Home » Eclipse Projects » Subversive » Getting javahl 1.4.5 to work on windows xp
Getting javahl 1.4.5 to work on windows xp [message #24010] Wed, 02 July 2008 20:43 Go to next message
I am trying to get JavaHL 1.4.5 to work on Windows XP with Subversive
0.7.1 and I keep getting the following error message when I try to
create a new repository location in the SVN Repository Perspective:
The system cannot find the file specified
svn: can't create tunnel: the system cannot find the file specified
I am using the svn+ssh: protocol to connect to the repository.
Do I need to install some external software that JavaHL needs to access?
I can't find any documentation that covers this.
I currently have following subversive and svn connectors installed in my
Eclipse 3.3.2:
JavaHL 1.4.5 Win32 Binaries 2.0.1
Native JavaHL 1.4.5 Implementation 2.0.1
Subversive SVN Connectors 2.0.1
SVN Team Provider 0.7.1
SVN Team Provider Localization 0.7.1
I am successfully connecting to the repository using Eclipe 3.3.2 on
Linux using JavaHL 1.4.4.
Any suggestions would really be appreciated.
Keith
ps. I have tried using SVNKit 1.1.7 on both Windows XP and Linux and I
have had no luck with it when using the svn+ssh protocol, which is why I
am now trying to get the JavaHL connector to work.
Re: Getting javahl 1.4.5 to work on windows xp [message #24102 is a reply to message #24010] Wed, 02 July 2008 23:13 Go to previous messageGo to next message
I had a similar problem with JavaHL 1.4.5 on XP under Ganymede Final, too.
After Subversive gets looked up/installed via the Ganymede Update
Manager it still is missing the connector.
Once this is installed, any active SVN enabled Eclipse project trying to
sync with the SVN repository causes Eclipse to freeze or crash entirely !!!
This is the same for the other Win32 Native connector btw, so it sounds
like a problem similar to what is described below (I'm not using SSH
tunneling, but the same works on this Mac without a crash)
Werner
> Eclipse 3.3.2:
> Keith
Re: Getting javahl 1.4.5 to work on windows xp [message #24107 is a reply to message #24010] Thu, 03 July 2008 03:31 Go to previous messageGo to next message
Do I need a separate svn client, like TortoiseSVN, installed on my
Windows XP to be able to use JavaHL 1.4.5?
> Eclipse 3.3.2:
> Keith
Re: Getting javahl 1.4.5 to work on windows xp [message #24172 is a reply to message #24107] Thu, 03 July 2008 05:38 Go to previous message
No, you don't need to install the separate client.
The problem seems to refer to wrong tunneling configuration for your
network.
The native client does not include svn+ssh support, so the tunnel should
be created and configured using some external tool (ex. PUTTY).
>> Eclipse 3.3.2:
>> Thanks,
>> Keith
Previous Topic:Ganymede Subversive - Compare/Replace with version from Repository
Next Topic:Why isn't merge finding any changes?
Current Time: Sun Nov 16 12:36:26 EST 2025
Powered by FUDForum. Page generated in 0.04148 seconds
