Home » Language IDEs » Java Development Tools (JDT) » Java Code Formatter from command line
Java Code Formatter from command line [message #244212] Mon, 04 June 2007 07:25 Go to next message
Originally posted by: stefan.bley.dd.gmx.de
Calling the Java Code Formatter from command line, e.g.
eclipse -application org.eclipse.jdt.core.JavaCodeFormatter -config
c:\temp\my.prefs c:\my_project\src
does work good if I do NOT have Java annotations in my source code. With
annotations, the Code Formatter does not format the code at all, whilst it
does it job when being called within the IDE, e.g. pressing
[Ctrl][Shift][F].
I use Eclipse 3.3RC2. Any ideas?
Stefan
Re: Java Code Formatter from command line [message #244221 is a reply to message #244212] Mon, 04 June 2007 09:04 Go to previous messageGo to next message
> it does it job when being called within the IDE, e.g. pressing
> [Ctrl][Shift][F].
Are you sure that the file c:\temp\my.prefs contains the options for the
compliance, source level and target level?
Make sure that you have the same values for these three options:
org.eclipse.jdt.core.compiler.compliance=1.5
org.eclipse.jdt.core.compiler.codegen.targetPlatform=1.5
org.eclipse.jdt.core.compiler.source=1.5
Olivier
Re: Java Code Formatter from command line [message #244226 is a reply to message #244221] Mon, 04 June 2007 11:00 Go to previous messageGo to next message
>> [Ctrl][Shift][F].
> Are you sure that the file c:tempmy.prefs contains the options for the
> Olivier
Hi Olivier,
you are right, I did not add these lines. Thank you!
It would be nice if one could omit the config file, so that the Code
Formatter uses the active profile (under Preferences -> ...)
Stefan
Re: Java Code Formatter from command line [message #244234 is a reply to message #244226] Mon, 04 June 2007 13:44 Go to previous message
Getting the active profile would require some UI code. The code
formatter itself has no idea that formatter profiles exist. It is purely
based on Core code.
Olivier
Previous Topic:Eclipse Summit Europe 2007
Next Topic:Misleading compiler error on single line if statement
Current Time: Mon Oct 20 14:46:56 EDT 2025
Powered by FUDForum. Page generated in 0.25115 seconds
