Home » Archived » BIRT » How to use an image as a watermark?
How to use an image as a watermark? [message #244437] Fri, 22 June 2007 17:02 Go to next message
Originally posted by: swilson.acs.on.ca
Hi, I've designed an invoice using BIRT and want to put an image in the
background so it appears as a watermark. I can't seem to add anything to
the body on the 'master page'. Is there some way to combine master pages
and overlay them on top of each other?
Thanks in advance,
Shawn
Re: How to use an image as a watermark? [message #244459 is a reply to message #244437] Fri, 22 June 2007 19:15 Go to previous messageGo to next message
Select a master page and in the "Properties" view (<=2.1.x) or in the
"Advanced" tab of the Property Editor (>=2.2) set the "Background >
Background image" property.
Spunk
"Shawn Wilson" <swilson@acs.on.ca> schrieb im Newsbeitrag
news:e76745cdeff65618a42f770379947bab$1@www.eclipse.org...
> Thanks in advance,
> Shawn
Re: How to use an image as a watermark? [message #244969 is a reply to message #244459] Tue, 26 June 2007 16:55 Go to previous messageGo to next message
Originally posted by: sunadmn.gmail.com
Thanks for showing where to do that. Do you know what the syntax to use to
get the image to display may be?
Thanks a million,
-Steve
Re: How to use an image as a watermark? [message #245211 is a reply to message #244437] Wed, 27 June 2007 15:13 Go to previous message
Shawn,
Did you get this figured out? I found the spot, but was not sure about the
syntax to actually put the image in.
-Steve
Previous Topic:Question on JReport vs BIRT
Next Topic:Deploying a Report that use my own Data Source and Data Set
Current Time: Thu Nov 06 16:12:25 EST 2025
Powered by FUDForum. Page generated in 0.02809 seconds
