector(keySelector);
XSDXPathDefinition keyField =
keyField.setVariety(XSDXPathVariety.FIELD_LITERAL);
keyField.setValue("simpleAttributeDeclarationGroupMember");
key.getFields().add(keyField);
simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(key);
// Create a keyref identity constraint called keyref that
references key.
XSDIdentityConstraintDefinition keyref =
keyref.setIdentityConstraintCategory(XSDIdentityConstraintCa tegory.KEYREF_LITERAL);
keyref.setName("keyref");
XSDXPathDefinition keyrefSelector =
keyrefSelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL);
keyrefSelector.setValue("simpleRecursiveElementDeclaration");
keyref.setSelector(keyrefSelector);
XSDXPathDefinition keyrefField =
keyrefField.setVariety(XSDXPathVariety.FIELD_LITERAL);
keyrefField.setValue("simpleAttributeDeclaration");
keyref.setReferencedKey(key);
keyref.getFields().add(keyrefField);
simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(keyref);
// Add the element to the schema.
prototypeSchema.getContents().add(simpleRecursiveElementDecl aration);
// This is the result that is produced.
// <xsd:element name="simpleRecursiveElementDeclaration"
type="PTS:SimpleRecursiveComplexTypeDefinition">
// <xsd:annotation/>
// <xsd:unique name="unique">
// <xsd:selector
xpath="simpleRecursiveElementDeclaration"/>
// <xsd:field
xpath="simpleAttributeDeclarationGroupMember"/>
// </xsd:unique>
// <xsd:key name="key">
// <xsd:selector
// <xsd:field
// </xsd:key>
// <xsd:keyref name="keyref" refer="PTS:key">
// <xsd:selector
// <xsd:field
xpath="simpleAttributeDeclaration"/>
// </xsd:keyref>
// </xsd:element>
I noticed that if setReferenceKey is not called for a KEYREF, I get this
exception:
org.eclipse.xsd.impl.XSDIdentityConstraintDefinitionImpl.cha ngeReference(XSDIdentityConstraintDefinitionImpl.java:786)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:342)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:355)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.adoptContent(X SDConcreteComponentImpl.java:1363)
org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1725)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1125)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:115)
org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:103)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:220)
org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
org.eclipse.xsd.util.XSDPrototypicalSchema.initializeSimpleR ecursiveElementDeclaration(XSDPrototypicalSchema.java:1006)
org.eclipse.xsd.util.XSDPrototypicalSchema.initializePrototy peSchema(XSDPrototypicalSchema.java:375)
org.eclipse.xsd.util.XSDPrototypicalSchema.<init>(XSDPrototypicalSchema.java:184)
org.eclipse.xsd.test.XSDMainTest.run(XSDMainTest.java:132)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
So I'll also fix that bug like this:
> etools-diff XSDIdentityConstraintDefinitionImpl.java
786c786
< niceSetAttributeURIValue(theElement,
XSDConstants.REFER_ATTRIBUTE, theReferencedKey.getURI());
XSDConstants.REFER_ATTRIBUTE, theReferencedKey == null ? null :
You can avoid this bug by making sure the referenced key is set for a
KEYREF...
> </xsd:unique>
> </xsd:key>
> </xsd:keyref>
> </xsd:element>
> <xsd:sequence>
> thanks & regards
> prabhakar
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Prabhakar,
<p>I'm updating XSDPrototypicalSchema to include this example:
<blockquote><tt>public void initializeSimpleRecursiveElementDeclaration()</tt><tt></tt >
<p><tt>&nbsp;&nbsp;&nbsp;&nbsp; {</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create an element declaration
and name it simpleRecursiveElementDeclaration.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDElementDeclaration simpleRecursiveElementDeclaration
= xsdFactory.createXSDElementDeclaration();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.setName("simpleRecursiveElementDeclaration ");</tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create an annotation placeholder
and set it to the element.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDAnnotation annotation =
xsdFactory.createXSDAnnotation();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.setAnnotation(annotation); </tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Set the element type definition
to complex SimpleRecursiveComplexTypeDefinition from this schema.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.setTypeDefinition</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; (prototypeSchema.resolveComplexTypeDefinition("SimpleRecursiveComplexTypeDefinition "));</tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create a unique identity
constraint called unique.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDIdentityConstraintDefinition
unique = xsdFactory.createXSDIdentityConstraintDefinition();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; unique.setIdentityConstraintCategory(XSDIdentityConstraintCa tegory.UNIQUE_LITERAL); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; unique.setName("unique");</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition uniqueSelector
= xsdFactory.createXSDXPathDefinition();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uniqueSelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uniqueSelector.setValue("simpleRecursiveElementDeclaration"); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; unique.setSelector(uniqueSelector);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition uniqueField
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uniqueField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uniqueField.setValue("simpleAttributeDeclarationGroupMember ");</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; unique.getFields().add(uniqueField);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(unique); </tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create a key identity constraint
called key.</tt>
key = xsdFactory.createXSDIdentityConstraintDefinition();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; key.setIdentityConstraintCategory(XSDIdentityConstraintCateg ory.KEY_LITERAL); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; key.setName("key");</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition keySelector
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keySelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL);</tt >
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keySelector.setValue("simpleRecursiveElementDeclaration"); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; key.setSelector(keySelector);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition keyField
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyField.setValue("simpleAttributeDeclarationGroupMember"); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; key.getFields().add(keyField);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(key); </tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Create a keyref identity
constraint called keyref that references key.</tt>
keyref = xsdFactory.createXSDIdentityConstraintDefinition();</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyref.setIdentityConstraintCategory(XSDIdentityConstraintCa tegory.KEYREF_LITERAL); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyref.setName("keyref");</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition keyrefSelector
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyrefSelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyrefSelector.setValue("simpleRecursiveElementDeclaration"); </tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyref.setSelector(keyrefSelector);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; XSDXPathDefinition keyrefField
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyrefField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyrefField.setValue("simpleAttributeDeclaration");</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyref.setReferencedKey(key);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; keyref.getFields().add(keyrefField);</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; simpleRecursiveElementDeclaration.getIdentityConstraintDefin itions().add(keyref); </tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // Add the element to the schema.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; prototypeSchema.getContents().add(simpleRecursiveElementDecl aration); </tt><tt></tt>
<p><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; // This is the&nbsp; result
that is produced.</tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //&nbsp;&nbsp;&nbsp;&nbsp;
&lt;xsd:element name="simpleRecursiveElementDeclaration" type="PTS:SimpleRecursiveComplexTypeDefinition"></tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;&nbsp;
&lt;xsd:annotation/></tt>
&lt;xsd:unique name="unique"></tt>
<br><tt> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; //&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p;
&lt;xsd:selector xpath="simpleRecursiveElementDeclaration"/></tt>
&lt;xsd:field xpath="simpleAttributeDeclarationGroupMember"/></tt>
&lt;/xsd:unique></tt>
&lt;xsd:key name="key"></tt>
&lt;/xsd:key></tt>
&lt;xsd:keyref name="keyref" refer="PTS:key"></tt>
&lt;xsd:field xpath="simpleAttributeDeclaration"/></tt>
&lt;/xsd:keyref></tt>
&lt;/xsd:element></tt>
<br><tt>&nbsp;&nbsp;&nbsp;&nbsp; }</tt></blockquote>
exception:
<blockquote>java.lang.NullPointerException
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDIdentityConstraintDefinitionImpl.cha ngeReference(XSDIdentityConstraintDefinitionImpl.java:786)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:342)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:355)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDConcreteComponentImpl.adoptContent(X SDConcreteComponentImpl.java:1363)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDSchemaImpl.adoptContent(XSDSchemaImp l.java:1725)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1125)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:115)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.emf.common.notify.impl.NotificationChainImpl.dis patch(NotificationChainImpl.java:103)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:220)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:5 70)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.util.XSDPrototypicalSchema.initializeSimpleR ecursiveElementDeclaration(XSDPrototypicalSchema.java:1006)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.util.XSDPrototypicalSchema.initializePrototy peSchema(XSDPrototypicalSchema.java:375)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.util.XSDPrototypicalSchema.&lt;init>(XSDPrototypicalSchema.java:184)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.xsd.test.XSDMainTest.run(XSDMainTest.java:132)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at java.lang.reflect.Method.invoke(Native
Method)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.run(Main.java:747)
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; at org.eclipse.core.launcher.Main.main(Main.java:583)</blockquote >
<blockquote>> etools-diff XSDIdentityConstraintDefinitionImpl.java
<br>786c786
<br> &lt;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&a mp;nbsp;&nbsp;&nbsp;&nbsp;&nbsp; niceSetAttributeURIValue(theElement,
<br>---
<br>> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; niceSetAttributeURIValue(theElement,
XSDConstants.REFER_ATTRIBUTE, theReferencedKey == null ? null : theReferencedKey.getURI());
<br>&nbsp;</blockquote>
You can avoid this bug by making sure the referenced key is set for a KEYREF...
<br>&nbsp;
<p>prabhakar wrote:
<blockquote TYPE=CITE>I am using eclipse to automatically generate a new
<br>and using java) - wanted to know how to implement the following unique,key
<br>and keyref constraints for a element as below
<p>&lt;xsd:element name="ROOT_ELEMENT" type="ROOT_ELEMENT">
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&lt;xsd:unique&nbsp; name="PERSON_PK">
<br> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
&lt;xsd:selector xpath="PERSON"/>
&lt;xsd:field xpath="PERSON_ID"/>
&lt;/xsd:unique>
&lt;xsd:key name="PERSON_KEY">
&lt;/xsd:key>
&lt;xsd:keyref name="PERSON_FK" refer="PERSON_ID">
&lt;xsd:selector xpath="MAILING_ADDRESS"/>
&lt;/xsd:keyref>
<br>&lt;/xsd:element>
<br>&lt;xsd:complexType name="ROOT_ELEMENT">
&lt;xsd:sequence>
<br>....... and expanding the complex type mentioned above
<p>I had seen the XSDIdentityConstraintDefinition class with xpath, selector
<br>etc and know that the functionality can be implemented.
<br>Couldnt really add it to the schema (getting some exception or the
<br>other)as there is no similar kind of example implementation
<p>Request to help in this regard( with a code snippet may be!)
<p>thanks &amp; regards
<br>prabhakar</blockquote>
</html>
--------------5F8431D81A59BA8EA87DDEF0--
Re: Help on Adding Identity Constraint to an element [message #24326 is a reply to message #24200] Fri, 04 July 2003 05:30 Go to previous messageGo to next message
Ed,
Thanks - worked like a charm - but i have another problem - when i was
checking the schema using XSDDiagnostics iam getting the following error
XSD: Key reference '#PERSON_K' is unresolved
(The same schema is working well and was able to validate XML doc data
successfully - when i was cross testing with XML SPY tool!)
the schema generated is ------
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:annotation>
<xsd:documentation xml:lang="en">text</xsd:documentation>
</xsd:annotation>
</xsd:unique>
<xsd:key name="PERSON_K">
</xsd:key>
<xsd:keyref name="PERSON_MAK" refer="PERSON_K">
</xsd:keyref>
</xsd:element>
....................... and so on
request help on the problem . (looks like its the last hurdle left before
our program can deliver a clean error free schema!)
Thanks once again for the solution given-
regards
prabhakar
> Prabhakar,
> element.
> key.setName("key");
> references key.
> // <xsd:selector
> // <xsd:field
> // </xsd:unique>
> // <xsd:selector
> // <xsd:field
> // </xsd:key>
> // <xsd:selector
> // <xsd:field
> // </xsd:keyref>
> // </xsd:element>
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 786c786
> KEYREF...
> > </xsd:unique>
> > </xsd:key>
> > </xsd:keyref>
> > </xsd:element>
> > <xsd:sequence>
> > thanks & regards
> > prabhakar
> <html>
> Prabhakar,
> <p><tt>ÿÿÿÿ {</tt>
> <br><tt>ÿÿÿÿÿÿ // Create an element declaration
> <br><tt>ÿÿÿÿÿÿ //</tt>
> <br><tt>ÿÿÿÿÿÿ XSDElementDeclaration simpleRecursiveElementDeclaration
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Create an annotation placeholder
> <br><tt>ÿÿÿÿÿÿ XSDAnnotation annotation =
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Set the element type definition
> <br><tt>ÿÿÿÿÿÿ simpleRecursiveElementDeclaration.setTypeDefinition</tt>
> <br><tt>ÿÿÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Create a unique identity
> <br><tt>ÿÿÿÿÿÿ XSDIdentityConstraintDefinition
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ unique.setName("unique");</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition uniqueSelector
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ unique.setSelector(uniqueSelector);</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition uniqueField
> <br><tt>ÿÿÿÿÿÿ uniqueField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ unique.getFields().add(uniqueField);</tt>
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Create a key identity constraint
> called key.</tt>
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ key.setName("key");</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition keySelector
> <br><tt>ÿÿÿÿÿÿ keySelector.setVariety(XSDXPathVariety.SELECTOR_LITERAL);</tt >
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ key.setSelector(keySelector);</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition keyField
> <br><tt>ÿÿÿÿÿÿ keyField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ key.getFields().add(keyField);</tt>
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Create a keyref identity
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ keyref.setName("keyref");</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition keyrefSelector
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ keyref.setSelector(keyrefSelector);</tt>
> <br><tt>ÿÿÿÿÿÿ XSDXPathDefinition keyrefField
> <br><tt>ÿÿÿÿÿÿ keyrefField.setVariety(XSDXPathVariety.FIELD_LITERAL);</tt>
> <br><tt>ÿÿÿÿÿÿ keyrefField.setValue("simpleAttributeDeclaration");</tt>
> <br><tt>ÿÿÿÿÿÿ keyref.setReferencedKey(key);</tt>
> <br><tt>ÿÿÿÿÿÿ keyref.getFields().add(keyrefField);</tt>
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // Add the element to the schema.</tt>
> <br><tt>ÿÿÿÿÿÿ
> <p><tt>ÿÿÿÿÿÿ // This is theÿ result
> <br><tt>ÿÿÿÿÿÿ //ÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ //ÿÿÿÿÿÿÿÿ
> <xsd:annotation/></tt>
> <xsd:unique name="unique"></tt>
> <br><tt>ÿÿÿÿÿÿ //ÿÿÿÿÿÿÿÿÿÿÿÿ
> <xsd:selector xpath="simpleRecursiveElementDeclaration"/></tt>
> <xsd:field xpath="simpleAttributeDeclarationGroupMember"/></tt>
> </xsd:unique></tt>
> <xsd:key name="key"></tt>
> </xsd:key></tt>
> <xsd:keyref name="keyref" refer="PTS:key"></tt>
> <xsd:field xpath="simpleAttributeDeclaration"/></tt>
> </xsd:keyref></tt>
> </xsd:element></tt>
> <br><tt>ÿÿÿÿ }</tt></blockquote>
> exception:
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at org.eclipse.xsd.test.XSDMainTest.run(XSDMainTest.java:132)
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
> <br>ÿÿÿÿÿÿÿ at java.lang.reflect.Method.invoke(Native
> Method)
> <br>ÿÿÿÿÿÿÿ at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
> <br>ÿÿÿÿÿÿÿ at org.eclipse.core.launcher.Main.run(Main.java:747)
> <br>ÿÿÿÿÿÿÿ at
> <br>786c786
> <br><ÿÿÿÿÿÿÿÿÿÿ niceSetAttributeURIValue(theElement,
> <br>---
> <br>>ÿÿÿÿÿÿÿÿÿÿ niceSetAttributeURIValue(theElement,
> <br>ÿ</blockquote>
KEYREF...
> <br>ÿ
unique,key
> <p><xsd:element name="ROOT_ELEMENT" type="ROOT_ELEMENT">
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <xsd:uniqueÿ name="PERSON_PK">
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:unique>
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:key>
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:keyref>
> <br></xsd:element>
> <br><xsd:complexType name="ROOT_ELEMENT">
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <xsd:sequence>
> <p>thanks & regards
> </html>
Re: Help on Adding Identity Constraint to an element [message #24422 is a reply to message #24326] Fri, 04 July 2003 07:31 Go to previous message
--------------3EB7D7AE192E58C2ADEE4E50
Content-Type: text/plain; charset=iso-8859-1
Prabhakar,
When I open the sample schema you show below in the Sample XML Schema Editor, I don't get any diagnostics:
[Image]
I'm not sure what version of XSD you are using or what you did to obtain the diagnostic you mention.
prabhakar wrote:
> Ed,
> <xsd:annotation>
> </xsd:annotation>
> </xsd:unique>
> </xsd:key>
> </xsd:keyref>
> </xsd:element>
> regards
> prabhakar
> > Prabhakar,
> > element.
> > key.setName("key");
> > references key.
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:unique>
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:key>
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:keyref>
> > // </xsd:element>
> > exception:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > 786c786
> > KEYREF...
> > > </xsd:unique>
> > > </xsd:key>
> > > </xsd:keyref>
> > > </xsd:element>
> > > <xsd:sequence>
> > > thanks & regards
> > > prabhakar
> > <html>
> > Prabhakar,
> > <p><tt>
Re: Help on Adding Identity Constraint to an element [message #573534 is a reply to message #24089] Thu, 03 July 2003 10:07 Go to previous message
Prabhakar,
element.
key.setName("key");
references key.
// <xsd:selector
// <xsd:field
// </xsd:unique>
// <xsd:selector
// <xsd:field
// </xsd:key>
// <xsd:selector
// <xsd:field
// </xsd:keyref>
// </xsd:element>
exception:
786c786
KEYREF...
> </xsd:unique>
> </xsd:key>
> </xsd:keyref>
> </xsd:element>
> <xsd:sequence>
> thanks & regards
> prabhakar
<html>
Prabhakar,
called key.</tt>
&lt;/xsd:key></tt>
exception:
Method)
<br>786c786
<br>---
<br>&nbsp;
&lt;/xsd:unique>
&lt;/xsd:key>
&lt;/xsd:keyref>
&lt;xsd:sequence>
</html>
Re: Help on Adding Identity Constraint to an element [message #573667 is a reply to message #24200] Fri, 04 July 2003 05:30 Go to previous message
Ed,
<xsd:annotation>
</xsd:annotation>
</xsd:unique>
</xsd:key>
</xsd:keyref>
</xsd:element>
regards
prabhakar
> Prabhakar,
> element.
> key.setName("key");
> references key.
> // <xsd:selector
> // <xsd:field
> // </xsd:unique>
> // <xsd:selector
> // <xsd:field
> // </xsd:key>
> // <xsd:selector
> // <xsd:field
> // </xsd:keyref>
> // </xsd:element>
> exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> 786c786
> KEYREF...
> > </xsd:unique>
> > </xsd:key>
> > </xsd:keyref>
> > </xsd:element>
> > <xsd:sequence>
> > thanks & regards
> > prabhakar
> <html>
> Prabhakar,
> <p><tt>ÿÿÿÿ {</tt>
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> called key.</tt>
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> <br><tt>ÿÿÿÿÿÿ
> </xsd:unique></tt>
> </xsd:key></tt>
> </xsd:keyref></tt>
> </xsd:element></tt>
> exception:
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> <br>ÿÿÿÿÿÿÿ at
> Method)
> <br>ÿÿÿÿÿÿÿ at
> <br>786c786
> <br>---
> <br>ÿ</blockquote>
KEYREF...
> <br>ÿ
unique,key
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:unique>
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:key>
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> </xsd:keyref>
> <br></xsd:element>
> <br>ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
> <xsd:sequence>
> <p>thanks & regards
> </html>
Re: Help on Adding Identity Constraint to an element [message #573750 is a reply to message #24326] Fri, 04 July 2003 07:31 Go to previous message
Prabhakar,
[Image]
prabhakar wrote:
> Ed,
> <xsd:annotation>
> </xsd:annotation>
> </xsd:unique>
> </xsd:key>
> </xsd:keyref>
> </xsd:element>
> regards
> prabhakar
> > Prabhakar,
> > element.
> > key.setName("key");
> > references key.
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:unique>
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:key>
> > // <xsd:selector
> > // <xsd:field
> > // </xsd:keyref>
> > // </xsd:element>
> > exception:
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > 786c786
> > KEYREF...
> > > </xsd:unique>
> > > </xsd:key>
> > > </xsd:keyref>
> > > </xsd:element>
> > > <xsd:sequence>
> > > thanks & regards
> > > prabhakar
> > <html>
> > Prabhakar,
> > <p><tt>
Previous Topic:Loading Schema from JAR
Next Topic:Creating XSDSchema from DOM Element
Current Time: Sun Aug 31 23:04:31 EDT 2025
Powered by FUDForum. Page generated in 0.04542 seconds
