Home » Eclipse Projects » Eclipse Platform » Strange runtime error in workbench
Strange runtime error in workbench [message #244955] Tue, 25 May 2004 12:00
Originally posted by: BrianK.nospam.com
I've been working on and testing a plugin using the run-time workbench.
Seemingly out of the blue, the run-time workbench doesn't launch, and
I'm getting the following error in my .metadata...
!MESSAGE Unable to locate application extension:
org.eclipse.ui.ide.workbench
!STACK 0
java.lang.RuntimeException: Unable to locate application extension:
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:205)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:85)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
I have org.eclipse.ui, org.eclipse.ui.ide, and org.eclipse.ui.workbench
in my required plugins, but I can't locate org.eclipse.ui.ide.workbench.
Any ideas?
Previous Topic:CVS history and local history
Next Topic:browser widget between windows and linux
Current Time: Fri Nov 07 13:35:50 EST 2025
Powered by FUDForum. Page generated in 0.04658 seconds
