Home » Newcomers » Newcomers » NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #243470] Tue, 18 December 2007 08:35 Go to next message
Originally posted by: vikas.khengare.unnat-e.com
Hi Friends,
I am creating new file and saving some data in it. I am able to create new
file in "runtime-EclipseApplication" folder and save data in it on my
development machine. I am trying to get path to save file from
ResourcesPlugin.getWorkspace().getRoot().getLocation().toStr ing() .
But when I am trying to put my plug-in on test machine it is not creating
new file & throwing error.
!ENTRY org.eclipse.ui 4 0 2007-12-18 18:27:05.781
!MESSAGE org/eclipse/core/resources/ResourcesPlugin
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin
at kr.roboid.datalogger.ui.Packet.saveInToFile(Packet.java:137)
at kr.roboid.datalogger.ui.Packet.access$0(Packet.java:135)
at kr.roboid.datalogger.ui.Packet$1.widgetDisposed(Packet.java: 101)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:101)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:933)
at org.eclipse.swt.widgets.Widget.release(Widget.java:743)
at org.eclipse.swt.widgets.Composite.releaseChildren(Composite. java:636)
at org.eclipse.swt.widgets.Widget.release(Widget.java:746)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:415)
at org.eclipse.ui.internal.PartPane.dispose(PartPane.java:167)
at org.eclipse.ui.internal.ViewPane.dispose(ViewPane.java:193)
org.eclipse.ui.internal.WorkbenchPartReference.dispose(Workb enchPartReferenc
e.java:639)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1548)
org.eclipse.ui.internal.WorkbenchPage.partRemoved(WorkbenchP age.java:1540)
at org.eclipse.ui.internal.ViewFactory.releaseView(ViewFactory. java:252)
at org.eclipse.ui.internal.Perspective.hideView(Perspective.jav a:494)
at org.eclipse.ui.internal.WorkbenchPage.hideView(WorkbenchPage .java:2208)
at org.eclipse.ui.internal.ViewPane.doHide(ViewPane.java:213)
at org.eclipse.ui.internal.PartStack.close(PartStack.java:499)
at org.eclipse.ui.internal.PartStack.close(PartStack.java:482)
at org.eclipse.ui.internal.PartStack$1.close(PartStack.java:106 )
org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation$1.handleE
vent(TabbedStackPresentation.java:81)
org.eclipse.ui.internal.presentations.util.AbstractTabFolder .fireEvent(Abstr
actTabFolder.java:267)
actTabFolder.java:276)
It works fine on development machine but not on test machine.
Can some one give some hints in this situation?
With best regards
From
Vikas R. Khengare
Re: NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #243475 is a reply to message #243470] Tue, 18 December 2007 08:42 Go to previous messageGo to next message
Vikas,
Did you add a dependency on org.eclipse.core.resources in your MANIFEST.MF?
Vikas wrote:
> Hi Friends,
> !STACK 0
> at
> at
> e.java:639)
> at
> at
> at
> at
> at
Re: NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #243488 is a reply to message #243475] Tue, 18 December 2007 09:33 Go to previous messageGo to next message
Hi Friends/ Ed Merks
Yes, I have added dependency on org.eclipse.core.resource in my MANIFEST.MF
file by writing,
Require-Bundle: org.eclipse.ui, org.eclipse.core.runtime,
I am getting error on line
" ResourcesPlugin.getWorkspace().getRoot().getLocation().toStr ing() " on test
machine, while on development machine it is giving path to "myWorkspace"
directory.
What else I can try?
With best regards
From
Vikas R. Khengare
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fk8ind$c7e$3@build.eclipse.org...
> Vikas,
MANIFEST.MF?
> Vikas wrote:
> > Hi Friends,
new
creating
> > !STACK 0
> > at
> > at
> > at
> > at
> > e.java:639)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
Re: NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #243492 is a reply to message #243488] Tue, 18 December 2007 09:43 Go to previous message
Vikas,
Perhaps the plugin in missing on the test machine. Have a look in the
error log of the workspace for the test machine to see it's complaining
about missing bundles. Given that it works in one place and not in the
other, the differences between the setups will be the key to solving the
problem...
> file by writing,
> directory.
Previous Topic:Merged eclipse environs - PDT, Java, EPIC, etc?
Next Topic:encoding user preferences in launch configuration
Current Time: Tue Dec 02 12:37:53 EST 2025
Powered by FUDForum. Page generated in 0.07748 seconds
