| How can I use TPTP on SUSE9.3?? [message #244353] |
Mon, 31 December 2007 12:02  |
Originally posted by: 10takashi.gmail.com
Hello there,
Currently, I'm trying to use TPTP on this environment.
I want to monitor remote JBoss application server
OS: SUSE 9.3
Eclipse: 3.2
Java: 1.5.10.0
Target Server: Jboss4.2.2
TPTP (Installed from Eclipse)
TPTP Agent controller 4.4.0
I could use TPTP Agent controller without any problem.
However, when I tried to start JBoss server, I got this error,
"Error occurred during the initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent"
My /etc/skel/profile is
JAVA_HOME="/usr/java/jdk1.5.0_10"
AGENT_HOME="/home/agent"
LD_LIBRARY_PATH="$AGENT_HOME/lib"
JBOSS_HOME="/home/jboss-4.2.2"
PATH="$JAVA_HOME/bin:$AGENT_HOME/bin:$LD_LIBRARY_PATH:$PATH "
I'm quite appriciated if anyone will give me good suggestion.
Best regards
Takashi
| Re: How can I use TPTP on SUSE9.3?? [message #244605 is a reply to message #244353] |
Thu, 03 January 2008 04:32  |
Takashi,
Please post this question to the TPTP newsgroup. Before doing that
though, I would recommend searching the TPTP newsgroup for similar
posts. I am quite sure this problem was already answered.
BTW, you may want to try TPTP 4.4 with Eclipse 3.3. It is much more stable.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.08650 seconds
