| Help! Reparent view [message #244383] |
Wed, 16 July 2008 22:24  |
Originally posted by: lifesting.gmail.com
--------------010104080801050005080106
I defined a simple ecore model as the attached image described.
There's two class one is Block, the other is CompositeBlock which is
inherited from Block
CompositeBlock is used to be Diagram model, both can be added in Diagram
as Nodes, that means there will be two CompositeBlockEditParts,
inherited from DiagramEditPart and ShapeNodeEditPart respectively.
I also set the *Related Diagram* property to *Canvas Mapping*(only one
canvas mapping defined) on CompositeBlock Node defeinition, so A new
diagram editor will open when I double click a CompositeBlock Node on
original editor, as you know, the two editor share same model.
Now, assume that I added three Block Node on original editor, and select
ed them all, then click *Merge* from context menu, the *Merge* action
will created a new CompositeBlock Node, attach a new created Diagram to
its HintedDiagramStyle. The most important step is move the selected
three Block Node to new created Diagram, in short, reparent view.
I tried several times as blow, but it failed.
MergeCommand:
Diagram diagram = getDiagram();
List<Node> selected = getSelectedNodes();
for(Node n : selected)
diagram.removeChild(n);
Node compositeBlockNode = newCreatedCompositeBlockNode();
HintedDiagramLinkStyle diagram_style = (HintedDiagramLinkStyle)
compositeBlockNode.getStyle(NotationPackage.eINSTANCE.getHin tedDiagramLinkStyle());
Diagram nestedDiagram = createLinkDiagramAndPersist(diagram_style);
for (Node n: selected)
nestedDiagram.insertChild(n);
persistAll();
I know above code doesn't work because the parent of all selected Nodes
still reference diagram not nestedDiagram, but I don't know how to
change it. Code may be like as blow:
CompositeBlock diagram_model = nestedDiagram.getElement();
changeViewParent(n, nestedDiagram);
changeModelParent(n.getElement, diagram_model);
Thanks!
Content-Type: image/jpeg;
name="ecore.JPG"
Content-Disposition: inline;
filename="ecore.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAC4AOUDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwD3+iiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAK KKKACiiigAoo
ooAKKKKACiiigDOuNYgtYzLNG0cPmGMSSSRopYEggbmHofyqKDxDZ3Uyw25W WVvupHcQsx78
APVHUphbwadIZ4YANSm/eTfcHyz9eR/Oo1vluNZ0lBqVjcn7Q52W4ww/cyc/ fPH4d6wlUkp2
S0KSVje+1Tf9A+5/76j/APi6PtU3/QPuf++o/wD4usXW4jqPirStJmuLuOzl sru5dbW5kt2a
SN7dUJeNlbAEr/LnByCQSBiuviOHSTp2nWxk1Kzht7ES6hJdB5JFuZDBA6kD EpZlJckrgHI3
E4rck6L7VN/0D7n/AL6j/wDi6PtU3/QPuf8AvqP/AOLrgbH4oXl3ouoXz6DB HNb6e2oRRLfl
lkjSG3mcM3lDawS6jwAGBYMCVABPQf8ACU3mz7H/AGZB/bP9of2f5H2s/Z/M +z/ac+b5e7b5
Xfy87+MY+agDe+1Tf9A+5/76j/8Ai6PtU3/QPuf++o//AIuudHjC5uLjRJrX S410nVbeCeO9
u53j2mQ/6shI3QOAUwHdA7OFUk5xoaXqFzdS+IY0s41u7O9MKI947xynyInQ 5K/ugVdQVVSA
dx+YkkgGl9qm/wCgfc/99R//ABdH2qb/AKB9z/31H/8AF1yNp4wv7L4eeG9U vrT7ZquqRQoq
Q+Yyu7RNKXbyomYZRGJCRthjj7oLDLvb69bxnFqkDalaWstvpMskNxeSq1u1 xcSRFDakmIlg
FR8keXguoZuoB6F9qm/6B9z/AN9R/wDxdH2qb/oH3P8A31H/APF1zOlXsXhy y8YzzzX1xY6T
dtKqzXL3EixrZwSsqtKxJ5LEAnGT2qx/wlN5s+x/2ZB/bP8AaH9n+R9rP2fz Ps/2nPm+Xu2+
V38vO/jGPmoA3JL54YnkksblUQFmOYzgDr/FVyvM9V8R6npuvXcLafKLnU9M snmtbq9k+y2M
ji6V/wB6EdFJZIowAF8xiMZOTXplABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRUEl7aQuU
luoY3HVWkANAE9FZ9zrenW0e43KSHssRDE/l/WqNv4qtJZSs0bwrn5WPzD8c dP1oAZcwXl1F
AbRGSS2vZpVkaNZEbJkQjHmKf4/0pEtdYe/s57vbJHbSGUJDbLGWJRk6mduP nJ6dq1tMdZLM
uhDK0spBHcGRquVDhFu7HcydSs7PWbdbfVPD630CuHWO6jhlUNgjIDMRnBIz 7mpJo4bi8try
bRWkurXd9nmdYS8W4YbaxbK5HBx1rSoqxHM6l4dsNQ0a702HSJdPS5t2tWms o7ZJFiZURkUn
IAKRovToq4xtUixBpFhD4fi0N9AWfT0QK0EkFsI3IO7cY1ITJb5uFAzyAK3q KAMW60zTb7UY
NRvPDUVxfQbfJuZoIHkj2ncu1i2RgkkY6GpLOzs9PuLq4svD62092++5khjh RpmyTlyGyxyx
OT6n1rWooAxX0zTZLO6s5PDUT2t3KZ7mFoICk0hIJd13YZsgHJ54FRwaJo9r fxX9v4VtobyJ
AkdxHbW6yIoTYAGByAF+XHpx0reooAwdN0TR9GuGuNL8K21jOyFGktba3iYr kHBKkHGQDj2F
Sf2Zpv8AY/8AZH/CNRf2Z/z5eRB5P3t33N2373PTrzW1RQBy2oeHtCawvSfC dmpktfJdza2/
MaAbFODkquxMDtsXHQV1NVdS/wCQVef9cH/9BNWqACiiigAooooAKKKKACii igAooooAKKKK
ACqtr/x833/Xcf8AotKtVVtf+Pm+/wCu4/8ARaUASXFrBdJsniWQe46fQ9qp QaBYW8hcRl8n
gOcge3uPrmtOigDNsrKF4XbMy/vpRhJnUD943QA4FWPsEP8Afuf/AAJk/wDi qgtLiVIpFWzn
kAnl+ZSmD+8b1YGp/tU3/QPuf++o/wD4ugA+wQ/37n/wJk/+Ko+wQ/37n/wJ k/8AiqPtU3/Q
Puf++o//AIuj7VN/0D7n/vqP/wCLoAPsEP8Afuf/AAJk/wDiqPsEP9+5/wDA mT/4qj7VN/0D
7n/vqP8A+Lo+1Tf9A+5/76j/APi6AD7BD/fuf/AmT/4qj7BD/fuf/AmT/wCK o+1Tf9A+5/76
j/8Ai6PtU3/QPuf++o//AIugA+wQ/wB+5/8AAmT/AOKo+wQ/37n/AMCZP/iq PtU3/QPuf++o
/wD4uj7VN/0D7n/vqP8A+LoAPsEP9+5/8CZP/iqPsEP9+5/8CZP/AIqj7VN/ 0D7n/vqP/wCL
o+1Tf9A+5/76j/8Ai6AK2oWMSabdMHuMiFyM3EhHQ9i3NadZmoXMrabdA2Nw oMLgsWjwODzw
1adABRRRQAUUUUAFFFFAHF+HdXvNWs7jRLy/1K31Bbi8W31Ly7fdcRQXRjLK ArICoMatujXO
7Kg8kXNJ8SSp4I8N6heRz3+panaW+2KBUV7iZofMfG4qi/KrtyVHy4HOAbie EdHiN20Ud3G9
07u7x306sheTzH8tg+Ygz4LBNobAznAog8I6PbaNFpMMd2tpC4eDN9OZICF2 jy5C++MbcrhW
AwWHRjkAj/4S6zmlsV06zvtRjuore4MtrEMQQzttikcOyttOGJ2hioQlgBjO H4e8ayNFqWnS
Qalrd5pL3Zu7i2SAsqpPcLEjIrITKywjAVOdyk4BzXUP4e0xri0njgktntES OIWk8luuxDlE
ZY2UOi84VgQNzYHzHNO18F6JZ+WbdL5Gj+0bH/tK5Ljz8eb8xkz8xUN14Ybh huaALmga3F4h
0tdQgt5IYHcrGWmhlEgHBZWhkdSM5HXOVPFalZ+k6LZaJFPHZLP/AKRL50zz 3Mk7u+1UyXkZ
m+6ijr2rQoAKq2v/AB833/Xcf+i0q1VW1/4+b7/ruP8A0WlAFqiiigCrp/8A x7P/ANd5f/Rj
Vaqs2n2TuXezt2Zjkkxgkn8qT+zbD/nytv8Av0v+FAFqiqv9m2H/AD5W3/fp f8KP7NsP+fK2
/wC/S/4UAWqKq/2bYf8APlbf9+l/wo/s2w/58rb/AL9L/hQBaorNewshqMKC zt9pikJHlLyQ
Ux29zVj+zbD/AJ8rb/v0v+FAFqiqv9m2H/Plbf8Afpf8KP7NsP8Anytv+/S/ 4UAWqKq/2bYf
8+Vt/wB+l/wo/s2w/wCfK2/79L/hQAal/wAgq8/64P8A+gmrVVf7NsP+fK2/ 79L/AIVaoAKK
KKACiiigAooooAKKKKACiiigAooooAKq2v8Ax833/Xcf+i0q1VW1/wCPm+/6 7j/0WlAFqiii
gAooooAKKKKACiiigCrJ/wAhW3/64S/+hR1aqrJ/yFbf/rhL/wChR1aoAKKK KACiiigAoooo
AKKKKACiiigDi7/V9Tj1TUbuO/kSCw1iy01bIRxmKVJvs253JXfvH2lsbWUf ImQfm3dpWXN4
e0y41QajJBIZ96yMgnkEUjrja7xBtjuNq4ZlJGxMH5VxcNlEbOa1Lz+XLv3E TuHG8kna+dy9
TjBG3gDAAwAc3458XzeEbWylg0+S+e4uI4zDbqZJtpljVisYxkbWKhs8SPEu Dv46SwuftmnW
11ugbzokkzby+bGcgH5HwNy88NgZHOBUk0ENygSeKOVA6uFdQwDKwZTz3DAE HsQDUlABRRRQ
AUUUUAFVbX/j5vv+u4/9FpVqqtr/AMfN9/13H/otKALVFFFABRRRQAUUUUAF FFFAFWT/AJCt
v/1wl/8AQo6tVVk/5Ctv/wBcJf8A0KOrVABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFZVzq72yCRoE8t5mhjwzszMu7+FUJ6KTWrXNam/lwacTJNH/wATKYbo Y97j5Z+i4Ofy
qJtqN0Nb6lyHXHmuIoFtgskpKp5qzRgkAnGWiA6An8KtRLfxSTv5FsfNcPjz 24+VV/uf7NYy
zh9Z0lRc30ubl/luLYxr/qZe+xefbNY/xNTR5Lnwuupz6HBIdQk2yaxCksSx /Zpd+VZlyu7y
v4gN3lnk4FTSlKSfMDS6HbeZf/8APtbf+BDf/EUeZf8A/Ptbf+BDf/EV57ou oaDZ+MfDLTz2
lnrVxoTQ3qXk6fbWmb7H5Uc7EKzykBsbgCcHAFbEfi/Uvtusxpp8d49nb3cq 2NurCeFoXCxJ
IfmybhT5kfyr8oOBJ96tRHVeZf8A/Ptbf+BDf/EVJazNcQb2QIwZkIByMqxH XA9K8t1/xHKw
0LULfUPDmu61Hqs8GlPp8iRiTdZOuxt8xx+9ePcA/IMePmIFd74R1BdW8M2u oJfW98lw0si3
NtE0SODI3RGZivoQTkEHOOlAG3RRRQAUUUUAVZP+Qrb/APXCX/0KOrVVZP8A kK2//XCX/wBC
jq1QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABWDNY3V/BGIm8 kwXcsscscwDZ
zIpyGjYYwxreqrp//Hs//XeX/wBGNSavowMqLSNRW8trme7kufs7mRI5Zowu 4qy5O2AHox71
q+Zf/wDPtbf+BDf/ABFWqKFFLYCr5l//AM+1t/4EN/8AEUeZf/8APtbf+BDf /EVaopgVfMv/
APn2tv8AwIb/AOIpNN3G0JcAN50uQDkA+Y3erdZdrehN9tGheYzSnDHav+sb uev4A0AalFVf
s0s3NzMSP+ecXyr+J6n8/wAKr2F9EunWoZbgsIUBIt5Dngd8c0AaVFVft8P9 y5/8BpP/AImj
7fD/AHLn/wABpP8A4mgAk/5Ctv8A9cJf/Qo6tVSSUXGpROiShUhkBLxMgySm OoHoau0AFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAVnWljaTRSSS2sDuZ5cs0Y JP7xu9aNZ1o9
2IpBFBAyefLgtMVP+sbttP8AOgCf+zbD/nytv+/S/wCFH9m2H/Plbf8Afpf8 KPMv/wDn2tv/
AAIb/wCIo8y//wCfa2/8CG/+IoAP7NsP+fK2/wC/S/4Uf2bYf8+Vt/36X/Cj zL//AJ9rb/wI
b/4ijzL/AP59rb/wIb/4igA/s2w/58rb/v0v+FR2UEL2LRNEhjE0oCFRgfvG xxUnmX//AD7W
3/gQ3/xFJpu42hLgBvOlyAcgHzG70AL9nmh/495jt/55y/MPwPUfr9KktIWt 7KCFiC0caoSO
mQMVNRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFZ1pfWkMUkc
t1AjieXKtIAR+8btWjRQBV/tKw/5/bb/AL+r/jR/aVh/z+23/f1f8atUUAVf 7SsP+f22/wC/
q/40f2lYf8/tt/39X/GrVFAFX+0rD/n9tv8Av6v+NJprK9oWVgytNKQQcgjz Gq3RQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAf/9k=
--------------010104080801050005080106--
| Re: Help! Reparent view [message #244391 is a reply to message #244383] |
Thu, 17 July 2008 00:27  |
Sorry, please move this thread to GMF group, thanks!
> MergeCommand:
> persistAll();
> Thanks!
FUDForum. Page generated in 0.35211 seconds
