Home » Archived » BIRT » About chart
About chart [message #23937] Thu, 31 March 2005 01:01 Go to next message
Originally posted by: eros.design.gmail.com
How to insert chart in report? why i didn't see any chart object ICON in=
eclipse?
www.chinaui.org
Re: About chart [message #24097 is a reply to message #23937] Thu, 31 March 2005 13:19 Go to previous message
Are you using a development build of the plug-ins to evaluate charts in
the context of BIRT? If yes, did you follow these steps:
A] Pull out the latest source from CVS
B] Build all plug-ins by executing the build.xml ant script provided in
the viewer plug-in
C] Clean and rebuild the 'org.eclipse.birt.chart.reportitem' plug-in
project after step [B]
Step [C] is important because step [B] only performs a partial build of
the 'org.eclipse.birt.chart.reportitem' plug-in project as required at
runtime by the viewer.
Once you do that, a chart icon should appear in the palette for use in
BIRT report designs.
If you are using the 03/28 binary build containing deployable plug-ins,
you should not see this problem.
Rohit Colaco
ECE Project Lead
eclipse?
www.chinaui.org
Previous Topic:test
Next Topic:stored procedure
Current Time: Sun Jul 27 12:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.04106 seconds
