Home » Eclipse Projects » GEF » Unable to select editpart by clicking
Unable to select editpart by clicking [message #244187] Tue, 08 July 2008 15:31 Go to next message
Originally posted by: darpan.cmu.edu
I am unable to select an editpart by clicking. When I click on it the
selection seems to fall through the editpart. However, when I use the
Marquee tool the editpart is selected.
Any help appreciated.
-darpan
Re: Unable to select editpart by clicking [message #244191 is a reply to message #244187] Tue, 08 July 2008 16:08 Go to previous messageGo to next message
I found the solution. I was retuning MarqueeTracker in the getDragTracker
method. Now that I return DragEditPartsTracker, things work just fine.
However, I have another problem. I need the editpart that I just created
to be selected and thats not happening. I am not sure what the default
behavior in GEF is.
-darpan
Re: Unable to select editpart by clicking [message #244256 is a reply to message #244191] Sat, 12 July 2008 02:30 Go to previous messageGo to next message
Originally posted by: annamalai.ancitconsulting.com
After you create a new model object .. u can do
getViewer().setSelection(editPart) that you just created. It would select
the model object that you created.
If you dont kno the editPart related to the model object. Then you can use
getViewer().getEditPartRegistry().get(modelObject) and this woudl return the
editPart for that model object and then pass the editPart to the
setSelection method.
Malai
"Darpan Saini" <darpan@cmu.edu> wrote in message
news:3f95f7997f8f274929f55507e01882b5$1@www.eclipse.org...
> behavior in GEF is.
> -darpan
Re: Unable to select editpart by clicking [message #244265 is a reply to message #244256] Sun, 13 July 2008 08:42 Go to previous message
That works.
-darpan
Previous Topic:how to deal with model event efficiently
Next Topic:Who handles SelectionRequest which is created by Targeting Tool?
Current Time: Wed Nov 19 08:09:39 EST 2025
Powered by FUDForum. Page generated in 0.10725 seconds
