Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless Pde build : build All
Headless Pde build : build All [message #23966] Thu, 25 September 2008 04:36 Go to next message
Ive got a headless build a bit complex with optional plugin in it.
I download all my plugins from svn so not build and I build everything
thanks to productBuild.xml, so I do not have any build.xml for each
pluginn there are generated each time I need it.
I ve a generated product working but with some errors on it (dependency
errors) because I ve got plugins not included in my product (so not built
by my product build) needed by some other for the build so to resolve my
problem I need to build all my plugins independently from the product
(even if I need to do it one by one).
Is there any way to doing that ?
Bertrand
Re: Headless Pde build : build All [message #482423 is a reply to message #23966] Wed, 26 August 2009 09:56 Go to previous messageGo to next message
It's bad form to post on a message that's this old, but I've ran into
exactly the same problem.
Did you find a solution?
-- TJ
Re: Headless Pde build : build All [message #482499 is a reply to message #482423] Wed, 26 August 2009 15:50 Go to previous message
yes, this is really bad ;-). For example I don't see the old message
anymore so I don't know what your question is exactly about.
An example for PDE build is described here:
http://www.vogella.de/articles/EclipsePDEBuild/article.html
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
> -- TJ
Re: Headless Pde build : build All [message #600973 is a reply to message #23966] Wed, 26 August 2009 09:56 Go to previous message
-- TJ
Re: Headless Pde build : build All [message #600984 is a reply to message #482423] Wed, 26 August 2009 15:50 Go to previous message
Best regards, Lars
> -- TJ
Previous Topic:Key Bindings for Actions does
Next Topic:Key Bindings for Actions does
Current Time: Tue Jul 22 01:39:16 EDT 2025
Powered by FUDForum. Page generated in 0.04386 seconds
