Home » Eclipse Projects » Eclipse Platform » plugins with additional jar libraries
plugins with additional jar libraries [message #243679] Sat, 22 May 2004 16:38 Go to next message
I have a plugin that has in addition to the normal source folder a
ready-compiled jar file which is defined in the plugin.xml file as a
runtime library (as well as the bundle classpath in the manifest.mf),
too. This worked fine with m8 but I have problems with this setting with
m9. Is this setting no longer supported or does it look like a bug?
Thanks for the help,
Martin
Re: plugins with additional jar libraries [message #243890 is a reply to message #243679] Sun, 23 May 2004 04:15 Go to previous messageGo to next message
Solved the problem for myself, but the way it works is still somewhat
strange.
I added the additional jar file (which is contributed by the same
plugin) to the extra classpath items of the build.properties. Then PDE
sets up the classpath correctly.
If I tell PDE to update the classpath from the plugin.xml (or
manifest.mf) PDE does not add the jar library to the build path. This
does not seem to be correct behavior.
-Martin
Re: plugins with additional jar libraries [message #243956 is a reply to message #243890] Sun, 23 May 2004 10:09 Go to previous messageGo to next message
Originally posted by: linnet.nospam.users.sourceforge.net
Hi Martin,
I have been troubled by the exact same behaviour and have solved it in
the exact same way. In my opinion, it's a bug. Will you file a bug
report against PDE or should I?
Jesper
Martin Lippert wrote:
>> with m9. Is this setting no longer supported or does it look like a bug?
> strange.
> Best regards,
> -Martin
Re: plugins with additional jar libraries [message #243961 is a reply to message #243956] Sun, 23 May 2004 10:16 Go to previous message
Hi Jesper,
Done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63576
-Martin
> Best regards,
> Jesper
>> strange.
>> Best regards,
>> -Martin
Previous Topic:Printing in linux
Next Topic:File archive bit not set saving sources
Current Time: Sun Nov 09 02:34:50 EST 2025
Powered by FUDForum. Page generated in 0.04088 seconds
